Hello, Guest the thread was called201 times and contains 6 replays
last post from ubik at the
YAPED32 - a 32 colour PETSCII editor for the MEGA65
  • Hi all,
    here's YAPED32. That's short for "Yet Another Petscii EDitor, but this time with 32 colours" ;-)
    A few notable features:
    - world's first MEGA65 native PETSCII editor supporting 32 colours
    - nice palette tool for redefining colours and easy creation of gradients
    - 9 independent workspaces
    - rectangular selection and copy tool
    - 5 extra screen rows for help, status information & palettes
    - 3 modes of operation: drawing mode / typing mode / low-res Block Mode
    The whole thing is still late alpha / early beta and likely has lots of bugs and rough edges, and I'm posting it here because I'd love to get some feedback from PETSCII artists as to what is still needed in there. :)
    Please note that YAPED32 does not yet run in XEMU (neither the baseline branch nor hernandp' s megawat branch), so you need the xilinx board or a m65 dev kit to test it.
    Some quick tips:
    - You can press the 'HELP' key in drawing mode and in the palette editor to get a basic rundown on how yaped32 works. In the other modes, the status area displays an overview about which functions you may use
    - If you don't like working with the character palette, you may use typing mode for just typing your characters or block mode to directly access 80x50 petscii block graphics
    - 'RUN/STOP' always takes you back to the main menu (at least, it should...)
    - in drawing mode, press 1-9 to switch between workspaces
    - in typing mode, press alt+1-9 to switch between workspaces
    - when using the a)rea selection tool in drawing mode, you can switch between workspaces once you have selected an area
    Have fun!
    P.S: If you find YAPED32 useful and are artistically inclined... I could use one or two nice PETSCII pictures to distribute with the final version :) :)
  • looks nice, do those 32 colours represent a certain mode of the VIC-IV or why exactly 32?
    It's an extension to the C64's standard character mode... on the C65 there's the 'highlight' bit, which tells the VIC-III to choose its foreground character colour from an additional bank of 16 colours. And since this little program began its life ~25 years ago on the C65 (long story ;-)), that's the mode that's currently supported ;)
    In theory, the MEGA65's VIC-IV can do even more via "super-extended attribute mode"... but that's stuff for a future version of YAPED ;-)
  • Okay nice :) so the original C65 can have the characters to be displayed in either one of the 16 original colors or 16 extended colors? Can this palette be freely chosen or were they fixed on the C65? What about the background color, is that global for the entire screen just like on the C64, or was it also choosable per char on the C65?
  • so the original C65 can have the characters to be displayed in either one of the 16 original colors or 16 extended colors?
    Yes, by setting the ATTR bit in control register B (bit 5 in register 0xd031), the C65 gains 4 additional attributes in colour RAM (in addition to the original, lower nybble, which still acts as colour pointer) from bit 4 to 7: Blink, Highlight, Underlined and Reverse Video.
    So, when setting bit 5 in colour RAM, the colour is taken from an additional bank of 16 colours by adding 16 to the colour index value (so the original colours are 0-15, and the extended ones are 16-31)
    It can be freely chosen; in fact, the original colours, too, can be freely redefined after setting the PALette bit in control register A (bit 2 in register 0xd030)
    Just like on the C64 there was also "extended color mode" on the C65. But just like on the C64, it wasn't worth much because you only had 6 bits left for the characters.
    But of course, the MEGA65 expands greatly on that... ;)
  • Amazing, Thank you !
    Looking forward testing it !
  • Here's a little bugfix release for YAPED32:
    What's changed:
    - fixed an issue where part of the screen would not be shown in NTSC mode (the VIC-IV is now reconfigured to PAL mode upon startup, because NTSC mode has not enough resolution for Yaped32's extended screen)
    - you can quit by pressing 'q' from the main menu. This has the benefit that the VIC-IV is brought back into a sane state and the HOTREG bits are reset
