Es gibt 123 Antworten in diesem Thema, welches 27.166 mal aufgerufen wurde. Der letzte Beitrag (30. August 2023 um 14:12) ist von Harald Fraenkel.
  • Anyone who had issues with the Ultimate64 / 1541UII+ freezing issue when leaving the OPTIONS screen (and working again after pressing the U64 button and then exiting the menu) should reapply the patch. I spoke to Gideon about this issue in the FW, and applied a workaround which seems to stop the issue.
  • edit: Und das offizielle EasyFlash CRT Image läuft auch einwandfrei auf dem Kung Fu Flash. Weiß jetzt nicht, ob der Patch bzw. Trainer von Excess schuld an dem Freeze vorher war.
    it is very unlikely that the trainer made KFF crash.
    Just checked. Works fine! Thanks!
    C64 - Die einzig wahre PlayStation!
  • According csdb, he's referncing to Excess' patch
    Okay:
    Zitat von Knight Rider
    I have implemented a workaround now, and the patch in the MEGA link has been updated to reflect this.
  • Yes I have the same problem. 1541UII+ Firmware 3.9 causes a crash after activating the autofire option and then exit to main menu. My 1541UII (without +) Firmware 3.7 does not start the game at all after exiting the Excess Trainer Intro. When I try to start the EasyFlash file within the original Protovision ZIP folder with my 1541UII (without +) it goes directly to the endscene without music. I can watch the end sequence until it goes back to the main menu. All without music. When I start the game my ship starts with a shield. Still all without music and when I hit enemies the shield does not decrease. Only hitting walls destroys my ship. The SoulForce_GS64.crt and the SoulForce_ocean.crt work fine with the 1541UII (without +) and Firmware 3.7. I downloaded the patch again and appiled it to the file, as described in the readme file. The result is the same. The Date of the BPS file is/was 31.12.2020 and time 15:15.
  • Soul Force aktualisiert für mehr Kompatibilität
    Sarah Jane Avory hat über die Feiertage hart gearbeitet, um sicherzustellen, dass Gamer ihren großartigen neuen Horizontal-Shooter – Bitte melde dich an, um diesen Link zu sehen. – in vollen Zügen genießen können. So wird nun eine noch breitere Palette von Geräten unterstützt.
    Die Images des Spiels wurden aktualisiert, um die Kompatibilität mit THEC64 (Mini & Maxi) sowie dem Ultimate 64 / der 1541 Ultimate II+ zu verbessern.
    Wir empfehlen, die neu hinzugekommene GS64-Version für THEC64 zu verwenden, während Nutzer von Ultimate 64 / 1541 Ultimate II+ zur aktualisierten EasyFlash-Version greifen sollten. Um auf die aktuellen Images zuzugreifen, können Kunden Soul Force einfach erneut aus unserem entsprechenden Shop herunterladen! Bitte auch die mitgelieferte Readme-Datei für weitere Hinweise beachten.
    Du hast das Spiel noch nicht gekauft? Dann hol Dir Dein Exemplar jetzt im Bitte melde dich an, um diesen Link zu sehen. oder alternativ auf unserer Bitte melde dich an, um diesen Link zu sehen.!
  • Heute abend hab ich mich dran gesetzt. Was ein tolles Spiel!
    Ein schöner Abschluss für einen Sonntagabend. Hier mein Gameplay Video:
    P.S. Irgendwann muss ich das nochmal neu uploaden - habe es noch nicht im Griff, die Interlace-Effekte (bspw. Schild des Raumschiff) ordentlich auf YouTube zu bringen. Beim aufgenommenen Rohmaterial abgespielt am Laptop sieht alles prima aus... :cursing:
    Gruß, Goethe.
    _______________
    C64, C128DCR, SX64, C16, plus/4, A1200+Blizzard1230/IV, A600HD+Vampire600V2, A300+ACA620, MEGA65, Atari 800+810
    Vectrex, Game Boy, NDSi, GameCube, Game Gear, Mega Drive, Mega CD, 32X, Multimega, Nomad, Saturn, Dreamcast, XBox, PS2, PSP, PS3, PS Vita, Ouya, PS4, PS5
    2 Mal editiert, zuletzt von Goethe (4. Januar 2021 um 00:52)
  • Warum bindet Protovision eigentlich nie Videos auf Ihrer Seite ein?
  • You need to redownload the files again. The date should be 3rd Jan 2021. Bitte melde dich an, um diesen Link zu sehen.
    1541UII FW 3.7 seems to be be a firmware/hardware issue. You need to speak to Gideon about this, but could be it's out of life so he won't fix it.
    1541UII+ and Ultimate64 FW 3.9 is a known issue, Gideon is aware. There has been a fix applied to the CRT to bypass this and has been confirmed as working.
  • P.S. Irgendwann muss ich das nochmal neu uploaden - habe es noch nicht im Griff, die Interlace-Effekte (bspw. Schild des Raumschiff) ordentlich auf YouTube zu bringen. Beim aufgenommenen Rohmaterial abgespielt am Laptop sieht alles prima aus... :cursing:
    Das Problem hatte ich früher auch; es liegt an der Framerate. Wenn nach deiner Verarbeitung die Framerate des fertigen Videos von der des Ausgangsmaterials abweicht, bekommst Du diesen Effekt. Das hatte ich bei Enforcer - wenn da der Shield aktiv ist, sieht man je nach Laune mal nur das Schiff oder nur den Shield...
