Hello, Guest the thread was called1.5k times and contains 1 replay
last post from MIRKOSOFT at the
USB FDD for 64HDD-PC
  • Hi!
    I'm user of 64HDD Professional. I have for this one MS-DOS (7.10) computer.
    I'm trying to use USB 3,5" FDD on this... Why 64HDD category? It's 64HDD computer.
    What's my problem:
    I added to config.sys driver usbaspi1.sys for detecting USB devices.
    At starting computer is FDD found, but after are two errors:
    ERROR: TARGET DEVICE NOT FOUND
    ERROR: DRIVER RESIDES SINCE USB FDD WAS DETECTED
    ...and I was trying more PC-DOS forums, but everywhere is writting only about USB CDROM etc.
    Can anybody help me which driver and how to install it for USB FDD as drive B: ?
    Thank you for every answer.
    Miro
  • Here's solution:
    Add this line to config.sys:
    device=c:\dos\usbaspi1.sys /v /u
    I selected UHCI 'cause my DOS computer has only USB1.1,
    if you have USB other version, here are parameters to replace /u:
    /E (EHCI USB 2.0)
    /O (OHCI USB 1.1 Add-on)
    /U (UHCI USB 1.1 Integrated)
    ignore errors:
    Please note that main floppy in computer marked as A: will be replaced with USB FDD, so will be not accessible.
    I tried not to set this drive to B: - don't know how, can anybody help me?
    Miro
