So, neue Version 5.4 ist da, mit einer Menge an Änderungen und Fixes:
Add: Assembler system label ASSEMBLER_C64STUDIO
Fix: Crash in "import file" for text screen editor without solution
Add: Better error marking in code
Fix: Branches in zero page now assemble
Add: Binary export "To BASIC" now supports line start and delta
Add: Export for map data from selection now selects all if no selection exists on the map
Fix: Export in map editor now only adds prefix if selected
Add: Missing undo for default charsets in charset editor
Add: Delete option to Media Manager
Fix: Register display for $01 (off by one error)
Fix: Map project now properly builds charset selector from loaded charset
Add: BASIC macro variants for "gray" with a and numeric PETSCII {147} equals clrscr
Add: tiledata option to !mediasrc pseudo op
Fix: crash bug in BASIC compiler
Fix: Panels activate now without stealing focus, updates .NET framework to 3.5 (for latest DockPanelSuite)
Add: Syntax coloring updates in current line right away (instead of delayed as the rest of the file)
Add: Direct paint option for tiles in map editor
Add: More missing undo steps for map editor
Add: Export to BASIC to sprite and graphic screen editor
Fix: invalidoperation bug in MC export
Add: Manual color mapping in graphic screen editor
Fix: Search string not found it at very end of file
Add: Sector error info support for D64/D81 to File Manager
Fix: Crash in find next when target document was not open or previously closed
Fix: No error if opcode with immediate addressing and late evaluation was out of bounds
Add: Additional output of start address and size after successful compile
Add: Changed tab support to also work without TabsAllowed enabled
Fix: Removed "apply functionality" in tool settings
Add: Portable mode (has to be chosen once in settings dialog)
Link wie gehabt: http://www.georg-rottensteiner.de/files/C64StudioRelease.zip
