Hello, i am from iutaly. Do you have a photo or a scan of the booklet/instruction/manual?
Hello, Guest the thread was called5.6k times and contains 41 replays
last post from cbm-warrior at the
VC20 .taps
- conch0
Ciao e ben venuto !!
Conosci questa pagina ? Magari trovi qui quello che cerci.I know that site. There is nNothing in that site about C= games 2001 or german issues of Sonnen Verlag or Sonnerverlag. Also i can't find in all internet photo or scan of manual of Sonnen Verlag issues like C= games 2001.
found only Supergame 1 and 2 from Sonnenverlag (c) 1985 Sonnenverlag Lugano Schweiz, printed in Italy Vertrieb Germany: Verlagsunion Wiesbaden
Oh thank you. This is a very important information for my research. So this king of cassette was made by Sonnenverlag, which it was in Lugano (Schweiz/Svizzera), and printed in Italy (from Pubblirome i bet), and distribution in Germany by Verlagsunion Wiesbaden.
Can you shot a photo of the manual page with company data? It's for an article on this cassette.Supergame is 100% style of italian Pubblirome cassette. And in 1987 the 3 supergame were released in italy in cassette called COMMODORISSIMO, but the booklet was in italian, and the cassette are identical, like warehouse funds.
it is a pity that we do not have information on the "games 2001" because there are no pictures on the internet of its manual.
the complete adress was
Sonnenverlag
Lugano / Schweiz
Via al Forte 2no more informations who did the printing
Vertrieb:
Verlagsunion Friedrich
Bergius Strasse 20
D 6202 Wiesbaden (Biebrich)
Tel. 06121 2660 Telex 4186116the booklet contain the manuals for the games. (all in german language)
Time permitting, i'll take a closer look with scanning / taping the booklet / tapes -
Sonnenverlag
Lugano / Schweiz
Vertrieb:
Bergius Strasse 20
Time permitting, i'll take a closer look with scanning / taping the booklet / tapesThank You, very precious informations
habe ich alle 3 Kassetten. Brauchst du die evtl., um saubere TAPs davon zu ziehen? Habe momentan nicht die Möglichkeit dafür.
ich versuche erst einmal mein Glück an den zwei, die ich vorliegen habe.
Zeitlich ist es momentan etwas knapp, ich könnte also nicht mal schnell ein paar .tap's ziehen und fertig.
Auch ist der Aufwand zu hoch die Tapes hin und herzuschicken... -
ich versuche erst einmal mein Glück an den zwei, die ich vorliegen habe.Zeitlich ist es momentan etwas knapp, ich könnte also nicht mal schnell ein paar .tap's ziehen und fertig.
Welche hast du denn überhaupt? Ich habe alle 3 und auch alle 3 Anleitungsheftchen, dazu je eine Kassette und Anleitung sogar doppelt. Die müßte ich erst raussuchen. Aber eine meiner Kassetten hatte damals schon Probleme gemacht.
Auch ist der Aufwand zu hoch die Tapes hin und herzuschicken...Na ein paar Kassetten samt Anleitungen in einen Maxibrief ggf. zu verschicken ist wirklich kein Staatsakt.
Man kann es ja oben sehen, ich habe Supergames 1 und 2 gefunden. Die Tapes auch noch nie abgespielt - ich weis auch nicht ob die sich noch lesen lassen - denke aber schon.
Du kannst mir aber gerne deine drei Exemplare schicken, dann besteht die Hoffnung auf jedenfall 100%ige Versionen zu erhalten bzw. ist die Chance größer - wie gesagt eine zeitnahe Bearbeitung kann nicht garantiert werden (könnte auch Weihnachten werden...)
Die 3 Kassetten die ich habe sind allerdings C= Games 2001, wovon du schon einige TAPs gezogen hast ...
an den anderen zwei wäre ich schon interessiert, wollen wir ja erhalten - ich würde falls Möglich .tap's erstellen und die Beihefte scannen...
