Need help with wav plugin to MMC Replay.
Es gibt 2 Antworten in diesem Thema, welches 1.114 mal aufgerufen wurde. Der letzte Beitrag (11. Dezember 2008 um 11:48) ist von sauhund.
  • I have a working wav file to my mmc replay, and i works but the problem is that the wav plays to fast, can i slowdown the plugin or the wav? please help me Thanks.
  • hello
    there are 2 different wav plugins. first 4 bit, unsigned data, 44.1 kHz, Mono.second 8 bit, unsigned data, 22.05 kHz, Mono. you have to convert the wave exactly for the plugin. use only 1 plugin in the system64 not both.
    it will work fine.:bia
    master64
  • you can use both plugins by renaming one of them to wavplgin.alt (and then run it by holding shift when pressing return)
