freeze menu stopped working
There are 8 replies in this Thread which has previously been viewed 2,613 times. The latest Post (February 23, 2023 at 1:38 PM) was by Venty.
  • I've just got the Mega65. After some tests the freeze menu stopped working. When I press the restore key the screen fills with random characters and crashes
    How can I fix it?
    How can I fix it?
    I have experienced the same and I assume we need to be a little patient and await a newer version :smile: As far as I know the entire freezer is being rewritten.
  • Not sure if I should open a new thread, but I'll just recycle this one for now.
    I have similar symptoms with my Mega65. I'm running ROM 920377, which is the latest AFAIK.
    When booting from the internal SD-Card that came with my Mega65, the freezer menu works. Well, most of the time, that is.
    Now, I use an external MicroSD-Card, where I copied the files from the original card to. Like MEGA65.ROM, the FREEZER.M65, all those D81 images plus a few other things like D64 images to use with the C64 Modes. The Mega65 does boot, but freezer does not even start. Pressing RESTORE has no effect. RUN STOP/RESTORE works however.
    Also I cannot disable the CRT Emulation in the Setup menu. The menu shows it disabled, blatantly lying to me.
    I mean, I can remove the external SD-Card, boot the Mega65 from the internal one and then reinsert the external SD-Card as a workaround, but I'd prefer not having to fiddle with this fingernail in the back of the computer all the time...
    Any hints? Does the size matter? My MicroSD is of 64 GB capacity.
    10 PRINT "BASIC programmers don't die."
    20 PRINT "They just GOSUB without RETURN."
    30 END
  • Venty
    Did you prepare the SD Card on the Mega65 (holding ALT on boot) ?
  • Any hints? Does the size matter? My MicroSD is of 64 GB capacity.
    64GB is to big. You need a SDHC card, max. 32GB. See also userguide page 23....
  • Venty
    As a matter of fact, no, I did partition and format it on my Linux box. I did not think it would matter. I will try this though.
    I wonder however, what the difference is when I let the Mega65 handle it? Does it add some "secret ingredient" to the filesystem, e.g. raise a special flag?
    Well, let's see, but first I have to backup the stuff already on the SD-Card.
    30 END
    What, me having to read a manual? Woe is me! :pumpkin:
    What puzzles me though is that other than those hickups I mentioned, the 64 GB seems to work fine. But okee, I wanted to get a bunch of SD-Cards for my Raspis, so I'll go shopping tomorrow.
    I'll report back, once I got hold of a 32 GB MicroSD-Card.
    Thank you both for your help so far!
    30 END
  • As a matter of fact, no, I did partition and format it on my Linux box. I did not think it would matter. I will try this though.
    From the MEGA65 Welcome Guide (Please login to see this link.
    Preparing the microSD memory card
    To use an SD card with the MEGA65, it must be formatted (erased and prepared) using the MEGA65. The SD card works like a regular storage drive when connected to your PC, but it contains additional data not visible to the PC that is used by MEGA65.
  • From the MEGA65 Welcome Guide (Please login to see this link.
    I see. Actually, the additional data is (kind of) visible, if you use Linux.
    It is a second partition of a very weird type:
    root@stallion:~# fdisk -l /dev/sdc
    Disk /dev/sdc: 59.63 GiB, 64021856256 bytes, 125042688 sectors
    Disk model: STORAGE DEVICE
    Units: sectors of 1 * 512 = 512 bytes
    Sector size (logical/physical): 512 bytes / 512 bytes
    I/O size (minimum/optimal): 512 bytes / 512 bytes
    Disklabel type: dos
    Disk identifier: 0xa6cb7d83
    Device Boot Start End Sectors Size Id Type
    /dev/sdc1 2048 120848381 120846334 57.6G c W95 FAT32 (LBA)
    /dev/sdc2 120848382 125042685 4194304 2G 41 PPC PReP Boot
    Could not yet mount it however, but eventually my kernel just lacks the appropriate driver.
    And yes, now that I prepared the card according to the manuals and guides, everything works! Sometimes, all you need is a nice RTFM slapped in your face. ;)
    Thank you so much everybody!
    30 END
