Es geht tatsächlich wie von icomp angekündigt im Monatsrythmus weiter:
Core Chameleon Beta-9m ist verfügbar!
Zitat von What's newAlles anzeigenThese are the changes since the last beta release. For the detailed history
please take a look at the releasenotes in the "Documentation" directory.
Menu System:
- Reworked Clockport initialization and -device detection. This fixes a tricky
bug that on some setups prevented a connected Silversurfer to work when the
program using it was started from the filebrowser.
FPGA Core:
- The REU configured for 256KByte did incorrectly wrap around the memory at the
256KByte boundary. A real 256KByte REU is really a 512KByte device with half
of the RAM chips missing, with the result that the upper half of the memory
banks accesses "open space".
This release corrects the incorrect wrap around - but does not implement the
somewhat tricky behaviour of reading from this unconnected memory yet (we are
working on it).
Some programs apparently rely on this behaviour - If you can identify any such
programs that use the REU and which do not work correctly after the update
when the REU configured for 256KByte please tell us so we can add them to our
testcases.
All other sizes are not affected, so you can always use the 512KByte config
instead, which should make those programs work.
