- This release completes the transition to the new GTK3 based GUI and fixes a
- bunch of long standing issues (see below).
- We welcome to the team:
- empathicqubit - who wrote the new remote monitor binary interface
- Roberto Muscedere aka OldWoman37 - who contributed the new Lt.Kernal, CMD-HD and
- RAMlink emulations (C64 only)
- ** general
- - Remove explicit support for OS/2, AmigaOS. These platforms should be able to
- use the SDL port.
- - VICE used to store its ROMs, keymaps etc into $PREFIX/lib[64]/vice, which
- isn't correct. Now VICE installs its data into $PREFIX/share/vice, which
- makes a lot more sense. The documentation location has changed as well, now
- the documentation is installed in $PREFIX/share/doc/vice.
- On Windows, the binaries and DLLs have been moved into /bin, according to the
- requirements of GTK/GDK.
- - Emulator timing is now directly driven by the host system audio device.
- If sound emulation is disabled, timing is synchronized with the host clock.
- As part of this change, the choice of sound synchronization method has been
- removed.
- - Emulation now occurs in blocks of time directly related to the sound fragment
- size. Previously, emulation of an entire frame happened as quickly as possible
- and then the host system would sleep until it is time to emulate the next
- entire frame. This means that user input is now visible to the emulated
- software with lower latency than before.
- - Audio latency is much lower on all platforms, and new lower latency defaults
- have been set. Users are encouraged to try using smaller fragment sizes and
- experiment with finding the lowest stable buffer size on their system.
- - Support for changing the emulator timing to target generating a specific number
- of video frames per second. Useful for smooth PAL scrolling on a 50Hz CRT, and
- also fun for playing games at 60fps to match a typical LCD screen refresh.
- - The default behaviour on CPU JAM was changed to "continue" to better match
- the behaviour of the real machines. Additionally a "CPU JAM" message will
- be displayed in the status bar.
- - A "quit emulator" option was added to the CPU JAM dialog
- - The CPU JAM dialog now shows the number of the device whose CPU has crashed.
- - Proper support for dual drives has been added
- - Relative file support on the filesystem device
- - Autostarting works from any drive (select the drive in the attach disk dialog)
- - Added support for 2nd and 3rd joystick button (potx/poty), currently only via
- keyboard and via unix joystick driver.
- - Added mapping for the THEC64 joystick
- - New LT.Kernal emulation
- - New CMD-HD emulation
- - New CMD RAM-Link emulation
- - New D9090/60 emulation
- - New icons for the applications.
- - We now use proper binary prefixes for memory sizes.
- Welcome in the 21st century!
- - Recalculate the palette parameters when the videochip type changes, now we can
- actually see the subtle color differences :)
- - Emulate a switch present on some compatible datasettes (not the Commodore
- ones). Turning the switch on makes the sound recorded on the tape audible.
- - Fixed/improved "native" screenshots. It will now work with all videochips and
- always generate "best effort" results.
- - The emulators will look for the config file at an alternative location first,
- before looking at the system wide location.
- - for windows that is the location of the .exe files
- - for Linux that is ~/.vicerc
- - Fixed lightgun/pen emulation
- - use poty instead of potx for trigger for magnum lightphaser and inkwell
- lightpen
- - tweak lightphaser offset against a bunch of games
- - Handling of settings and resources was improved a bit:
- - always reset resources to default before loading a settings file
- - new "-addconfig" option (or "load additional settings") loads additional
- resources from a file without resetting to defaults before. this can be used
- to keep custom setups separate from the regular settings.
- - Fixed sysfile search path order.
- The order now is $HOME/.local -> path-of-binary -> VICE_DATADIR
- - Fixed a bug in .tap file handling that caused some .tap files to not work in
- the preview widget(s)
- - A bunch of files have been removed from the source tree because they didn't
- really belong there and/or contained outdated info:
- - hardware-sids.txt, the old info is now at
- https://vice-emu.pokefinder.org/index.php/Hardware_SID_Status
- - SDL-support.txt, the old info is now at
- https://vice-emu.pokefinder.org/index.php/SDL_Status
- - ffmpeg-support.txt, the old info is now at
- https://vice-emu.pokefinder.org/index.php/FFMPEG_Status
- - Another bunch of files were removed because their content was hopelessly
- outdated and/or could be moved to other files:
- - removed ancient CHANGELOG files. Read NEWS for the recent changes. Refer to
- the SVN log for the gory details.
