First of all, sorry for my English. And unfortunately I don't speak German.
I'm planning to build a two-card SD2IEC, but I can't build devices using SMD parts - so I'm going to design another board for it, using, if possible, only one layer (I'll figure it out if I have a schematic). I have some questions about designing it:
1. As I look to a Shadowolf's schematic here: http://www.pitsch.de/stuff/mmc2iec/index.htm#A11 there's a resistor R13 between PB2 and PA0 (IEC_ATN). According to 1.9 firmware config file, PB2 is an interrupt pin used by SD2 presence detect. Should this resistor be removed?
2. There's a way to connect a PCF8563 RTC to I2C, as I think to mark file dates properly. Are there any schematics showing how to connect this?
When RTC is powered up from circuit's power supply, it's OK, but after the power is turned off, RTC will loose its data. Will it be enough to connect CR2032 battery to RTC's Vcc thru 2 diodes (to avoid Vcc "charging" not rechargeable battery)?
3. Are there any pins/pins+small logic on the SD card socket, which can blink LED when the card is in use?
4. I'm going to build it on small boards to fit it easily in some old modem case). How long uC-SD cable can be, to not worry about interferences?
5. Should the IEC leads for Shadowolf's board be connected to two IEC connectors (like inside 1541)?
Thanks in advance
MCbx
