VICE 3.7 has been released
There are 399 replies in this Thread which has previously been viewed 83,844 times. The latest Post (July 1, 2025 at 9:20 PM) was by 8R0TK4$T3N.
  • VICE Team is proud to announce the release of VICE 3.7
    This release contains a lot of bug fixes and improvements:
    Downloads can be found at Please login to see this link. or Please login to see this link.
    From now on we also publish Debian packages (including the ROMs) of point releases and development releases, which should make it a little easier for Linux users to install an up-to-date VICE with the proper ROMs.
    Merry Christmas and enjoy!
    Please login to see this link. -- Please login to see this link.
  • I knew it!
    I had a hunch V3.7 was about to come this Christmas!
    So Excited!
    Man So may Updates and New Releases this Christmas!
    Are you keeping up with the Commodore? 'cause the Commodore is keeping up with you!
  • Aber CMD-RamLink funktioniert nach wie vor nur unter VICE-C64 :sad:
    Sollte das ab VICE 3.7 nicht auch unter VICE-C128 funktionieren?
    Pusti64
    Tja. Derjenige, der das implementiert hat, ist leider wie es aussieht kaum mehr aktiv. :|
    Ich persönlich fände es nett, wenn der Bug gefixt würde, dass man von einem 1581 Drive nicht mehr richtig wechseln kann.
  • Tried the new version some minutes ago and have a question. In V3.7 the "8580 filter bias" is set to "0" by default. Is that correct now, or should users change this again to "-3000", as it was always the case in all the older VICE versions? Does anyone know more?
    And then i recognized a problem on my Win7, 32bit-system. About every third time, i start the emulator, it crashes and brings up the error message:
    "x64sc.exe funktioniert nicht mehr. Das Programm wird aufgrund eines Problems nicht richtig ausgeführt. Das Programm wird geschlossen."
    "x64sc.ex don't work anymore ..."
    Especially this seems to occur on my PC, when a few other programs are already open and I then want to open VICE additionally. If no other program is running and I only open VICE, it seems to occurs less often. With V3.6.1 I had a similar problem. However with V3.6 and all VICE versions before, this problem never appeared. Could have something to do, with the changes from V3.6 to V3.6.1 maybe?
    Does anyone else have this error-message from time to time (especially on Win7, 32bit systems), when trying to open latest VICE? Overall V3.7 runs okay on my system, only this crash-message is a little bit strange, because like i mentioned, this never happens in V3.6 here, on my PC.
  • Bei mir schliesst sich x64c.exe (GTK) oft kurz nach dem start wieder, komplett ohne Fehlermeldung. Nach 2-3x starten bleibt das Fenster dann offen. Dieses Problem hatte ich mit 3.6.1. aber auch schon.
    Was in 3.7 neu ist, das mir Directories bei der Image Auswahl nur noch so angezeigt werden.
    Hab hier 3.6.2-dev r42547 drauf, da ist die Directory Anzeige noch in Ordnung. Bei früheren 3.7er builds war das bereits schon kaputt.
    Vielleicht nur ein simples Font Problem? Der enthaltene C64_Pro_Mono-STYLE.ttf Font ist zumindest installiert...
  • Die Directory Anzeige geht bei mir auf dem Notebook, auf dem Desktop war sie kürzlich auch plötzlich kaputt.
    Auf dem Desktop crasht VICE auch immer beim beenden, schon seit langem...
    Wirklich bedauerlich.
    Mich persönlich stört das missing feature, dass man bei einem »Host file system device« nicht die Kernmöglichkeiten vom SD2IEC hat - hauptsächlich: »Extension hiding« sowie »file extension mode«, also genau das, was auf einen SD2IEC per »xe"-Kommando eingestellt wird.
    Meine Github-Projekte: Please login to see this link. Vice 3.2 Improved: Please login to see this link.
    1541 Ultimate II / Ultimate 64 Firmware Releases: Please login to see this link.
    1541 Ultimate II Update instructions: Please login to see this link.
    Ja, selbes Problem hier.
  • Die MacOS Version stehtzwar als 3.7 auf der Hauptseite, es gibt aber nur 3.6.1.
    So wie ich das mitbekommen habe hat das neueste Gtk3-Release vom 22.12. endlich einen Bug gefixt, durch den die Menupunkte in macOS Ventura nicht anklickbar waren, aber damit zeigt VICE das C64-Bild im Fenster an der falschen Y-Position an. Statt eine Version rauszugeben die auf die eine oder andere Art kaputt ist wurde beschlossen, die Mac-Version nachzuliefern wenn der Mac-Nutzer im Entwicklerteam die Weihnachtsfeiertage überstanden hat und den VICE-seitigen Bug gefixt hat.
    30 printint(rnd(1)*328)-217
    Please login to see this link. - Please login to see this link. - Please login to see this link.
  • In V3.7 the "8580 filter bias" is set to "0" by default. Is that correct now, or should users change this again to "-3000", as it was always the case in all the older VICE versions? Does anyone know more?
    Please see Please login to see this link.. This is to be seen in the aftermath of a newer 8580 filter implementation. Just keep the filter bias at its default value if the SID emulation sounds right for you. :)
