I tested yesterday with a self-compiled experimental Sidekick64 kernel based on 0.48 and I could play both HIRO and Instinct instrument-complete (with minor sound glitches).
Hallo Besucher, der Thread wurde 110k mal aufgerufen und enthält 1341 Antworten
letzter Beitrag von Cpt.Hardy am
Sidekick64 Aufbau, Probleme, Lösungen
- rafi
- Unerledigt
These settings should work for both HIRO and Instinct. Does Instinct crash also if you've not activated the sound emulation (F3)? (btw. 47b doesn't have MIDI support)
Instinct does not crash. It works properly without sound. When i active emulation (F3) i get black screen ( no logo ate bit )
I can only guess... does the C64 have any modifications (kernal etc)?
The C64 has not any modifications. I have tested only with shortboards. I have not any optional 10pF capacitors on my PCB.
if you disable the SFX emulation and keep "register read off", what does it do then?
I disable SFX emulation ( F5 - settings, "SFX Sound Exp - off" and keep "register read off" )
1. ate - Instinct runs like same, I set 0 for MIDI and 0 for SID delay on startup screen and start demo, I get black screen and nothing happens.
2. Hiro - runs, I get startup screen and info that no detect FM-YAM (NONE), I can swap Midi ( status OK and NONE ). Demo does not run. I get info about it.
Sid emulation works properly - I have usic from game or sid music files.
I tested on old breadbin machine (long board). Demos run like same with one exception. Hiro did not detect MIDI ( both NONE for Datel and Sequential ), but I could set those option manualy.
with these settings the Sidekick only listens to the bus but does not do any writes or anything that could crash the C64 (as long as the HW is ok).
what does not run mean? does it crash or can't you hear MIDI sounds?
just to be sure: have you placed sound font files into SD:/MIDI ?
Ohhhh. Of coz that have not.
I have not found info about it on github page.
Now playing all great !!!!
Thank you so much.
I have another question.
I have RGB-TFT display and I can't see logo in tga format. ( I get SideKick64 logo after run CRT image) . I have placed tga file example I have pop.crt ( EasyFlash image in SD:\CRT ) and I have placed pop.tga ( copy alpharay.tga from SD:/CART264 ) . I have seen logo on oled when I have placed pop.logo ( copy alpharay.logo ).
in principle it searches for pop.tga (in your case) in the same directory, so this sounds good if I understood you correctly. Note .logo is a 128x64 raw b/w image for the OLED screen, not the RGB-TFT. So which display do you have?
I have got both displays.
RGB-TFT - works fine i can run and display tga files on EasyFlash, Action Replay, Final III images ( tga files in SD:/SPLASH )
but when I have placed pop.tga ( it is a copy alpharelay.tga from SD:/CART264 ) and pop.crt ( Prince of Persia CRT image ) i watch only logo SideKick64 on screen.
Yes .logo on the OLED works well. ( only i dont know how create raw file 128x64 )
Wußte jetzt nicht ob ich hier schreiben soll oder im Haupt-Thread, aber da es ein "Problem" ist denke ich...hier:
Hab das SideKick64 vom RestoreStore, läuft auch wunderbar an meinem Sixtyclone64 - allerdings bekomme ich das Sidekick64 nicht mit dem TuningBoard ans laufen: ich komme partout nicht ins ModulMenu.
Hat jemand von euch das Sidekick auch in Verbindung mit dem TuningBoard am laufen? -
Funktionieren an Deinem Tuningboard am Expansionport alle anderen Module, die Du hast? Da Dein Sidekick ja funktioniert, ist es ja höchstwahrscheinlich ein Problem am Tuningboard - mangelnder Kontakt am Expansionport, Lötstelle vergessen oder so.
Ich habe ein Kung Fu Flash drin, das läuft.
Was heißt "drin"?
Am Expansions-Port eingesteckt
Würde mich primär erstmal interessieren ob jemand anders das Sidekick auch am TuningBoard betreibt, wenn es da rund läuft kann ich mich aufs TuningBoard stürzen - aber kann ja auch sein das durch dem "etwas" abweichenden Board-Design irgendwas am TuningBoard anders "tickt".
Zum Tuning-Board kann ich nichts sagen. Das KFF kenne ich nicht gut genug, um damit einen Fehler einzukreisen. Aber mal andersrum: was machen die Sidekick-LEDs?
Wenn der Rechner eingeschaltet ist: die rechte LED leuchtet und die beiden linken LEDs blinken abwechselnd
Du kannst ja mal die Tests aus diesem Post machen: Sidekick64 Probleme
Die benötigen jeweils nur einen Teil der Signale... alternativ kannst Du den RPi auch mal leicht übertakten (siehe RPi-Config-Files), vielleicht kommt irgendein Signal zu früh/zu spät. Aber was die Timings angeht: nachdem das SK eigentlich an allen möglichen Boards (C64+C128, PAL+NTSC) läuft, wäre das überraschend. Vielleicht ist auch eines der Signale auf Deinem Board unsauber (Flanke verschmiert, Pegel, ...). Wie gesagt, ein Tuning-Board habe ich nicht und kann's daher nicht direkt nachvollziehen.
Hmmm, da tut sich nichts mit den anderen beiden Kernels - verhalten bleibt identisch, ich schaue morgen mal das ich den etwas übertakte.
wenn der Kernel mit dem blinkenden Rand nichts tut, dann liegt da was im Argen. Ist die SK64-Stromversorgung extern oder über den Expansionsport? Was zeigt das HDMI Bild des RPi?
