Holiday New Release - Snake VS Bomb by Richard of TND
  • My beloved master of C64 Gaming (especially C64 Music) has Release 2 "FREE" games this Christmas.
    Richard has been releasing quality C64 Games and Utilities for FREE ever since!
    I really apprecited it. And we all should.
    This is 1st one.
    TND Games is very proud to present to you an entry for the Snake Fun Compo on CSDB. Snake VS Bomb is a fun for five minutes hi score challenge that features the following:
    • 8 Levels of increasing speed
    • Addictive gameplay
    • Loading bitmap
    • Front end presentation
    • Hi score table
    • Arcade style sound effects and cool music
    • Plus much more.
    • PAL/NTSC compatible
    • Compatible with theC64 mini, theC64, full size and theVIC20
    Instructions
    This is a fun hi score attack challenge, featuring 8 levels of madcap mayhem. You are a snake, which is travelling through a very long tunnel. During your travels you encounter fruit and bombs, which are placed at random inside the tunnel. The snake can eat the fruit if the fruit reaches its head for points. However, the bombs must be avoided. If any part of the snake collides into a bomb (or vice-versa), the bomb will explode along with the snake. The game will then be over.
    Completing a level
    Between the score panel and below it is a timer bar. This will drain per interval. This indicates how far or near you are to the next level. After the bar runs out fully, you will move onto the next level, which will get faster. For each level completed, a bonus of 1,000 points will be awarded.
    There are 8 levels in total - if you can survive for that long that is!
    Controls
    Use Joystick in port 2 only (If playing online, use Cursor Keys as direction and Z as the firebutton).
    Credits:
    Programming, charset, sound effects and music by Richard Bayliss
    Graphics, sprites and loading bitmap by Hugues Poisseroux
    Tape loader source by Martin Piper and Richard
    Glossary:
    The following C64 tools were used in developing this game production
    • Multipaint by Dr. Terrorz
    • Spritepad V2.0Beta by Subchrist
    • Charpad V2.7.6 by Subchrist
    • GT Ultra V1.4 by Cadaver and Jason Page
    • CBMPRGStudio V4.0 by Arther Jordison
    • KickAssembler V5.52 by Slammer/Camelot
    • TS Crunch V1.4 by Antonio Savona
    • Dir Master by Style
    • TapeToolBuild V1.0.0.7 by Martin Piper
    (C)2022 The New Dimension
    Like with all TND games. This production has been made specially for the C64 / retro community and is free to download. TND has no issues with this production being copied/shared. However no part of this production is allowed to be reproduced as physical/digital media without permission from TND Games.
    Install instructions
    Download the ZIP file. Create a folder on your device, open the ZIP archive and then copy and paste the files into your zip folder.
    Loading instructions (If copied to real hardware):
    Disk
    Insert the copied disk into your floppy drive.
    Type in LOAD "*",8
    After loading, type in RUN
    Tape
    Insert the copied tape into your fully aligned datasette then rewind the tape to the start.
    Press SHIFT and RUN STOP simultaneously. Press PLAY on your datasette and the game should load and run.
