AROS ONE x86 (2.1) - Deutsche Tastaturbelegung?
Es gibt 57 Antworten in diesem Thema, welches 8.298 mal aufgerufen wurde. Der letzte Beitrag (16. August 2024 um 18:43) ist von SkulleateR.
  • I encountered a new behavior. Trying to boot Aros 2.2 within Virtalbox it instantly freezes. I have 4+ Gig of RAM and 128 MB Videoram inserted.
    Im Moment des Todes verliert Nationalität völlig seine Bedeutung.
    Ist Sie dann nicht jetzt schon obsolet?!
  • Hello, AROS One should not have these problems, I replied to you arosworld.org, look at my screenshot and possibly try my config that I attached on arosworld.org !
  • I have associated AmiFox with OpenURL requests, a tool used by Amiga/AROS Software to direct you to their site for any updates or news.
    I would say that it is very fast and very practical to download the software, I made a small video showing the functionality of AmiFox !!!
    In the attached video test, the PerCMan software once expired automatically redirects you to its site to get info and download the updated version
    AmiFox: Bitte melde dich an, um diesen Link zu sehen.
  • By Christmas I should be able to distribute the new version 2.3 of AROS One, there are a lot of new features in this release, updated Core, new software and a lot of updated software.
    In addition I have created new configurations and completed the 4 Icon Sets, as always installable through a simple click, there are now almost a thousand of them.
    Among the novelties of AROS One v2.3 there is the presence of 3 new Directories located in "Extras" it's about "Benchmarks", "DemoEffects" and "DemoScene", see screenshot, it's about a lot of very good Demo on RTG screen, many of them came from Amiga world.
    AROS One 2.3, new version of the AROS x86 Distribution ABIv0, in this release there are many new features, Core and Third Party Software updates, in the list you can see in detail all the update
    This is definitely the most stable version of AROS x86 ever released, many fixes concern Wanderer and Hardware compatibility, the hardware compatibility catalogue has also been reformulated, you can consult it Bitte melde dich an, um diesen Link zu sehen.
    For the installation a clean (ex-new) installation is recommended, this is because the Core, configurations and location of some folders have changed, possibly for those who have their own configurations could make a backup and if compatible install them later.
    For the next releases there will be huge changes to the Core which will be based on the latest ABIv11 source code, thus the same C library as the ABIv11 builds.
    AROS One x86 v2.3 ISODVD/ Image USB:
    Download: Bitte melde dich an, um diesen Link zu sehen.
    In addition, an emulator will be developed that will allow 32-bit AROS programmes to run under 64-bit AROS.
    Update AROS One OS System:
    - OpenURL, impostazione default "AmiFox"
    - Dopus4 now uses the XAD library to manage most of the Archives
    - ZuneARC now uses the XAD library to manage most of the Archives
    - Fixed Scrtip 'IconDisk-SMB2' icon replacement package
    - Fix Stack Demos Mesa
    - Create in Extras: Drawers Benchmarks, DemoEffects and DemoScene
    Update AROS One Apps:
    - AGet v1.1, HTTP Protocol Tester (not to be confused with Commando AGet similar WGet)
    - iConecta v5.0, A little and easy program to test your Internet
    - Fract v1.07b, SDL based 3d rendering benchmark.
    - Glmark v0.5.2.1, OpenGL 3D benchmark
    - LCDTest v1.01, (Test Patterns Display LCD Monitor)
    - Tinyul v41.1, Tinybld PIC uploader (e.g. Minimig)
    - AnimWebConverter v6.0.0
    - In addition to PlayCDDA 1.6 also added PlayCDDA v1. 5, this version also works on VMware
    - UnLZX 2.16
    - JoyTest v1.0
    - Videntium Picta v3.0
    - iConecta v5.20
    - Omanko v1.20
    - Font Tester v1.20
    - QLView 25.09 (Sinclair QL Screen viewer)
    - Pintor Web 4.0
    - Image2PDF v2.4
    - Font Tester v1.20
    - HWP APNG v1.3
    - XPDF-GUI v1.1
    - Drawer Benchmarks, Various Demo
    - Drawer DemoEffects,Various Demo
    - Drawer DemoScene, Various Demo
    Update Core ABIv0:
    Functionalities:
    - Extensions to IO-APIC support in Kernel (Kalamatee)
    - Allow ejecting AHCI media (Kalamatee)
    - Initial work on nvme.device (Kalamatee)
