After entering the freezer in C64 mode, sprites are only half the horizontal size and their position is halved too. Even after a RESET, the situation remains the same. Only a power-off-and-on-again will solve it.
Bug Report - FREEZER - sprites change their size
- Bug!
- ZeHa
- Thread is Unresolved
The Freezer Version is 1.5?
Yes, I downloaded the version on Friday I think.
TheRealWanderer
Moved the thread from forum MEGA65 Everything else to forum MEGA65 Bug Reports. -
TheRealWanderer
Added the Label Bug! -
Did you try a new core + freezer? I think this was fixed in mega65-core#499. I can't reproduce this with balloon65.prg
it happens with the following configuration:
the freezer has to be entered in C64 mode for the bug to happen. after entering the freezer, sprites will have half the size, even after resetting back to MEGA65 mode.
Still can't reproduce.
Please provide step by step instructions to reproduce.
now i can't reproduce it anymore myself. i swear i reproduced it right before my last post. if i find the proper steps again, i will let you know
i managed to reproduce it again, but it seems it only happens randomly.
my successful steps (but as i said only randomly successful):
1. turn on mega65
2. enter freezer
3. press f3
4. go64
5. enter freezer
6. press f3
7. reset button
8. mount disk with balloon
9. load balloon
10. run
There is also something else happening...
Sometime the sprites disappear suddenly (as described), but sometimes the smoothly scroll all the way out on the left side.
And I only get the blinking when they smoothly scroll out, not when they disappear.
Well, sprites have still a lot of work to be done... there are lots of sprite bugs in mega65-core.
