USB expansion and backpanel STL
Es gibt 4 Antworten in diesem Thema, welches 1.323 mal aufgerufen wurde. Der letzte Beitrag (1. Januar 2021 um 03:30) ist von rdpeake.
  • So, I ordered a usb extension cord panel mount Bitte melde dich an, um diesen Link zu sehen. so that i could easily unplug and replug the usb cable for the programmer.
    i made a 3d printed plate to mount it to and it was recommended i post about it here in case others wanted to do the same, or expand on this port for something else for use with the dev kits.
    an stl is available on the Bitte melde dich an, um diesen Link zu sehen. and here attached
  • I was planning to do the same once i can access my printer again - now I don't even have to draw it myself. Thank you! :thumbup:
    10.06.2023 - DoReCo Bitte melde dich an, um diesen Link zu sehen.
    14.09.2023 bis 17.09.2023 - DoReCo-Party 2023
  • Hopefully your panel mount extension has matching dimensions so you can just print it without issues!
  • Moving the screwholes around isn’t much of a Problem, if you mean that.
  • i know it isn't - i had to print it twice because i mucked up the screws the first time, but was more just meaning i hope it just prints without needing to do any moving (and your usb cable fits through the hole - i assume it will though.)
