Hello, Guest the thread was called16k times and contains 80 replays
last post from CapFuture1975 at the
SD2IEC LCD Release V0.2b
  • Moin!
    Ich hab' monentan leider keine Zeit das in einen Stand zu bringen, in dem ich es gerne hätte, deshalb gibt's einfach das aktuelle Paket:
    Click
    Introduction
    SD2IEC LCD 0.2b is my try to extend the SD2IEC/MCC2IEC controllers with a LCD display.
    It is bases heavily on the SD2IEC 0.6.6 firmware by Ingo Korb, who did a great job there!
    Note that i made several modifications of the firmware. Ingo Korb is not responsible for
    any wanted or unwanted features of this firmware version.
    Since this is a slightly unfinished fun project (sorry, not so much spare time at the moment)
    i am publishing it as it is in the hope that it will be useful.
    There's no guarantee that the code works or that the suggested hardware modifications are correct.
    Use it on your own risk!
    Additional Features
    * Based on the SD2IEC Firmware V0.6.6 by Ingo Korb
    * Runs on Atmel ATMEGA32 MCU. Should run on ATMEGA644P MCU too (not yet tested).
    * Display various information like
    - current path (D:<path>)
    - current D64 image (D:<Image.d64>)
    - file access (L/S/R:<file>)
    - error messages (E:<message>)
    - user defined messages
    - and a nice boot screen (-;
    * Support HD 44780 compatible displays (2x16 or 2x20 chars)
    Removed Features
    I fitted in the LCD routines at the price of:
    - No debug code (UART output)
    - No bootloader support on ATMEGA32 (sorry, not enough space)
    Additional Commands available via IEC
    XT* Text Commands
    The display can be accessed from the c64!
    Use commands "XT1" and "XT2" to send text to display line 1 or 2.
    The addressed line will be cleared before text is printed.
    Example 1 - send "Lightyears ahead!" to line1:
    OPEN15,8,15,"XT1Lightyears ahead!"
    The "XTC" command allows to send a control code followed by data, which makes it possible
    to program the display from the C64 side, e.g. define own characters.
    Example2 - clear the screen:
    OPEN15,8,15,"XTC"+CHR$(1) will clear the screen.
    Example 3 - define a special character with a "heart" (line 2) and print it 3 times (line 3):
    1 OPEN15,8,15
    2 PRINT#15,"XTC"+CHR$(64)+CHR$(27)+CHR$(31)+CHR$(31)+CHR$(14)+CHR$(4)+CHR$(0)+CHR$(0)
    3 print#15,"XT1"+CHR$(8)+CHR$(8)+CHR$(8)
    4 CLOSE15
    Display About Message
    The XA command shows a small about message:
    Example:
    OPEN15,8,15,"XA"
    Display Greetings & Credits
    The XG command shows the greetings and credits:
    Example:
    OPEN15,8,15,"XG"
    Undocumented experimental feature
    The XX command is not documented. It might cause skynet to
    link all computers together to play a game of global
    thermonuclear war.
    Maybe your C64 is not connected to skynet, so you'll give it a try.
    Good luck!
    Example:
    OPEN15,8,15,"XX"
    LCD Hardware
    Every HD 44780 compatible displays (2x16 or 2x20 chars) should work
    The display is accessed in 4-bit mode.
    Different pinouts have to be used depending on the hardware variant
    of the SD2IEC / MMC2IEC device:
    sd2iec V1.4 by Shadowolf (sw1 variant)
    MMC2IEC by Lars Pontoppidan (larsp variant)
    (original design, also used by PCBs from Peter Sieg)
    Display Atmega
    RS PB0
    RW PB1
    E PB2
    DB4 PA4
    DB5 PA5
    DB6 PA6
    DB7 PA7
    sd2iec V1.6 by Shadowolf (sw2 variant)
    ATTENTION: I have not yet tested this pinout so it might be possible that it is not working.
    At least it will be hard to solder the display to PB0,PB1 and PB3 if using a TQFP44 mcu.
