Hello, Guest the thread was called248 times and contains 2 replays
last post from ubik at the
vbcc optimizing C compiler for 6502 now with MEGA65 support
  • Hi,
    I have uploaded an update of vbcc with first support for the MEGA65: http://www.compilers.de/vbcc.html
    It does not yet make much use of MEGA65 CPU apart from map instruction (update is under work) and there are probably still quite a number of problems (there are some areas where I do not yet understand the requirements regarding mapping when calling kernel functions). But it should be well worth a try. At least I did have to change the loop counter of the dhrystone benchmark to unsigned because 30000 iterations would not take enough time.
    A few of the good things:
    - compiler is under active development
    - supports C99 (variable-length arrays, designated initializers etc.)
    - generates optimized code (see dhrystones in sample directory)
    - supports banked memory and far-pointers
    - (limited) floating point support based on Steve Wozniaks code
    - (pretty good) 32/64bit IEEE floating point support based on SANE
    - support for 65C02 extensions
    - support for writing interrupt handlers
    - attributes for putting variables into zero page
    - supports stack-frames > 256 bytes
    Changes since r1:
    - new target: MEGA65 (native mode, some banking support)
    - new target: Commander X16 (thanks András Péteri)
    - new options -prefer-statics/-force-statics (allocate local variables in static memory rather than on the stack)
    - new option -range-opt (first implementation of some range-based optimizations changing induction variables to smaller types)
    - added support for o65 object file format
    - added support for Oric target format
    - better use of x register
    - improved cross-module function-inlining
    - IEEE math library works with 65c02
    - several code generation improvements
    - fixed several bugs
    - slightly reworked examples
  • WOW,
    thanks for the update !
