Gib es einen einfach Weg, mittels eine Schalters das interne LW des SX-64 komplett zu deaktivieren?
Folgendes habe ich gefunden:
"If the drive isn't working and you want to disable it, you can unplug the IEC cable (white cable) between drive board and CPU board. This will allow you to use external drive with ID 8 on the SX. This does however require removing about 12 screws and 3 case parts to get to the drive cable"
Wäre stattdessen eine ein-Schalter Lösung möglich?
