dtvtrans 1.0 + full source
Es gibt 3 Antworten in diesem Thema, welches 2.150 mal aufgerufen wurde. Der letzte Beitrag (18. Februar 2008 um 23:34) ist von tlr.
  • dtvtrans is a PC <-> C64DTV V2/V3 transfer solution.
    It uses a cable connected between the parallel port of the PC and a joystick port on the C64DTV. (port 1, port 2 and the user port supported)
    The transfer speed is roughly 15 Kbyte/s PC -> DTV and 13 KByte/s DTV -> PC.
    Used with Lallafa's dtv2ser+usb hardware it is roughly 17 KByte/s PC -> DTV and 19 KByte/s DTV -> PC.
    Changes since 0.6:
    • [PC] Applied a patch to fix possible problems using dtvtrans rd on GNU/Linux systems (contributed by Hannu Nuotio)
    • [PC] Support for auto reset of the DTV.
    • [PC] sys is now a synonym for go.
    • [PC] chaining of commands (separated by '+' signs) supported. This idea was taken directly from lallafa's dtv2ser[+usb] software.
    • [PC] implemented a sleep command as in lallafa's dtv2ser[+usb] software.
    • [DTV] hardcoded video timings for PAL. Corrected timings for NTSC.
    • [DTV] support for auto reset. Works automatically with the cable plugged into joy2. (dtvmon/dtvboot works with all ports)
    • [DTV] significantly improved speed due to heavy burst optimizations of the transfer code.
      - measured with Lallafa's dtv2ser+usb hardware + software 0.3
      dtvtrans 1.0: write=16.85 KByte/s, read=18.47 KByte/s
      - measured with Lallafa's dtv2ser+usb hardware + software 0.2
      dtvtrans 1.0: write=12.98 KByte/s, read=19.10 KByte/s
      dtvtrans 0.6: write=9.18 KByte/s, read=13.25 KByte/s
      - measured with dtvtrans on a Linux box
      dtvtrans 1.0: write=15.5 KByte/s, read=13.6 KByte/s
      dtvtrans 0.6: write=9.84 KByte/s, read=8.29 KByte/s
      dtvmon 1.2: write=15.4 KByte/s, read=13.4 KByte/s
      dtvmon 1.1 rom beta: write=6.61 KByte/s, read=6.12 KByte/s
    • [DTV] Switchable guaranteed setup timing for DTV -> PC communication. (gets rid of an ugly 5us delay on the PC side, providing improved transfer speeds on many systems)
    • [DTV] An RTS in a program called using go/sys returns to the server
    • [DTV] go/sys can set registers and wait for the result.
    • [DTV] Address of the dtvtrans code in memory is selectable (by bank). If not $018000, a reset trap will be installed at $018000 that jumps to the installed location.
    • [PC] Added 'load'. Does a BASIC load.
    • [PC] Added 'save'. Does a BASIC save.
    • [PC] Added 'run'. Does a BASIC run.
    • [PC] Added 'init'. Does a BASIC init.
    • [PC] Added 'exit'. Does a BASIC exit.
    • [PC] Added 'verify'.
    • [PC] Added 'info'. Queries information about the server.
    • [PC] Added switches to 'reset'. The default is to automatically do a full BASIC init.
    • [PC] Switched to Mingw32/MSYS on Windows.
    • [PC] Source code modified for easier addition of new backends.
    • [PC] Much better error handling.
    • [PC] files with an extension of .bin or .raw are automatically assumed to be in raw format. The global option '-l' will override this. (suggested by lallafa)
    • Added cable schematics. (cable-schematics.png)
    • Added protocol documentation (PROTOCOL.txt)
    • Many useful additions to the protocol.
    Download: Bitte melde dich an, um diesen Link zu sehen. (Bitte melde dich an, um diesen Link zu sehen., Bitte melde dich an, um diesen Link zu sehen.)
  • tlr :
    Is the protocol between the different versions of dtvtrans PC and DTV software compatible ?
    More concret : can I use new dtvtrans software on PC with old dtvmon on DTV installed ?
  • tlr :
    Yes, the protocol is fully backwards compatible.
    You can even use old dtvtrans software on the PC with dtvtrans-1.0 on the DTV.
    For the new PC client there is also a switch to force the old pre 1.0 protocol in case there would be any problems.
    EDIT: but many new of the new features will be unavailable if using an old DTV implementation ofcourse.
  • There was an unfortunate problem with the PC client side of dtvtrans-1.0 as reported by peiselulli.
    The behaviour of dtvtrans wr <file> defaulted to dtvtrans load, which was not very close to the dtvtrans-0.6 behaviour and caused problems in some cases.
    This has been fixed now. (the DTV side programs have not changed)
    Please re-download the archive to get the fixed version.
    Yes, I know it is ugly to update the archive. ;)
