Hello, Guest the thread was called285 times and contains 0 replays
last post from magictom at the
Aktuelle Firmware 30.03.2021
  • Um an die letzte NEWS anzuknüpfen. Seit Juni 2020 sind mehrere Firmware Updates erschienen. Hier die Änderungen. Erhältlich wie üblich unter folgendem Link:
    https://github.com/mist-devel/…ries/tree/master/firmware
    1. firmware_210330
    2. ===============
    3. - Don't switch SPI clock for ACSI reads
    4. - <corename>.hd0/.hd1 can be used instead of a single vhd (useful for plus_too)
    5. - sdram64 option added to mist.ini (cores can get info if the SDRAM chip is upgraded to 64MB)
    6. - Allow umounting with backspace from OSD (core support is needed)
    7. - DIR= option added to ARC files, it can specify a new default director
    1. firmware_200130
    2. ===============
    3. - Allow to use the 3rd mouse button in cores
    4. - Menu navigation fixes in paged mode
    5. - Add AX88772A USB ID
    6. - Enable 68020 CPU for MiSTery
    1. firmware_201220
    2. ===============
    3. - 64 bit status word support
    4. - .RAM file support mostly to save/load small non-volatile contents (e.g. CMOS RAM or NVRAM in arcades)
    5. - Always put ".." on the top of the directory list (thanks to retrofun)
    1. firmware_201126
    2. ===============
    3. - Fix unnecessary RDB generation for some HDF images
    1. firmware_201122
    2. ===============
    3. - IDE handling cleanup
    4. - Send Ethernet config periodically to the FPGA
    5. - Add 0b95:772B noname USB Ethernet adapter
    6. - Composite blending setting for MiST2
    1. firmware_201011
    2. ===============
    3. - Fix the clock_freq setting
    4. - Add a mouse_speed setting to scale the mouse movement by percentage
    1. firmware_201006
    2. ===============
    3. - Add clock_freq setting to override Minimig master clock
    4. - Fix detection of SD card capacity for blocksize > 512
    5. - Support DB9 joystick remap
    6. - Fix joystick test for DB9
    1. firmware_200725
    2. ===============
    3. - Fix long-standing ADF write corruption bug
    4. - Generic USB-RTC support
