I like the EF as well
And I did release for it, and still do actually.
Yet, we/you/everyone should be aware that some/several of this untested bunch will/might have issues later in the game.
Feedback of those that actually play it is necessary here.
Hallo Besucher, der Thread wurde 436k mal aufgerufen und enthält 1603 Antworten
letzter Beitrag von CapFuture1975 am
Disk2EasyFlash - Fertige Images
- Ebster
- Erledigt
Typhoon of Steel - Europe v1.1 (1988)
Typhoon of Steel - Pacific v1.1 (1988) -
Space Rogue is broken. Possibly the used crack already is.
Space Rogue is erased from collection.
It's a real pitty nobody converted this disk-game (better than Elite, by the way) for Easyflash cartridge. -
Klaus/Stephan,
I just have one more wish here for D2EF release, and that will be:
Enforcer - best shoot'em up ever on C64 done by Manfred Trenz!
It's 1D game, according to http://www.csdb.dk it has 15 cracks (!), but only one version working with SD2IEC (!), and that's from Lurid & Tricycle.
This one is probably easiest for conversion to D2EF release.
If you can leave trainers, it would be great!I know we have this game on Onslaught Shooter Collection, but it's without trainer and level-skip.
And - of course, without option to mix this game with others that we want filling 1MB slot using xbank versions -
The Joker,
Can you write program to convert Ocean CRT games to CRT-XBANK versions?
For NONE of existing 14 cartridge games with Ocean Type 1 loader (128 KB+) we don't have D2EF releases, and games are really powerful!
Converting these to xbank versions will raise great quality of our D2EF collection!Here's the list:
128 KB:
Batman the Movie
Battle Command
Cyberball
Double Dragon
Navy Seals
Pang
Robocop 3
Satan
Toki256 KB:
Chase HQ II (SPecial Criminal Investigations)
Robocop 2
Shadow of the Beast
Space Gun512 KB:
Terminator II - Judgment Day -
I don't think you can convert the Ocean Format to xbank.
Klaus/Stephan,
And - of course, without option to mix this game with others that we want filling 1MB slot using xbank versionsEnforcer loads under $d000 and this is unsupported by disk2easyflash.
Disk2EF use the Loadvector at $0330 to link the EF-Ramdisk, therefore not all games work with it.I will try to implement a getbyte loaderoutine or a stream depacker into disk2easyflash.
Gruß: Stephan
Retro-Nerd,
Probably you're right that Ocean type 1 CRT games can't be converted to CRT-XBANK versions, but let's The Joker confirm this.
Anyway, both DCM and D2EF programs gives you opportunity to put ONE Ocean Type 1 CRT game inside 1 MB slot of EF cartridge, and that means these games can be part of game compilations done by Easyflash afficionados here.
In other words, they deserve to be posted here
So, here it goes - first, Ocean Type 1 games done in 128 KB:
Batman the Movie (1989)
Battle Command (1991)
Cyberball - Football in the 21st Century (1990)
Double Dragon (1992)
Navy Seals (1990)
Pang (1991)
Robocop 3 (1992)
Satan (1990)
Toki (1991)I should mention Satan CRT game is not originally done in Ocean type 1 loader, but someone made a fix for this.
Ocean Type 1 CRT games done in 256 KB:
SCI - Special Criminal Investigation (Chase HQ II) (1990)
Robocop 2 (1990)
Shadow of the Beast (1990)
Space Gun (1992)Ocean Type 1 CRT game done in 512 KB:
Thanks for all theese great release, you miss "cabal" now
Fourth Protocol, The (1985)
Labyrinth from Activision/Lucasfilm
someone asked for it, here is it.
i have not complete test the game.
if any error occur, please send me a
winvice snapshot or an explanation ofthe error
have fun with it
Greets: Stephan
Besten Dank. Eine Speicherfunktion im Flash wird es wohl nicht geben, oder?
Sorry, vom Programieren des Anlegens eines Spielstandes in der EasyFlash habe ich noch nicht genug Wissen.Soweit ich weiß muss man dafür gleich 64KB resevieren
Das Auslesen von Daten aus der EF in den C64 Speicher habe ich schon gut im Griff. Ich muss aber beides, dass Lesen und dass Schreiben, coden können,
um eine richtige EF-Anpassung zu machen, nicht mit Disk2Easflash. Obwohl, schlecht ist des Programm auch mal wieder nicht. Es hat nur einige blöde
beschränkungen.Gruß: Stephan
Shadow of the Beast from psygnossis.
another great game adaptet to work with disk2easyflash
Dann mal eines, wo nicht gespeichert werden muß. Target Renegade wäre nett.
Mean Street Disk2EasyFlash
Have fun with it.
Greets: Stephan
Maybe I can help...
PM me with details like which version you have used as a starting point.