- - moved contents from FEEDBACK to README
- - removed INSTALL, AUTHORS, FEEDBACK
- - removed the MAN pages. Read the html or pdf manual instead.
- ** build system
- Many changes and simplifications were made in the build system, to make
- it more reproducible and match the expected standard behaviour:
- - Add --disable-optimization (default=no) to make the buildsystem use -O0 for
- debugging.
- - 'make dist' no longer needs '--enable-static-ffmpeg' to generate a working
- tarball.
- - Fixed support for the —disable-silent-rules/—enable-silent-rules configure
- arguments.
- - Added --enable-sandbox-mode switch. This switch will tell GTK3 to use
- 'native dialogs' so we can properly support Flatpak and similar containers.
- - Added -—enable-cmake to automatically generate cmake CMakelists.txt files for
- in-tree configured builds. Generating Xcode projects works, and this may
- allow generation of MSVC project files in the future.
- - Add --enable-desktop-files for creating and installing .desktop files on Unix.
- - Added --enable/disable-html-docs
- - Added --with/without-mpg123 (default=yes), makes MP3-decoding support optional
- - Added --with/without-ogg-vorbis
- - Added --with/without-flac (default=yes)
- - Update --with[out]-lame, make no default
- - Make jpeg and gif support default to no
- - Make using libpng the default, fail unless explicitly disabled
- - Make ALSA and Pulse default to enabled, make OSS default to disabled
- - Make MIDI support disabled by default
- - Make new 8580 filter default
- - Removed --disable-hwscale, always check for OpenGL with GTK3, error out when
- --disable-hwscale is used with SDL2
- Properly report missing tools to generate docs:
- - Fail on missing pdftex when PDF docs requested
- - Checks for makeinfo and texi2dvi (from the texinfo package) and warns in the
- configure output at the end if they are missing, but will still build VICE.
- Check presence of other tools instead of silently not using them:
- - Made dos2unix mandatory to avoid surprises
- - Fail if building for Windows and `icotool` is missing. It can be obtained by
- installing the `icoutils` package.
- Some features have been deprecated and are now disabled by default:
- - Added --enable-x64-image option to enable X64 image support, which is now
- disabled by default.
- - Added --with/without-fastsid switch to enable/disable the fastSID engine
- (default is off).
- ** Monitor
- - Completely new binary remote protocol for debuggers. The older hack was
- removed - see the documentation for details.
- - -moncommands finally work as originally intended and supports all monitor
- commands now. That means there are subtle differences in how certain things
- work. one important thing is that by default it will use an initial break
- point just after "reset".
- - "-initbreak ready" can be used to place an initial wait for "ready", like
- autostart does, or "-initbreak reset" to break just after reset.
- For more details, read the documentation.
- - ‘stop’ is no more ending up in recorded monitor command playback files
- - Support `cd ~` to change cwd to $HOME
- - Added 'mkdir' command
- - Aadded 'rmdir' command
- - Aadded "verify" and "bverify" commands to compare memory with a file
- - Aadded optional address to the `screen` command
- - `chis` shows the cycle count as well now
- - Aadded option to configure the number of lines used for chis
- - Aadded option to change the size of the scrollback buffer
- - Added "dummy" command to enable or disable whether break- and watchpoints
- trigger at dummy accesses or not.
- - Check watchpoints in the order they were added, that makes the output in the
- monitor less confusing when more than one watchpoint triggers at a time
- - Show rasterline and cycle in both decimal and hex
- - Add 'q' as a shorthand for 'quit'
- - Improvements to the char/sprite display - use # over * for more contrast,
- show the memory value(s) alongside binary view and fix bug showing multiple
- sprites
- - "list", "load" and "save" do now work with the filesystem device
- - Drive numbers are now expected to be decimal
- - Add monitor dump function to m6821 core
- - Added info on head position/status to VIA io dump
- - The display now (optionally) refreshes after each monitor command. this is not
- cycle exact right now (only per scanline).
