WinUAE 1.4.0 released !
Es gibt 2 Antworten in diesem Thema, welches 2.594 mal aufgerufen wurde. Der letzte Beitrag (19. März 2007 um 20:01) ist von Sensei.
  • WinUAE 1.4.0 (03.03.2007)
    New features:
    - CDTV emulation, including CD controller, internal SRAM and 64KB SRAM
    expansion memory card support.
    - More compatible SPTI CD32/CDTV CD support.
    - Advanced Chipset configuration. Miscellaneous model specific
    hardware configuration entries like real time clock chip type, CIA-A
    TOD clock source, RAMSEY, FAT GARY register emulation..
    - Rewritten harddisk configuration system. No more lost hardfile or
    virtual directory configuration entries if path was missing..
    - A3000/A4000 motherboard RAM bank support.
    - Added Arcadia bios rom type selection.
    - New Windows Vista -style application icon added
    - Small CIA and custom chip emulation updates.
    Bugs fixed:
    - FPU emulation floating point to integer conversion fixed
    (proper clamping instead of truncating)
    - uaeserial.device compatibility improved
    - New serial port detection didn't detect all types of serial ports
    - Random sound errors after adjusting sound GUI setting on the fly
    - Directory filesystem memory leaks fixed and compatibility improved
    - It was not possible to disable keyboard layout C after enabling it.
    - Sound panel settings were not always enabled correctly.
    - -datapath command line parameter didn't work.
    - Disk image drag and drop didn't work.
    - Quickstart panel disk swapping is properly delayed again.
    - Some Picasso96 display modes were not available.
    - bsdsocket freeze fix (Aminetradio)
    - Windows driver Catweasel support works again.
    - "Faster RTG"-mode lockups fixed.
    - External drive sound selection GUI didn't work if fdrawcmd.sys
    was not installed.
    DL: Bitte melde dich an, um diesen Link zu sehen.
    Jaaaa ! :freude
  • Hallo habe ein kleines problem mit winuae version 1.4.0 ich spiele zu zeit ambermoon bin in der elfen stat kann aber diesen rätsel mund nicht sagen nähnadel weil ich einfach kein ä schreiben kann :encolere20:
  • Tach leute hats sich erledigt lach an der workbench 3.1 hatte keine deutsche tastatur config drin gehabt aber jetzt gehts prima :party:
