WinUAE 1.4.2 ist raus !
Es gibt 6 Antworten in diesem Thema, welches 3.055 mal aufgerufen wurde. Der letzte Beitrag (15. Mai 2007 um 03:34) ist von FXXS.
  • WinUAE 1.4.2 (12.05.2007)
    New features:
    - "Windowed fullscreen" for users with multiple monitors, fullscreen
    Amiga on secondary monitor, Windows on primary monitor, no more lost
    fullscreen when focus changes to Windows program.
    - A600/A1200 and A4000 IDE harddrive (HDF) hardware emulation, includes
    also "4-Way IDE" / "IDE splitter" emulation.
    - Directory, HDF, IDE and Picasso96 statefile support. WARNING: data loss
    possible if data in HDF has changed between saving and restoring!
    Picasso96 statefile support not 100% compatible yet.
    - 68030 and 68060 (with FPU. 68060.library required) emulation. (no MMU)
    - 68881/68882 FPU type selectable.
    - Global brightness, contrast and gamma adjustment.
    - "PAL" TV-like filter, with brightness, contrast, gamma, scanline level,
    blur and noise adjustment.
    - GUI debugger, debugger improvements. (xx switches debugger modes)
    - New GUI font if running under Windows 2000/XP/Vista.
    - Interpolation and filters supported in 4/6 channel sound modes.
    - Log and debugger console position stored in registry.
    Bugs fixed:
    - Improved CDTV emulation compatibility.
    - 1.4.0 FPU clamping fix.
    - Missing channels in 4 channel sound mode. (Emu10K based cards)
    - 10x+ performance increase during "decrunching" color effects when
    no filters enabled and only background color was visible.
    - Crash when loading config and specific chipset extra model was selected.
    - Direct HD support improved, SyQuest removable drives detected properly.
    - Minor custom chipset emulation updates.
    - Rare emulator crash when running Amiga program crashed badly.
    - Filter centering improved.
    WinUAE 1.4.2a update will be released later today.
    Following major bugs found:
    - Path handling defaults to wrong path
    - Windows 98SE (and ME?) incompatibility
    DL: Bitte melde dich an, um diesen Link zu sehen.
    YESS !!! :D :D :D
  • Zitat
    Original von HOL2001
    Schön, daß das auch mal geht. Da bin ich erst vor kurzem fast dran verzweifelt... :schreck!:
  • Das ja genial!
    Fullscreen auf zweitem Monitor/TV-out war schon immer mein Ding. :juhu:
    Avatar: Bitte melde dich an, um diesen Link zu sehen. Foto von Bitte melde dich an, um diesen Link zu sehen. Lizenziert unter CC BY 3.0 über Wikimedia Commons. Bitte melde dich an, um diesen Link zu sehen.
  • Zitat
    - Windows 98SE incompatibility
    Schade, bleib ich halt bei der alten Version....
    ( XP würde meinen zweitrechner zu sehr beschäftigen... der ist aber der "Hauptemulator" *g* )
    sl FXXS
  • Zitat
    Original von FXXS
    sl FXXS
    Gute Neuigkeiten für dich: :D
    WinUAE 1.4.2a (13.05.2007)
    Bugs fixed:
    - Path handling problems fixed. If you still have problems with paths,
    select Paths-panel "WinUAE default (old)" and click "Reset to defaults"
    and then manually adjust paths if needed.
    - Windows 98SE (and ME?) incompatibility.
