Problem with SOUND noise waveform
There are 5 replies in this Thread which has previously been viewed 632 times. The latest Post (January 15, 2025 at 1:19 PM) was by SkulleateR.
  • If i type SOUND 2,800,50,,,,3 it makes 1 second of noise.
    However if i use it in a programm i have the following problem :
    100 SOUND 2,800,50,,,,3 : REM start noise flameshot
    200 IF H=1 THEN SOUND 2,0,0 : REM stop noise if something is hit.
    When i powercycle my M65 and start the programm line 100 does nothing the first few calls.
    All other SOUND commands work first call. (other wavweforms)
    IF i END and restart the programm it works at first call as long i don´t powercycle.
    What i am doing wrong ?
    Do i have to init the noise generator ?
    100 % echte Dummheit
    Keine künstliche Intelligenz involviert.
  • It seems to be the same problem.
    I tried a workaround.
    10 VOL 0
    20 FOR I=1 to 10
    30 SOUND 2,800,50,,,,3
    40 NEXT
    50 VOL 10
    It worked the first time after powercycle.
    Second start the VOL 0 doesn´t work
    I can live with it, since it doesn´t seem to be my fault.
    This is for the core and ROM developers..
  • This is for the core and ROM developers..
    It seems that the core problem was fixed: :gruebel
    Please login to see this link. (from September 1, 2024):
    Quote
    bubbob42 Is this fixed?
    With a recent development core and SID 8580 the SOUND command plays the sound every time for me.
  • I switched to 6581 and it works now.
    Or just try the C65/MEGA65 Kernal ROM - Beta (920409 right now) ;)