    - Added support for message signalled interrupts (Kalamatee)
    - Rework ECAM support in pci.hidd (Kalamatee)
    - Allow forcing AHCI generation via boot parameters (Kalamatee)
    - Processor.resource supports checking availability of AVX, HyperV, AES (Kalamatee)
    - Decrease usage of C standard library functions in AROS libraries (Matthias Rustler)
    - Tool for debugging AROS under HyperV (Kalamatee)
    - Improved SetMem using SSE, implemented SetMem using AVX (Kalamatee)
    - Migrated many keymaps to new format (Kalamatee)
    - Made InstallAROS better at detecting suitable drives (Kalamatee)
    - Initial work on wide character support in C library (Kalamatee)
    - Multiple improvements to copy and delete in Wanderer (Bo Kopperud)
    - Implemented C++ startup objects (Kalamatee)
    - Show disassembly of failing code in Alerts (Kalamatee)
    - Improvements in handling themes and Prefs/Appearance (Kalamatee)
    - Enabled structural unit testing (Kalamatee)
    Updates:
    - AROS build system (Kalamatee)
    - Documentation (Matthias Rustler)
    - BoingIconBar (20230501) (Kalamatee)
    - Ahci.device v0.04 (Kalamatee)
    - Boot/No disk present animation (Kalamatee)
    - SysExplorer v0.13 (Kalamatee)
    - Acpi.library v1.8 (20220331) (Kalamatee)
    - Z library (Kalamatee)
    - Png.library v53.1 (Kalamatee)
    - Jpeg library v9d (Kalamatee)
    - Freetype2.library v6.4 (Kalamatee)
    - Jpeg.datatype v41.1 (Miker)
    - InstallAROS (20230501) (Kalamatee)
    - Wanderer (20230501) (Kalamatee)
    Functional Fixes:
    - AROS Build system (Kalamatee, David Gilmore, Marlon Beijer)
    - Allow loading old-style ELF keymaps (deadwood)
    - Revert to using ISO-8859-2 for polish (deadwood)
    - Muimaster.library (bugs: notifications issues when 'new==old' for certains attributes) (deadwood)
    - Register.mui (bugs: labels don't support escape sequences) (deadwood)
    - InstallAROS (bugs: windows entry not added to grub config) (deadwood)
    - Ahci.device (bugs: wrong total size reported) (Kalamatee)
    - USB (bugs: race condition with input.device) (Kalamatee)
    - Datatypes.library (bugs: ASCII not recognized) (Matthias Rustler)
    - I8042.hidd (bugs: direct use of hardware, lockups on HyperV, log delay on some hardware) (Kalamatee, deadwood)
    - C library (access, execl, vfork, fseek) (Kalamatee, Matthias Rustler)
    - Wav.datatype (Kalamatee)
    - Locale.library (bugs: broken condition in OpenLocale, wrong behavior in FormatString) (Kalamatee)
    - Prefs/Input (bugs: broken condition) (Kalamatee)
    - InstallAROS (improved stack usage) (Kalamatee)
    - Dos.library (bugs: loading of large C++ binaries fail, wrong order when calling MatchFunc) (Kalamatee, deadwood)
    - Hdaudio.audio (Kalamatee)
    - Wanderer (bugs: Bitte melde dich an, um diesen Link zu sehen., Bitte melde dich an, um diesen Link zu sehen., Bitte melde dich an, um diesen Link zu sehen., Bitte melde dich an, um diesen Link zu sehen.) (Matthias Rustler)
    - Prefs/IControl (fixed layout) (Kalamatee)
    - Workbook (Thomas Scheller)
    - Graphics.library (bugs: wrong behavior of ClipBlit in some cases) (JuanDoble07)
    - Intuition.library (added support for labels in propgadget) (JuanDoble07)
    - Gadtools.library (fixed behavior of TEXT gadget) (JuanDoble07)
    - KeyShow (bugs: Bitte melde dich an, um diesen Link zu sehen.) (deadwood)
    - SysExplorer (bugs: Bitte melde dich an, um diesen Link zu sehen.) (Kalamatee)
    - Kernel (bugs: Bitte melde dich an, um diesen Link zu sehen.) (Kalamatee)
    - Regina.library (bugs: Bitte melde dich an, um diesen Link zu sehen.) (deadwood)
    - Sfs-handler (bugs: Bitte melde dich an, um diesen Link zu sehen.) (deadwood)
    - Pciusb.device (bugs: #111) (deadwood)
    Stability Fixes:
    - ImageAdjust.mui (arkade, Kalamatee)
    - Ata.device (Kalamatee)
    - Prefs/ScreenMode (Kalamatee)
    - Intuition.library (Kalamatee)
    - Ilbm.datatype (Kalamatee)
    - C:TaskList (Kalamatee)
    - Vesagfx.hidd (Kalamatee)
    - Exec.library (Kalamatee)
    - Processor.resource (Kalamatee)
    - Prefs/Printer (Matthias Rustler)
    - Ram-handler (Matthias Rustler)
    - Dos.library (Ronnie Beck, JuanDoble07)
  • Started the transition to the new Core and new Contrib software compiled with the new C library.
