CC65, VBCC: Graphics
There are 6 replies in this Thread which has previously been viewed 1,469 times. The latest Post (June 28, 2024 at 7:53 PM) was by rorodev.
  • Hello, everyone. I also finally got my Mega65 this week 🙂
    The next step is to create a simple game using C. I knew CC65 already, so I set this up first on my M2 Mac, but I also tried VBCC. They work fine for text-based stuff, and I've created some simple games.
    My question is: Has someone already created some more complex things in C using DMA (Sprites, Lines)?
    Are there some samples around showing this? Or even a library? I try not to reinvent the wheel, but if nothing is there, I would start with that at first. It would be great to get some hints from your long-term Mega65 devs.
    Thanks best!
  • According to the Please login to see this link., the Mega65 is not yet officially supported by CC65.
    However, I find Please login to see this link. that seems to add that support to CC65 to a certain extent.
    I didn't try programming the Mega65 with CC65 yet. I took first steps with CC65 and the Commander X16 though. My code for the X16 would be Please login to see this link. (runs in an emulator). I didn't get very far though. Graphics programming seems to be very system-specific, so probably my code couldn't be ported to the Mega65 easily. Maybe the general principles and the data could be transferred though.
    Thank you! I already done some stuff on the Mega65, so everthing text based works fine. But all the CC65 examples are not using line drawing or sprites. I got in the meantime another game source that sounds promising as a starting point. Anyway thanks a lot for the feedback.
    Btw. I have also a Commander X16 here, but not started on that yet, too many other projects already on the plate :)
  • Are you aware of mega65-libc and its documentation? Please login to see this link.
    Other than that, I would recommend joining the Discord. Unfortunately the programming gurus are all hanging out there and not in this forum.
    Yes I also registered there and got at least one very useful example :thumbsup:
