Hi,
I have mounted the Geos D81 file using the freezer menu. However, I can see the files by loading a $, but I cannot find the actual program to run to load Geos.
1. Is Geos a C65 or C64 program?
2. How do I start Geos?
Thank you.
Es gibt 2 Antworten in diesem Thema, welches 1.508 mal aufgerufen wurde. Der letzte Beitrag (
Hi,
Thank you.
Actually, after trial and error, I figured it out:
1. Geos that ships with the devkit is C65 version.
2. Load the D81 and then load/run the Autoboot program on that disk.
the fastest way is:
- power on MEGA65
- enter freeze menu and press "0" to mount geos.d81
- press F5 (that leaves Freezer, does a Reset and autoboots GEOS)