    This morning deadwood made available the new Build and the new Contrib compiled with the new C library, the work of integration in the various Distributions has begun, a lot of work and a lot of tests before seeing some ready for users!
    Bitte melde dich an, um diesen Link zu sehen. you will find all the info and the Builds to download.
  • So richtig überzeugt mich das alles nicht. Immerhin ist Ikarus Desktop Live auf einem Pc installierbar. Bei 2 anderen bleibt der beim booten mit der Live CD mit einem ACPI Error hängen.
    AROS One x86 v2.4 läßt sich erst gar nicht installieren. Starten mit der Live CD geht aber. Der bricht mit einem Festplatten Fehler ab, obwohl die Festplatte in Ordnung ist.
    Alles mit echter Hardware, wobei kaum welche untersttzt wird.
    Dieses Programm zum Partitionieren der Festplatte ist eine echte Katastrophe. Nix ändern, nur Sata als Festplatte einstellen, und dann installieren. Die Festplatte muß komplett leer sein, sonst funktioniert das auch nicht. ;(
    Micky
  • Auf was das basiert ist nicht so ganz klar. Irgendein Linux als Unterbau und dann AmigaOS 4?
  • Sieht schick aus, aber das war es auch schon. Ich sehe da keinen großen Nutzen drin.
    Kann sein, wenn man die richtige Hardware hat, das es besser funktioniert. Das kann aber auch nicht der Sinn sein, daß man sich erst mühselig unterstützte Hardware zusammen suchen muß.
    Micky
    Naja, aber das Problem hast du den anderen "amiganoiden" Systemen wie MorphOS und AmigaOS4 ja auch, auch das läuft nur auf bestimmter Hardware (von Emulation und/oder VMs mal abgesehen) ... AROS hat es sich zur Aufgabe gemacht, ein Quelloffenes amiganoides Betriebssystem zu sein, welches eine hohe Kompatibilität zu AmigaOS 3.1 hat. Nebenbei kann man dann halt auch Programme darauf laufen lassen, die speziell für AROS kompiliert sind, genau wie bei MOS und AOS4.
    Und es gibt halt nur für die Hardware eine Unterstützung in AROS, für die auch Treiber existieren, simple as that.
  • Ich will es ja auch nicht schlecht machen, nur wenn nicht mal partitionieren geht, zumindest nicht so wie man das haben möchte, dann kann es das ja auch nicht sein.
    Und irgendein Amiga Programm starten, da ist ja wohl ein Emu mit im System, was dann letztendlich nicht funktioniert, kann einem das auch vermiesen.
    Und wenn Aros One v2.4 sich nicht installieren läßt dann kommt auch nicht die große Freude auf.
    Micky
    Wollte ich dir auch nicht unterstellen ;)
    Wenn man sich ein wenig damit beschäftigt, kann man durchaus einen GRUB Bootloader installieren und so Windows/Linux parallel zu AROS installiert haben ;)
    Ist sicherlich nichts für jemanden der nur mal in AROS reinschnuppern will, dafür gibt es zu viele Fallstricke aber genau dafür ist ja das LIVE System, einfach booten und anschauen ...
  • Ich habe hier für jedes System einen einzelnen Rechner.
    Windows Vista
    Windows 7
    Windows 8.1
    Amithlon
    MacOS 9.2
    Novell Netware 5.1
    Aros Icaros Desktop
    QNX 6.2 mit Amiga XL
    IBM OS/2 Warp Server 4
    Windows 95
    Dann noch einige Systeme vorinstalliert auf SDD Fesplatten.
    Was ich überhaupt nicht mag sind mehrere Systeme auf einem Rechner bzw. Festplatte.
    Micky
    Welches Tool haben Sie zur Erstellung der Partitionen verwendet?
    Bei AROS müssen Sie keine Tools zum Partitionieren verwenden, InstallAROS partitioniert automatisch, wenn Sie AROS installieren.
    Bezüglich der Installation auf einem nativen PC, wenn Sie Icaros installiert haben, wird auch AROS One installiert, bedenken Sie, dass Icaros seit vielen Jahren nicht mehr aktualisiert wurde, Hunderte und Aberhunderte von Fehlern wurden im Laufe der Jahre im Core behoben.
    AROS One ist jetzt in der neuen Version 2.5 verfügbar, viele Software-Updates und weitere Kernfehler behoben
  • Gibt einen Prozess zum Aktualisieren einer bestehenden Installation?
    Ab Version 2.6 wird es wohl einen Update-Installer geben :)
