ZitatFor about 3 or 4 days now being working on adding the internet to PCUAE and VICE Mode, I managed install a network adding the network drivers to PCUAE and a DNS Client.
I managed to connect to Commodore Server using the V-1514 software and puting its IP address in the RS232 settings in C64 emulator.
Now I am working on getting BBS boards to work, I compiled TCPSER and got it to run in the background when you start VICE Mode, its a TCP to SERIAL Emulator made for VICE so you can communicate the old way via a network to serial, it converts the info from eth0 the network and sends it to the serial device in the VICE Emulator so this should work on any of the other machines too.
So the next version of PCUAE will have Internet Access
Genaueres und die erfolgreichen Tests unter:
