New Release - Bill & Ted's Excellent Game Boy Adventure (C64) by Roman Werner
Es gibt 5 Antworten in diesem Thema, welches 1.157 mal aufgerufen wurde. Der letzte Beitrag (3. September 2023 um 12:37) ist von wizball6502.
    per Author:
    No way! Yes way. This, my friends, is the conversion of the legendary Bill & Ted Game Boy™ game by LJN/Beam Software to the Commodore 64.
    I used to have this cartdrige in the 90's with my Game Boy and really enjoyed the fast pace and simple but addictive game mechanics. Also the music is great. And you can play as Keanu Reeves - what could be more awesome. So I remade the game from scratch for the C64. SID music was done by Nordischsound. Enjoy! It's free!
    Joystick Control:
    • Joystick in Port 2
    • Press fire to jump (short press does a smaller jump)
    • To pick up a bonus item stand still and press the fire button
    • To activate a bonus item press down, then fire button
    Keyboard:
    • 'P' pauses the game
    • 'Run/Stop' takes you back to the menu/title screen
    • 'Space' changes the colour theme
    • Also use keys to enter your high score name
    Instructions
    A scan of the orignal Game Boy manual can be found Bitte melde dich an, um diesen Link zu sehen..
    Note: You will most likely have to play a quest a few times before you learned the best way to master it.
    Modern Game Design Considerations
    To make the game more enjoyable for today's standards I made the following adjustments...
    • More control over Bill and Ted while jumping
    • Jumps and landings do not need to be pixel perfect
    • Smooth transition from platform to ladders and ropes
    • The ten adventures can now be played in any sequence
    • Game state will be saved after each adventure (à 5 quests)
    • If you are not happy with the progress you can press Run/Stop anytime and start again from the last save state
    Technical Details/Design Challenges:
    The Game Boy has a resolution of 160x144 pixels. While 2x160 fits nicely into the 320 pixel width of the C64, the 144 pixels height does not (288 vs 200 pixels). Easy would have been to accept the 160x144 pixels dimension but for this game I wanted a full screen experience on the C64. My solution to the problem was to scroll the screen vertically which adds a nice challenging twist to the gameplay (you can't see the top or bottom baddies anymore). The permanent visible status bar (Life/Score/Time) is made out of 7 Sprites positioned in the opened top border. Same for the "Nintendo Game Boy" logo in the bottom border. Overall it took me about 5-6 months to make this game
    Trivia:
    • I tried to make Bill & Ted look more like Bill & Ted. Especially Ted did not do Keanu Reeves' distinctive hairstyle justice
    • I also made the representation of Jean d'Arc a little less lush
    • The Pterodactylus in the fifth adventure looked more like a flying manta ray. I fixed that
    • The phone number of the first adventure gives a hint on Keanu's birthday (I had to choose a number ;))
    • The bad guy in the original Game Boy game and instruction booklet is misspelled "De Nomolous" intead of "De Nomolos". We know now that "De Nomolos" is the name of writer and producer "Ed Solomon" spelled backwards.
    • The instruction booklet also mentions a jumping dog whereas the animal in the game is clearly designed as a cat. Which makes sense since there are cats in the second Bogus Journey movie ("Aim for the cat, dude!"), not dogs.
    • I rewatched all 3 movies to better understand the references in the game. To be honest, the "Bill & Ted Face The Music" movie came much later (2020), so I watched it for my own pleasure, not for research :)
    • The alien species called Station did not appear in the original game. They do now. Somewhere :)
    Game Requirements
    • C64/C128 (also works on C64 Mini and C64 Maxi)
    • 1 Player
    • PAL system only
    • Looks best in Full Border Mode
    • Sounds best with a SID 8580
    • Also playable on Windows/MacOS/iOS/Android (C64 Emulator required)
    Alternative Versions
  • Das sieht ja wirklich beeindruckend aus. Ich habe auf dem erstem Blick gedacht, es sind Screenshots vom Gameboy.
    New Version 1.1.1
    V1.1 should hopefully fix the real hardware drive issues while loading/saving. Definitely fixed is the crash when space was pressed at the same time when the title screen and high score table toggled.
    Version 1.1 furthermore fixes some cosmetic flaws, like the Game Over text not being displayed properly when the color theme was changed to another theme or some transitions that looked a bit rough. And LIVES is now spelled correctly.
    Please replace prior version with this one. Thank you <3.
    Please note: The disk now contains two main files: "Bill&Ted" and "Bill&TedNS". The "NS" stands for "No Speech" and may be used if you can live without the "Excellent" speech sample but instead prefer faster loading time. Enjoy.
    If you want to take over your score and save state from version 1.0 then feel free to copy the files "HI" and "ST" over to the new disc. Tip: The Windows tool Bitte melde dich an, um diesen Link zu sehen. does a great job for managing .d64 containers.
    Edit: Another quickfix applied to v1.1.1 so that after restart lives are properly initialized to '08'.
    Are you keeping up with the Commodore? 'cause the Commodore is keeping up with you!
    New Version 1.2
    The following improvements have been made in this version:
    • The "Last life lost without Game Over"-bug should be be fixed
    • Much shorter waiting times during the game due to the "Excellent" speech sample only loaded and played once
    • Bill has now his own Sprite when climbing (I originally had to reuse the Ted Sprite because I ran out of memory and hoped nobody would notice. Well, it did get noticed :D. I managed to squeeze some bytes and fixed this
    • Fixed a few bugs here and there, e.g. some gfx issues in the game over screen when a colour theme was used other than the default green one
    • The top left flickering when a level was started has mostly gone