    Display Atmega
    RS PB0
    RW PB1
    E PB3
    DB4 PC4
    DB5 PC5
    DB6 PC6
    DB7 PC7
    For other variants please feel encouraged to change the lcd.h to suit your needs.
    Credits
    Ingo Korb alias for his great SD2IEC firmware.
    Shadowolf for his outstanding hardware designs running the SD2IEC firmware.
    Lars Pontoppidan for creating the MMC2IEC in the first place.
    Jim Brain & ChaN for basic code like IEC routines and FAT driver.
    Commodore for the good times.
    Licence
    This program is free software; you can redistribute it and/or modify
    it under the terms of the GNU General Public License as published by
    the Free Software Foundation; version 2 of the License only.
    This program is distributed in the hope that it will be useful,
    but WITHOUT ANY WARRANTY; without even the implied warranty of
    MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
    GNU General Public License for more details.
    You should have received a copy of the GNU General Public License
    along with this program; if not, write to the Free Software
    Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA
  • I fitted in the LCD routines at the price of:
    ist das alles was rausgeflogen ist ja?
    also müsste ich den atmega 32 per ISP programmieren?
    ansonsten nit schlecht :D
    wäre nur froh wenn die bootloaderfunktion wieder drinne wäre zum preis von was anderem.
  • Nachdem das auf einem Atmega32 (mmc2iec 1.6) beruht müsste doch im 644er (sd2iec 1.2) Platz für die Ansteuerung und für den Bootloader frei sein, oder?
    Die Frage ist halt, ob man als Nicht-Löter auch an die notwendigen Pins am Atmega kommt ohne das sd2iec gleich ins Nirvana zu befördern! :roll:
    Also ich wär da noch immer sehr an einer Lösung mit Display interessiert....
    znarF
  • Musste das CBM-Logo und den "XX"-Befehl vorerst wieder rausnehmen, weil sonst zur Laufzeit der wertvolle Speicher zu knapp wird.
    Hier also die aktualisierten Sourcen Sources
    Und das aktualisierte Image für Larsp-hardware: Firmware
    Sowas legt man ja auch nicht im RAM sondern im Flash ab. =) Wie das geht kannst du dir zB in errormsg.c anschauen, die Fehlermeldungen liegen auch nur im Flash.
  • Sowas legt man ja auch nicht im RAM sondern im Flash ab. =) Wie das geht kannst du dir zB in errormsg.c anschauen, die Fehlermeldungen liegen auch nur im Flash.
    Yep, da hast Du wohl Recht. Danke für den Tip! Schmerzliche Erfahrung, dass für die 64 Bytes Logo kein Platz mehr im RAM war...
  • Hmm, wär das nicht mit dem NKC-sd2iec leicht(er) zu realisieren? Bisher hatte ich ja schon das Problem, das ich nicht an die benötigten Pins vom Atmega ran komme. Mit dem Teil von NKC wäre die o.a. Pins über eine Stiftleiste zu erreichen.
    Und nun die Frage an die Amega Profis: Wie hoch schätzt ihr den Aufwand die Ansteuerung eines LCD Displays in die aktuelle 0.8er FW zu bekommen?
    lg,
    znarF
  • Die weiter oben beschriebenen Funktionen in den Code einzubauen dauert eine Stunde (ich weiß es, denn ich hab' das eben gemacht).
    Hinzu kommen einige Stunden für Tests, Doku, Uploads und Diskussionen im Forum (-;
  • Die schönere Lösung wäre es, das Display über einen Tiny2313 anzuschliessen. Der Atmega des SD2IEC versorgt den Tiny über I2C oder UART.
