There is now a releases page on the github repo where they go. They aren't included as a binary blob under source control anymore.
LG
Paul.
LG
Paul.
Ok, I guess you need a permanent link that also survives updates. For now I guess the filehost provides this:
https://mega.scryptos.com/shar…ocs/MEGA65-Book_draft.pdf
Of course it will be our job to regularly update the pdf, however, the link will be pesistant.
best
deft
Sadly it doesn't work with this command:
wget https://mega.scryptos.com/sharefolder-link/MEGA/MEGA65+filehost/Docs/MEGA65-Book_draft.pdf
I need this for the update script in the Xemu live system.
I can't accept the "terms of use question" which is needed by https://mega.scryptos.com/sharefolder-login/MEGA/MEGA65+filehost within the wget command.
Why not leaving the "MEGA65-Book_draft.pdf" in the github site as done before? There wasn't any problem with wget.
We will look into this!
best
deft
It seems that all links to the ISO's are dead. Is it still possible to download the ISO from somewhere?
Strange, because I checked the link yesterday and all works fine. I'll look at mega.nz if something had gone wrong.
Okay, mega.nz has changed the link to the file without any notice to me. Nice "feature" of the filehoster.
Here is the new link to the iso file: Xemu live system 20200814
Maybe adtbm can please change the link also in the first post? Many thanks!
Thanks! Works much better now
Display MoreOk, I guess you need a permanent link that also survives updates. For now I guess the filehost provides this:
I'll use in future releases of the Xemu live system this link from the MEGA65 Filehost site for getting the current PDFs of the MEGA65-Book:
https://files.mega65.org/news/MEGA65-User-Guide.pdf
I assume that this link will always be updated with the latest PDF version of the Userguide?
Hi Snoopy ,
thanks for the update !!!
Two people from the team shifting quite some files at the moment, building PCs, etc. and it's all still w.i.p. but we're coming along pretty good !
(Thanks @ Dieter and Tayger !!! )
more official information is coming soon ! (PS: yes, we're working on, getting the latest version of a file/doc accessible at one link)
So thank you very much for following up and helping !
Because the filehoster mega.nz isn't very reliably with the download link (it was changed twice without a notice to me), I moved the iso file to my site.
Please use the download link "Xemu live system" (1,7 GB) at this site:
adtbm : If you find a minute, could you please change the link in the first post, so the new download site will be easily found? Thanks!
Snoopy : Done.
I hope it's OK. Otherwise let me know ! Thanks !!!
Perfect! Many thanks!
Hello your mega65 fan.
I wanted to test the meg65 for windows once.
I downloaded the emulator and this mega65 rom too.
the error message appears, see picture.
if I click further, the text comes from the mega65.
Where can I get the missing data from and how do I integrate it?
many thanks.
Display MoreHello your mega65 fan.
many thanks.
So, do what the message says (ie, right click into the emulator window to access the context menu, select option "SD-card" and the "update" option inside the sub-menu ... Surely after you dismissed this warning window you have shown). It will ask you for the ROM in a file selector box. Note, that you probably want the so called "closed ROM" not the "open ROM" though, but the "closed ROM" unfortunately is not "free" to access, because of legal reasons, outside of the scope of the MEGA65 project, and has roots about the legal status of the ownership of the ROM, still belongs to the respective owner, even for a ROM which is further developed but based on the original one (the so called "derivative work" or how it's called).
So the answer of your question in nutshell: exactly in the way the window tell you've just shown
You can download the latest ROM here: https://github.com/MEGA65/mega65-release-prep
Copy the MEGA65.ROM to your SD-Card and enjoy.
Hello, thanks for the help.
Mega65 has started.
What does this value show in the emulator at the top of the bar:
[100% 28%]
28% Flashes between 27% and 29%
Thank you.
Display MoreHello, thanks for the help.
Mega65 has started.
[100% 28%]
Thank you.
The first % shows the emulated speed of a MEGA65, ideally if your hardware is OK enough (ie your PC/Mac is fast enough), it should be 100% always. The second % shows the calculated CPU usage of the emulation, so it can be anything, but it's good to be a relative low value meaning, that emulation must even wait from time-to-time to be in sync with the emulated machine speed. Originally there was a single value, but people were complaining that it's confusing, as it shows like 27% or 29% (from your example) and they thought that the emulation is too slow, when in reality it's just the emulation internal CPU usage of the computer which runs Xemu. So then it has been moved as the "second % display" and the first shows the emulated speed. Of course the second value will change, depending the load of your system (Windows/Mac/Linux which runs Xemu - depends on what OS you're using -, ie it runs other programs as well not just Xemu), and the actual emulation task being hard or easier to do (like 320x200 screen is easier to be emulated than 640x400 - which requires more power from Xemu -, or for sure 40.5MHz emulation CPU clock requires more resources to be emulated than 1MHz ...)