- - Fixed accessing cartridge memory
- - Improve expansion port mode status output
- - Fix io command to shows IO space in address order
- ** vdrive
- - The filesystem device now uses shortened filenames by default to increase
- compatibility.
- - Disallow to silently overwrite existing files (optional, default is "no")
- - Implemented "save @" to overwrite files (but do not simulate the well known
- related bugs)
- - Basic support for REL files in the File System Device. (Using P00 format, or
- rather R00, is recommended)
- - Fix some BAM track allocation issues in 8050/8250 disk images
- - Avoid DISK FULL with 27 blocks free on .D80 / .D82.
- - For D80/D82 images, when reading the directory, use the correct block to fetch
- the disk's name from. This corrects a bad disk name in directory listings when
- using a vdrive.
- - Added proper creation of d1m, d2m and d4m images, the resulting image has 1
- native partition spanning the entire disk.
- - When formatting or validating an 8050 or 8250 image, the header sector wasn't
- flagged as allocated. This resulted in VICE hanging when creating more than 80
- files on the disk.
- ** True drive emulation
- - More realistic modelling of the floppy drive wobble
- - Changed lower limit for drive RPM to 260 and upper limit to 340 (ie +/- 40).
- This is slightly more than possible with a real 1541.
- ** CPU fixes
- - Prevent IRQ/NMI from being served by the CPU when it has JAMed
- - Perform all "dummy" accesses also in the non "sc" core
- - Changed magic constant for LAX#imm to 0xEE as required(!) by wizball
- ** VDC fixes
- - Emulate VDC's internal buffer, issues with RFOVDC plasma part are fixed
- - Several fixes for interlace, now vdcmodemania interlace parts all work and
- soci VDC test #5 works
- - Improved VDC-FLI handling, 3 byte attribute offset doesn't always apply,
- fixes vdc-mcm demo and vdcmodemania fli part
- - Fix issue with wrap around of VDC ram affecting vdcmodemania fli part
- - Fixed VDC reg #28 bit #4, it sets the addressing mode, it does not actually
- reflect the amount of ram installed.
- - Correct aspect ratio for PAL or NTSC
- - Screen is resized automatically on PAL/NTSC change
- - Corrected size of saved screenshots or videos
- - Correct handling of unused bits in some registers
- - Corrections and enhancements to monitor "io d600" dump
- ** SID fixes
- - Fixed the filter saturation
- - Noise writeback fixes
- - Envelope regression fix
- - Fix the coefficients for the resid external filter
- - Rough implementation of the shift register and waveform zero bitfade
- - Added 4 possible additional SID chips for a total of 8 (x64*/xscpu64/x128 only)
- ** C64 fixes
- - Enable/disable datasette/tapecart as needed on autostart
- - Several new cartridge types added:
- - The 'ZIPP-CODE 48' cartridge
- - The polish 'blackbox v8' cartridge
- - The polish 'Blackbox V3' cartridge
- - The polish 'Blackbox V4' cartridge
- - The polish 'Blackbox V9' cartridge
- - The 'REX RAM-Floppy' cartridge
- - The czech 'BIS-Plus' cartridges (2,4,8kb variants)
- - The polish 'SD-BOX' cartridge
- - The 'MultiMAX' cartridge
- - The argentinian HERO bootleg cartridge
- - The "GMod3" cartridge
- - Action Replay fixes:
- - When reading from IO1 area when AR5 is enabled, the value currently on the
- bus will get written to the register, causing the famous bug/crash
- - Handle the broken mode 0x22 and emit a warning on potentially problematic
- reads
- - Retroreplay fixes:
- - Allow reading back the status of the freeze button
- - Fix reads from IO1 when the clockport is not active.
- - Handle the somewhat broken mode 0x22 like on real retro replay
- - Nordic Power fixes:
- - Fix writing to cartridge ram in mode 0x22
- ** C128 fixes
- - FD2000/4000 work again, including burst mode
- ** VIC20 fixes
- - Added handling for 32k cartridge files that contain blocks 1,2,3 and 5.
