Hello, Guest the thread was viewed8.1k times and contains 0 replies
last post from atarianer at the
Die Chip-Nummern und was dahinter steckt...
  • Atari ST - Chips - 260/520/1040/MEGA ST (alle außer STE)
    C100110-001 = DMA (IMP)
    C070714-001 = GLUE (IMP)
    C100109-001 = MMU (IMP)
    C170713-002 = Shifter (IMP)
    C101643-011 = BLITTER
    C025915-xx = GLUE
    C101602-38 = GLUE (80pol. SMD)
    C025912-xx = MMU
    C101601-38 = MMU (80pol. SMD)
    C025913-20 = DMA (Ur-Version)
    C025913-38 / -38A = DMA
    C025914-38 / -38A = Shifter
    S8818 - 9151 = BLITTER (Code)
    YM2149F = Soundchip
    C101625 = PAL-IC für Uhr (nur Mega ST)
    C101622 = RTC RP5C15
    C100117 = MC1377 RGB-TO-PAL/NTSC-Konverter (nur STFM)
    68901 = MFP (48pol. DIL)
    MC6850 = ACIA
    EF6850P = ACIA
    SCN68000 = 68000/8 Keramikgehäuse
    MC68000P8 = 68000/8 Kunststoffgehäuse
    MC68000G10 = 68000/10 Kunststoffgehäuse
    SCN68000C8N64 = 68000/8 Kunststoffgehäuse
    ST68000 = 68000/8 Kunststoffgehäuse
    WD1772-PH00-00 = 1772 Floppycontroller DD-fähig
    WD1772-PH00-02 = 1772 Floppycontroller DD-fähig
    WD1772-PH02-02 = 1772 Floppycontroller DD-fähig
    VL1772-02PC = 1772 Floppycontroller DD-fähig
    C026028 = 1772 Floppycontroller
    C070122-001 = 6301 Keyboard-CPU (1. Version bis Nov. 85)
    C070122-002 = 6301 Keyboard-CPU
    Atari ST - Chips - STACY
    C025915-38 / -38A = GLUE
    C025912-38 / -38A = MMU
    YM2149 = 2149 Soundchip
    TC552557BPL-10 = LCD VRAM-Chip
    C101775-001 = LCD Shadow Videochip
    C10366-001 = PAL Chip für Uhr
    RP5C15 = RTC
    68901 = MFP
    HD6350 = ACIA
    HD6301V = 6301 Keyboard-CPU
    MC68HC000P8 = 68000/8 Kunststoffgehäuse
    Atari ST - Chips - ST BOOK
    68HC000-8 = 68000/8 PLCC
    C398789-001 = DMA (PLCC)
    YM3439 = 3439 Soundchip (SMD)
    6350 = ACIA
    68HC901 = MFP (PLCC)
    C302183 = Kombichip (GLUE, MMU, BLITTER)
    27C4096 = 4MBit OTPROM TOS2.06
    MAX241 = unbekannt
    C104531-001 = unbekannt
    Atari ST - Chips - 520/1040 STE
    C398739-001 = DMA
    C025983 = 2149 Soundchip
    C025984 = 68901 MFP
    MK68901N-04 = 68901 MFP
    C025985 = 6850 ACIA
    C026028-002 = 1772 Floppycontroller
    C101643 = BLITTER
    C300588-001 = STE-Shifter 84pol.