    Hmm, ist das dann ein Mehraufwand das in die Firmware von Unseen einzupflegen? Denn Tiny2313 würde es sogar als Dip-20 geben und mit 1,30 wär der gar nicht mal so teuer. Das Display ist da schon etwas teurer, kostet doch das günstigste Ding bei Reichelt 17,15 aber da wirds sicherlich auch günstigere geben.
    znarF
  • Ich kaufe Displays mit 24 Zeichen 2 Zeilen um 5€: klick
    Der Tiny könnte sich um Display und evt. um Tastatur kümmern. Das ganze Modul würde nur 2 Pin des SD2IEC benötigen. Wenn man I2C nimmt, dann sind die eh schon für die Echtzeituhr verwendet, der Tiny könnte quasi zusätzlich zur Echtzeituhr drauf hängen.
  • Ich habe mir ein paar sehr schöne seriell ansteuerbare VFDs für kleines Geld sichern können:
    forum64.de/wcf/index.php?attachment/18234/
    Jetzt braucht's nur noch ein schönes Gehäuse....
  • Ich biete demjenigen, der die o.a. Vorschläge mit Tiny2123 und einem Standart Display zum laufen bekommt, einen nagelneuen Double Layer SATA Brenner als Bounty.
    Voraussetzung:
    Unseen muss aber das ganze als Patch in die bestehende Firmware einpflegen können und somit absegnen!
    Es sollte sowohl mit Shadowolf´s sd2iec 1.2 als auch mit dem sd2iec von NKC funktionieren. Vielleicht kann uns Shadowolf ja eine kleine Platine dazu zaubern! :winke: (dann gibts für ihn dasselbe Bounty!)
    lg,
    znarF
  • Unseen muss aber das ganze als Patch in die bestehende Firmware einpflegen können und somit absegnen!
    Ok, keiner bekommt die Bounty. =) Oder gibts schon Flaggen-Displays? (Standarte)
    Ich habe hier schon seit einiger Zeit die Hardware zusammengesteckt um eine eigene Displaylösung zu implementieren, aber die wird mit einem 2313 auf Displayseite nicht auskommen wenn ich die Menüs so implementiere (resourcensparend auf sd2iec-Seite) wie es mir vorschwebt. Wird aber noch dauern bis da was fertig wird...
  • Ich habe diesen, im angehängten Textfile enthaltenen, Traum von einem Display für AVR-basierende-Drives. Er hat leider einen 28-Pin-MEGA88 statt eines 18-Pin-TINY2313. Ich habe dies nur im Kopf geplant und absolut keine Experimentierschaltung dazu erstellt, sodass ich über die Realisierbarkeit absolut nichts sagen kann. Wenn es ginge, hätte er: 6 Taster, 4 LEDs, die Fähigkeit, den Haupt-AVR resetten zu können und eine Echtzeituhr. Er sollte über den I2C-Bus mit dem Haupt-AVR verbunden werden. Dies hätte den Vorteil, dass man eine PCF8583-RTC gleichzeitig anschließen könnte, falls die MEAG88-RTC doch zuviel Strom verbrauchen würde oder Ticks verliert oder falls einem die Batterie zu groß ist.
    Ich weiss, dass ich mich mit diesem Vorschlag weit vorwage. Es ist nur so eine Idee, über die man diskutieren kann, aber nicht muss. Wenn die Idee schlecht ist, dann reagiert einfach nicht darauf. Ich bitte um Entschuldigung, falls ich mich in etwas eingemischt habe, das mich nichts angeht.
    Wo ist denn da der entscheidende Vorteil?
    Bis jetzt sehe ich bei dieser Lösung nur Nachteile. Ein Kabel kann man ohne weiteres eben auf eine bestehende Schaltung auflöten, aber den ATtiny dann noch frei fliegend irgendwo einzuhängen finde ich nicht so schön. Dann will der extra Chip natürlich auch noch geflasht werden und man hat eine weitere Fehlerquelle, da man nicht nur eine Firmware zu aktualisieren und zu flashen hat, sondern derer zwei. Zwei mal Fuses setzen (oder zerschiessen) etc.
    Am ATmega sind doch genügend Anschlüsse für das Display frei. Und Taster sind ja ohnehin schon implementiert.
    Klärt mich mal auf...