- - Fixed megacart nvram addressing
- - External audio filter fix
- ** PET fixes
- - Teach VICE where BASIC 1 keeps the current screen line address, so that
- Autostart works.
- - Made the UK business keyboard the default and moved it to the top of the list
- of keyboards. This makes the default setup work with the keymaps and editor
- ROM we have in VICE.
- - For CRTC-less PETs, use screen setup values that work out to 60 Hz refresh.
- - Tuned the display timing values for non-CRTC PETs
- - Renamed PET ROMs to include their part number (in line with Zimmers). This
- should make it more clear which editor ROMs exist.
- - The 4032B model used a wrong Editor ROM
- ** SDL fixes
- - Implemented mouse pointer auto-hiding
- - Remember last position in the main menu
- - Several Keyboard mapping fixes:
- - Fix (some) plus4 keymaps
- - Some pet keymap fixes
- - Updated/fixed symbolic mapping for italian keyboard
- - Some tweaks to symbolic keymap for german layout (plus4)
- - Added keymap from/for BMC64 (c64)
- ** GTK3 fixes
- - Almost all causes of stuttering / audio glitches when interacting with the UI
- have been resolved.
- - Cairo is completely gone, all major platforms use their native rendering
- backend
- - Added hotkey "pause" to generate a screenshot from current canvas using a
- generated filename in the current working directory
- - Rearranged cartridge/io settings around a bit. not perfect yet, but probably
- better than before
- - Add optional hiding of VDC display
- - Make double-clicking on the emulated screen switch fullscreen mode
- - Alt+Enter will now also toggle fullscreen mode
- - Added option to pause the emulation when settings dialog is open
- - Remember not only the last directory but also the last file in file dialogs
- - Show "Use Alt+M to disable mouse grab" in window title if mouse grab is
- active
- - Support 'StartMinimized'/-minimized
- - Added 'restore window geometry' to UI and commandline to allow users to apply/
- ignore the last position/size of the window(s) stored in vicerc/vice.ini.
- - Allow for 8 'analog' controllers on Linux
- - Added Alt+Shift+F12 VICII to switch border mode in x64sc
- - Moved the netplay settings from the 'File' menu to the settings dialog
- - Added 'Host' root node in the settings UI, move Autostart, Monitor, Netplay,
- Snapshot/Event/Media recording directory and start-mode under that.
- - Also move Host->Machine settings (CWD and JAM-action) under Host, remove the
- Host->Machine node.
- - Use workaround for GTKFileChooser's "Select" button not being active when
- selecting/creating a directory.
- - Added keymaps for THE64 keyboard
- - Updated keymaps for pet graphical keyboard
- - Fix shift+z/y in german positional mapping (c64)
- - Some tweaks to symbolic keymap for german layout (c64)
- - Added positional keymap for Swedish keyboard
- - Fix ctrl and cbm mapping (c128)
- ** macOS fixes
- - VICE GTK performance on macOS is now excellent and we finally now recommend
- the GTK build over the SDL build.
- - macOS bindist now relies on macports rather than homebrew. With macports it’s
- possible to build deps from source while targeting an older macOS version,
- which allows us to continue to support macOS 10.9+.
- - Re-enabled the bafflingly disabled working macOS joystick code
- - Actual macOS game controller device names are now listed instead of 6x “Analog
- joystick n”
- ** c1541 fixes
- - Added some REL file support
- - support for REL files to the c1541 COPY subcommand
- - Add subcommand to show dir entry of a file, and all side sectors.
- - Add support for SEQ and USR files for the -extract command
- - Renamed `zcreate` command to `unzip`. 'unzip' (dissolve a zipcode archive)
- sounds more logical than 'zcreate'. When we decide to also support creating
- zipcode archives, a proper name for that could be 'zip' or 'zipcode'.
- ** petcat fixes
- - Added missing basic v4 tokens for cbmII
GTK3 Builds (recommended)
SDL2 Builds
