MEGA65 R3 Mainboard sneak-peak and Updates
Es gibt 15 Antworten in diesem Thema, welches 3.895 mal aufgerufen wurde. Der letzte Beitrag (1. September 2020 um 23:23) ist von deft.
  • Hi,
    as some of you maybe noticed already.
    Paul did a nice Bitte melde dich an, um diesen Link zu sehen..
    We have received the first 3 Prototypes of the revision 3 Mainboards of the MEGA65.
    One of those boards will be sent via express delivery to Paul/Australia tomorrow morning, to get it into Pauls hands as fast as possible.
    I had the chance to test the board already together with Paul.
    (While i made a serial connection from my PC to the MEGA65, Paul connected remotely to my PC and directly worked on the R3 board. So YES Paul was able to use a MEGA65 located in Darmstadt Germany from the middle of Nowhere in Australia !)
    So far we are absolutely happy with the Revision 3 ! and if our further tests proof, we will be absolutely in our planned release schedule.
    So have fun, reading Pauls Blog and we keep you updated !
    Stay tuned !!!
    :DJ
    Bitte melde dich an, um diesen Link zu sehen. <- here you can find all MEGA65 related files, games, etc.
    Bitte melde dich an, um diesen Link zu sehen. <- MEGA65 main Homepage. links to all important MEGA65 sites (links on top of the page to Files, Forum, GitHub, Manual,etc.)
    Bitte melde dich an, um diesen Link zu sehen. <-Pauls Blog - constant updates about current tasks, project status, etc.
    Bitte melde dich an, um diesen Link zu sehen.,Bitte melde dich an, um diesen Link zu sehen. <- All Open-Source information regarding MEGA65. Found Bugs ? create an issue there please!
    Bitte melde dich an, um diesen Link zu sehen. <- Join for live chat support and more --- The Future is 8-bit !!!
  • Thank you. Yes ! It's a beauty ! Probably some people will notice, that we have not been able to change the RTC battery holder anymore, that change request just came in to late. But i will plan to build myself a small Battery adapter to use the more commom CR2032.
    But overall the new Mainboard fits together with the new case like (Die Faust auf's Auge :wink: )
  • Very well, home-office, social distance etc .... :wink:
  • Tolle Sache! 😎
    Was ist da eigentlich jetzt für eine Batterie drinnen, dass das so ein Thema ist?
    A CR1220.
    have a read and continuing battery questions Bitte melde dich an, um diesen Link zu sehen. Thanks !
  • ist das nicht wurscht, ob man eine 2032 oder 1220 nimmt?
    A CR1220.
    :guckstdu:
  • Will the DevKit have space for the speakers too? Which model would you suggest?
  • At the moment we are just experimenting with old PC speakers, so to be honest we really can't give a suggestion at this time.
    I am quite certain you should be able to mount some speakers inside the Devkit as well, but there are no screwbosses prepared for mounting.
    but since there is a huge variety of 8 Ohm speakers, you can choose yourself.
    Within the next couple of days, there will be an update, regarding the Tests we have done so far, probably together with a small video, showing the internal speakers in action too.
    I have at the moment one of the latest Revision DevKit case over here, so thanks for your question, i'll have a look where it would be possible to mount some speakers.
  • Which model would you suggest?
    Better think big ...
    Bitte melde dich an, um diesen Link zu sehen. :D
    Uff is it for good low-frequency sounds or for destroying the whole block of houses nearby in case of lack of enough earthquakes nearby? :-O
  • OK, lots of work has been done in the previous days to verify the R3 boards.
    Paul did 2 very nice blogposts, that summarize a little bit of the work we did and give you a nice "behind-the-curtain" view.
    Bitte melde dich an, um diesen Link zu sehen. with more general testing.
    and Bitte melde dich an, um diesen Link zu sehen., with a deeper look into the IEC port testing
    And last but not least, as a special sneak-peak, here for the community:
    A test fit of the speakers (CMS-40504N-L152 4OHM 2W ENCLOSED 100DB) we had in mind when we added the screw bosses for speakers below the speaker connectors on the R3 board. we will not deliver the DevKit or the final MEGA65 with speakers, but of course we needed to test the amplifier that has been added to the R3 board. So as it is written on a lot of groceries, it's a "serving suggestion", ein "Serviervorschlag". :wink:
  • gibt es eigentlich Infos, wie es um den Amiga-Kernel steht? Wird der zeitgleich mit dem C64/65-Kernel oder zumindest zeitnah nach dem Verkaufsstart verfügbar sein? Ein Mega65 MIT Amiga-Kernel wäre für mich DAS Kaufargument...😁
    Es gibt leider noch keine offizielle Aussage von uns dazu, Ihr werdet sie aber hier so früh wie möglich bekommen. Verraten darf ich aber: Es wird daran gearbeitet :)
    cheers
    deft
    "VHDL schreiben ist wie in Mordor zu arbeiten. Es gibt viel Streben und viel Rauch, aber nur wenig Erfolg. Und Erfolg sieht meist schlimmer aus als Misserfolg" PGS 2019
