SwinSID ATMEGA88
Es gibt 519 Antworten in diesem Thema, welches 261.848 mal aufgerufen wurde. Der letzte Beitrag (12. April 2024 um 15:26) ist von 1570.
  • I used this Fuse settings:
    Low = 0xF0
    High = 0xDF
    Ext = 0xF9
    from this Post from kinzi ... Bitte melde dich an, um diesen Link zu sehen.
    ...and this is the Firmware I used: Bitte melde dich an, um diesen Anhang zu sehen.
  • Die Posts von Snocksman habe ich auf seinen Wunsch in einen anderen Thread exportiert:
  • FInaly the parts arrived, assembled ....
    But have no picture when I plug it in ....
    Used the no patch firmware, set fuses
    Low = 0xF0
    High = 0xDF
    Ext = 0xF9
    THe led on borad is ON, have a noisy sound on power up, but no pic ....
    HAve an 8580 in my C64 so I jumpered J2 only ...
    Advices
  • HiResPic of the populated SID? Maybe ab short on the adress or databus.
  • Tryed with 1 SID from kinzi and this one works with same firmware, and same fuse settings ...
    Even the 4 SID from kinzi works (at lease I have a pic) but without sound, don't know where should the wires from J3 and J1 go ....
  • Just connect VCC, GND and AUDIO_OUT.
    Flash a firmware with "power on ping".
    Listen if it pings at power up.
    If it doesn't, something is wrong with it.
    Changing the osc to a 20 MHz one might give a hint.
    The have been reportings here that newer lots of ATmega88s do not like overclocking to 32 MHz.
  • Nope, even don't work with 25Mhz ...
    DOn't have any lower OSC ...
    I have to admit that when I turn the C64 on, I have a noise sound all the time, but still no pic ...
    kinzi Could you please guide me how to try to connect the 4 SID board
  • See Readme ...
    • Plug into SID socket.
    • Connect Address Lines according to desired address ranges:
      Use A5 and A8 if you have no special desires. This will lead to 4 SIDs at D400, D420, D500, D520.
    • If you wanna route Audio thru the 64, jumper all four SIDs to "L" audio channel (J4, J5, J6, J7) and close "onbd" Jumper.
  • OK; I have found the A5 and A8 on the CPU, connected them with fast pin headers ...
    But still don't have any sound ....
    All 4 SID's put to L, and the onboard jumper is set on ...
    DO I have to get a sound even if I don't connect the A5 and A8 ????
  • DO I have to get a sound even if I don't connect the A5 and A8 ????
    Yes.
    Instead of connecting address bus pins, you can pulk the address input pins to GND. This wil permanently select the first SwinSID:
  • 74HC138 is not the right part. It may or may not be your problem, though. You should use LS, or maybe HCT.
    Also, I am not sure what an ATMEGA88PA-U is... I've seen PA-PU and they work. You could just have fake or wrong chips?
    However, no picture? You have some other wiring issue here, I would think. Try it with no ATMEGAs in the sockets.
    Peter Rittwage
    C64 Preservation Project
    NIBTools
    3 Mal editiert, zuletzt von r.cade (16. März 2024 um 18:48)
  • Changed the 138 from HC to LS ... still nothing ...
    Strange that the single SID works, but this 4 SID not, even not on single chanel ...
    Can the nanoSID be programmed per fuse to set the internal OSC ??? AND SHOULD IT WORK ???
  • You double check your resistor values and placement?
    Peter Rittwage
    NIBTools
  • Depends on your device, it seems ...
    Max clock frequency for the ATmega88PA according to this datasheet is 16 MHz.
    Page 270, 321
    Max clock frequency for the ATmega88PA according to this datasheet is 20 MHz.
    Page 312, 631
    ATmega88PA-U is totally unknown to the datasheets (missing case designating character after the dash).