    Früher habe ich alles mit iMovie gemacht, das dengelt aber jedes Video am Ende auf 30fps, egal was Du vorher reinschmeisst....
    Mittlerweile nehme ich nur noch vom U64 auf, HDMI mit 50fps und Scanline-Effekt, ein besseres Ergebnis für YouTube gibt es nicht.
  • Haha, ich muss leider noch warten bevor ich loslegen kann. Habe eine einfache Banküberweisung benutzt und jetzt wird das erstmal weiter andauern mit den freischalten des Downloads. Hätte PayPal benutzen sollen und hab's einfach versemmelt XD.
  • Mittlerweile nehme ich nur noch vom U64 auf, HDMI mit 50fps und Scanline-Effekt, ein besseres Ergebnis für YouTube gibt es nicht.
    Ich muss sagen, ich bin da Purist... Aufnahmen in meinem YT Channel alle nur von "echten" :wink: C64 (hoffentlich liest Gideon nicht mit :whistling: ).
    Ich nehme auf C64 SVideo -> Framemeister XRGBMini 720p50, Scanlines, Wide Mode, Picture Mode --> AVerMedia Live Gamer Mini (GC311) --> Aufnahme ebenfalls 720p50 (H.264 HIGH).
    Ich muss mich auch selbst korrigieren - habe mir mein Video nochmal angeschaut, und der Schildeffekt ab 2:15 sieht ja einwandfrei aus.
    Das Geruckel des Scrollings kommt natürlich durch das 50/60Hz Problem - YT macht scheinbar alles nur in 60Hz, obwohl mein hochgeladenes Video natürlich 720p50 ist.
    Kein Ahnung warum ich da gestern Nacht dachte, der Schildeffekt sei nicht sichtbar / die Videoqualität sei nicht ok. War vielleicht schon zu spät.
    Oder es besteht eine Abhängigkeit auch zum verwendeten YT Player / Betriebssystem / Gerät, da ich gestern Nacht auf einer anderen Maschine unterwegs war.
    Allerdings hatte ich den Framemeister falsch konfiguriert - Picture Mode sollte man nur für progressive Sources verwenden (z.B. Spielkonsolen), für SVideo Input (C64 etc.) sollte man stattdessen Natural Mode verwenden.
    Gruß, Goethe.
    _______________
  • YouTube kann eigentlich sauber 50Hz abspielen, aber nicht alle Abspieler geben das richtig wieder. Soweit ich weiß, schaltet ein FireTV nicht auf 50Hz, wenn das System auf 60Hz eingestellt ist. Entsprechend ist es zweifelhaft, ob das jedes andere device, Browser und so weiter, immer richtig macht.
  • aber nicht alle Abspieler geben das richtig wieder.
    Ja genau. Sogar bei Handys gibt es verschiedene Abspielarten. Auf dem iPhone 7 konnte ich die 50 bzw. 60 Frames nicht richtig ansehen, wenn ich im LTE unterwegs war, im WLAN schon. Auf dem 11er habe ich diese Einschränkung nicht mehr.
  • 1541UII FW 3.7 seems to be be a firmware/hardware issue. You need to speak to Gideon about this, but could be it's out of life so he won't fix it.
    I have info from Gideon that there will be more firmware updates for the 1541 U2 without plus. It's just current application part of the firmware does not fit into the flash. A flash reorganisation will help, and for one of the next firmware versions (to last plans I knew the next one; but recent bugs may force Gideon to release a bug fix before that) that reorganisation is planed together with a complete rewrite of cartridge suport. Thus we decided it's better not to release 3.9 for the U2. The alternative would have been to delay release for all platforms.
    Einmal editiert, zuletzt von markusC64 (4. Januar 2021 um 21:17)
  • Die Images des Spiels wurden aktualisiert, um die Kompatibilität mit THEC64 (Mini & Maxi) sowie dem Ultimate 64 / der 1541 Ultimate II+ zu verbessern.
    Protovision Ich habe gerade das Spiel als Download gekauft. Zwecks Prüfung, was da mit der Ultimate II schiefgeht, könnte ich bitte auch die "alten" Versionen haben?
    Ach ja: Bei der U2+ und beim U64 gibt es in Firmware 3.9 einen Bug im UCI Command Interface, welches derzeit viele Probleme verursacht - unter anderem in der EAPI, die fürs Easyflash verwendet wird. Da warten wir erst mal dessen Korrektur ab, bevor wir das genauer beurteilen. Zur Analyse gibt es aber in der Regel Zwischenstände, mit denen ich das trotzdem schon mal anschauen kann.
    2 Mal editiert, zuletzt von markusC64 (4. Januar 2021 um 21:20)
    mrr19121970
    For the very same reason: Can I get the old patch?
    Edit: Thanks for the patch, I have received it sucessfully.
    Einmal editiert, zuletzt von markusC64 (5. Januar 2021 um 16:50)