Bei der anderen Kassette hast ja von Maus auch noch kein TAP gezogen, warum auch immer. Leider ist es ja nicht möglich, dich per PN anzuschreiben.
Maus ist übrigens nur ein Crack von Bongo ... benötigt + 16 KB.
es ist ein .tap erstellt worden, das nicht zu 100% gecleaned ist - lauffähig ist es trotzdem und nach deiner Info war mir das nicht mehr wichtig (da es ja eh nur ein Ripoff von Bongo ist)
Trotzdem ein gecleanedes TAP wäre toll. Außerdem sollte man auch diese Versionen sichern. Bin davon überzeugt, das die Programme dieser 3 Kassetten effektiv alles gehackte Originale sind, was in Italien ja leider üblich war.
Ich verweise einfach mal auf meinen alten Thread Futter frisch von der Mafia und dann guck mal die einzelnen Titel an. Da steht dann meist auch der tatsächliche Originaltitel bei dem Screenshot bei. Das gilt übrigens für alle Systeme.
hier ein aus mehreren RAW .tap zusammengecleantes Maus
Danke und gleich ein fieses TAP - das fragt expliziet nach der 16 KB Speichergrenze ab und will bei einer 24- oder 32 KB Erweiterung im Original nicht weiterladen.
Jetzt habe ich mir mal kurz das Supergame Nr. 1 / 2 angeschaut, je 8 Spiele sind drauf https://www.c64-wiki.de/wiki/Supergame_(Sammlung)
Alles gerippte bzw. auf Deutsch gemachte Versionen von mehr oder weniger bekannten Spielen
z.B. ist der Bergfex -> Spike's Peak
Boxautos -> Bumping Buggies usw.Die Spiele sind aber aufwendig verändert worden, sprich Logos, Copyrightvermerke wurden entfernt, eingedeutscht usw. spricht also einiges dafür das die Fa. Sonnenverlag hier eventuell doch Rechte erworben hat.
Die Programme sind mit Biturbo auf die Kassette gemastert.für mich keine Dringlichkeit sowas zu konvertieren.
Ich bin gerade damit beschäftigt, alle Programme sauber auf Diskette zu ziehen.
Leider macht die Ausgabe N. 1 Kassette Probleme, da wird gar nix mehr gelesen.
Hat jemand evtl. die Nr. 1 als (lose) Kassette in seinen Fundus und könnte mir die leihweise zur Verfügung stellen?
Das war in Italien eher Alltag. Nicht nur am C-64, auch VC-20 und C-16 Plus/4.
Gibt ja auch die Software Club Kassetten, die sind auch aus Italien und meist mit ZX Spectrum und MSX. Ob bei den Systemen die aber eine wesentliche Rolle gespielt haben, weiß ich nicht.
Ich verweise jetzt einfach mal auf eine ältere News von der Plus/4 World: http://plus4world.powweb.com/news/969
Unser Freund Luca ist ja Italiener und hat sich damals an die Arbeit gemacht, für den Plus/4 (und C-16/116 somit auch) alles an italienischen Material zu sammeln und zu archivieren. Da er natürlich in Italien lebt, sitzt er vor Ort eher an der Quelle. In den News kann man ja lesen, das praktisch alles mehr oder weniger Raubkopien sind, die aber nicht weiter verfolgt wurden, einerseits weil die Kassetten ja nur in Italien erhältlich waren, andererseits wohl auch kaum in so großen Mengen, das diese einen wirklichen Schaden angerichtet hätten.
Allerdings haben die Italiener damals schon verschiedene Originalprogramme "gecrackt", um die Copyright-Vermerke etc. im Code zu überschreiben, und auch recht aufwendig mit anderen Fastloadern neu auf Kassette gespeichert.
Eine Dringlichkeit so was zu konvertieren ist praktisch eher das man davon ein lauffähiges TAP zieht, aber mehr nicht.
Ich verweise hierzu immer wieder auf meinen alten Thread, wo man systemübergreifend noch viel mehr findet: Futter frisch von der Mafia