    C398057-001 = DAC0802
    C398058-001 = DMA-Soundchip
    C398057 = DAC0802 / DAC0800
    C100117 = 1377 RGB-TO-PAL/NTSC-Konverter
    C300589-001 = GSTMCU (GLUE/MMU)
    C398739-001A = DMA (1040STE) DIL
    C398789-001 = DMA PLCC
    C301712-001 = GST-Shifter
    MC6850 = ACIA
    ST6850 = ACIA
    EF6850P = ACIA
    C302434-001A = AJAX Floppycontroller DD/HD/ED-fähig
    Atari ST - Chips - MEGA STE
    C302017-001 = SRAM 8K+8 85ns (HM6265L-70)
    C301846-001 = CTRAM 8K*8 35ns (MK48S74N-25)
    C398778-001 = 68000/16 PLCC
    C101718-001 = 68881/16 PLCC
    C301705-001 = GLUE
    C301899-001 = PAL16R4
    C301901-001 = PAL20L8
    C301903-001 = PAL18L8
    C301904-001 = GAL22V10
    C301905-001 = PAL16L8
    C301906-001 = GAL22V10
    C301907-001 = PAL16R4B
    C301908-001 = PAL16L8A
    C301909-001 = GAL22V10
    C398106-001 = 68901 MFP
    C398109-001 = 8530 SCC 10 MHz
    C301898-001 = GAL22V10
    C398739-001A = DMA (DIL)
    C301903-001 = PAL18L8 für 68881
    C101643 = BLITTER
    C300569-001 = GSTMCU / ext. BLITTER
    C302183-001 = Kombichip (MMU/GLUE/BLITTER)
    C301224-001 = TT-SCU
    C300588-001 = GST-Shifter ohne DMA/Sound-Probleme S9018AX
    68901 MFP = 68901 MFP 44pol. PLCC
    ST68B50 = 6850 ACIA B-Version
    MC68B50 = 6850 ACIA B-Version
    Z8530 = 8530 SCC
    MC68000FN12 = 68000/12 Kunststoffgehäuse 16MHz-geprüft
    ST68000 = 68000/16 Kunststoffgehäuse
    C302096-001A = AJAX Floppycontroller DD/HD/ED-fähig (Toshiba)
    C302434-001A = AJAX Floppycontroller DD/HD/ED-fähig (National)
    C302096-001 = AJAX Floppycontroller DD/HD/ED-fähig
    C103705-001 = GAL-ACSI
    C103706-001 = GAL-SCSI
    Atari TT - Chips - TT030
    C301838-001 = PAL16R4-7PC
    C301837-001 = PAL16L8-7PC
    C398721-001 = PAL $198B
    C398722-001 = PAL $22AC
    C300869-001 = MMU
    C300580-001 = Funnelchip
    C300579-001 = Soundshifter
    C301224-001 = GLUE (SCU)
    C301705-001 = GLUE (SCU) - Daughterboard-Version
    C301706-001 = DCU - Daughterboard-Version
    C301707-001A = Funnelchip - Daughterboard-Version
    C301223-001A = DMA - Daughterboard-Version
    C301708-001A = Soundshifter - Daughterboard-Version
    C301225-001A = MMU (2MB ST-RAM onboard)
    C398080-001 = 8530 SCC / ECL Uhrengenerator
    C398081-001 = 8516 Mono Video Driver
    C101694 = RTC
    C300868-001 = Videochip - Daughterboard-Version
    C398739-001 = DMA (DIL) - 1989
    C398739-001A = DMA (DIL) - 1990
    C398982-001A = TT-Shifter
    68901 MFP = MFP
    MC6850 = ACIA
    ST6850 = ACIA
    C025987 = GD75189 RS232 Receiver
    C025986 = FD75188 RS232 Driver
    C101693 = MC14609
    C398112-030 = 26LS30
    C398112-031 = 26LS31
    C398721-001 = PAL U702
    C398722-001 = PAL U703
    C101694 = RTC
    Z5380 = SCSI-Chip
    Z8530 = SCC
    XC68030 = 68030/32 Keramikgehäuse PGA
    MC68030 = 68030/32 Kunststoffgehäuse PLCC
    MC68882 = 68882/32 Kunststoffgehäuse PLCC
    C302096-001A = AJAX Floppycontroller DD/HD/ED (Toshiba)
    C302434-001A = AJAX Floppycontroller DD/HD/ED (National)
    CA400313 = 2MB ST-RAM Board
    CA401058 = 4MB ST-RAM Board
    CA400312-001 = 4MB ST-RAM Board
    C300869-001 = MMU TT-RAM
    Atari Falcon - Chips - Falcon030
    C103803-001 = LM386 Audio Operationsverstärker
    C302900-001 = LM387
    C302799-022 = 3439 Soundchip
    C302829-001 = VIDEL
    C302995-001 = COMBEL
    C302996-001 = SoundDMA
    C303001-001 = 68030/16
    C303002-001 = DSP 56001
    C303003-001 = CRYSTAL CODEC CS4216-KL EP
    C303004-001 = DSP SRAM 32K*8
    C302830-001 = GAL16V8-12 ECLK
    C302831-001 = GAL16V8-12 UDS/LDS
    C302832-001 = GAL16V8-12 DSACK
    C302833-001 = GAL16V8-12 AS/BG
    C302834-001 = GAL20V8-12 DSP
    C302897-001 = 53C80 SCSI-Chip
    C302824-001 = STV8438 DAC
    27C4096 = PROM 44pol PLCC TOS 4
    TMP27PC240-12FNL = PROM 44pol PLCC TOS 4
    HN27-C4096CC-12 = PROM 44pol PLCC TOS 4
    68901 MFP = MFP
    EF6850P = ACIA
    Z53C80 = SCSI-Chip
    Z8530 = SCC
    MK48T87B-24 = RTC
    MCCS146818BM = RTC
