Hello, Guest the thread was called279 times and contains 2 replays
last post from deft at the
BASIC 10 - LIST "filename"
  • Yesterday, while playing around with the BASIC10 section of the C65 ROM, I came across an innovation in the LIST command that I have not yet noticed, although it is even mentioned in the old "c65manual.txt". :search:
    You can not only display a BASIC program that is currently in memory with LIST, as usual, but also a BASIC program that is on disc:
    LIST "filename" [, Ddrive] [<, | ON> Udevice]
    lists the program "filename" without(!) destroying or changing the current BASIC program in the memory.
    For example, it is convenient to have the listing of a program displayed to look something up there without having to save the current BASIC program first.
    LIST "filename" works in direct mode and also as a command in the program with filename "PROGRAM1" or with "P*" or "*" for the filename.
    I think that this is a nice and useful extension of the LIST command in BASIC 10 and should receive the attention it deserves. ;)
  • Snoopy
    Changed the title of the thread from “BASIC 10 - LOAD "filename"” to “BASIC 10 - LIST "filename"”.
