letzter Beitrag von MarcusN am
Hilfe mein KU Replica läuft nicht
- MalleB
- Erledigt
mein KU läuft jetzt
OK bei der letzten Chip-Tausch-Aktion hat sich auf U30 ein 74LS193 geschlichen der da nicht hingehört. Aber der war nach dem richtigen einlöten des C86 auch noch schnell wieder gegen nen 74LS139 getauscht.
Ein super Dankeschön an ALLE die uns 'Anfängern' dabei immer wieder helfen unsere Projekte zum Laufen zu bringen!!!
Jetzt kannst Du Dich ganz entspannt dem widmen
GLÜCKWUNSCH!!!
Great work! I'm reading the discussion a bit late.
I will update the bom and schematics on the github repository. R42 is missing a value in BOM and schematics. It is 330 ohms on my KU prototype and original boards. RP1and RP2 I will double check. Also maybe add the suggestion to use traco regulator.
Thank you to everyone for keeping us updated
Yes. Me or someone can spin-off from this project . ADAC lso contacted me on twitter about ideas. Then I didn't hear anymore from him. I vented some ideas too. Mainly 12V dc input.. Here is from a nice chat I had with him while I waited for the subway train:
ZitatAdac:
And: the are some Usere who asked about a 'Special Edition' of this board
Proposals are:
- connect Pin1 an 16 of the Rams or connect Pin16 to GND or 5V (can be different for any Chip) so you can use 41256 Rams out of the box
- Protection diodes for IEC- an Tape-Port
- Internal IEC Pinheader to install an SD2IEC
- Integrated AEC-Fix
- use of the X1-Osscillator socket (8701? I dont know exacly...)- conpatiblity to 41256 Rams should be possilbe an easy
- and a IEC PInheader for SD2IEC might be also easy (if there ist enough room)-Protection Diodes: might be a Problem...
-AEC-Fix also
Me:
12V dc input + 50Hz generator for the tod.
ADAC hasn't been online for a couple of weeks ... I am quite convinced that he will contact you again as soon as he has solved his phone/internet problems.
RP1 & RP2 sind mit B330G und RP3 & RP4 mit A332G beschriftet?
Die Richtigkeit kannst du per Multimeter überprüfen. Die haben Pin 1 markiert (Punkt oder "1"). Von dem misst du zu Pin 2. Bei RP1 und RP2 müssen dort 33 Ohm zu messen sein, von Pin 1 zu Pin 3 unendlich/offen. Bei RP3 und RP4 zwischen Pin 1 und 2 3.3 kOhm, aber auch zwischen Pin 1 und Pin 3 und Pin 1 und Pin 4 usw.
Hmmm stimmt soweit. Danke. manchmal sind es auch nur 2,7k. Aber das liegt sicher an den anderen Bauteilen.
Im eingbauten Zustand? Ja, das ist wahrscheinlich. Aber selbst wenn nicht, die 3.3k-Widerstände sind PullUps, die erfüllen ihre Aufgabe auch mit 2.7k
Poste doch mal Bilder vom Board (Vorder + Rückseite) , evtl sieht man ja was... Viele Augen sehen mehr
Die Aufnahmen sind mit Blitzlicht gemacht. Ich hoffe man kann etwas erkennen. Da ich schon mal Ärger mit den billigen Sockeln hatte tausche ich die gerade gegen bessere. Ich hatte sogar einen dabei an dem ein PIN gebrochen war.
Hallo an alle KU-Experten,
ich habe heute das Replika-Board fertig gestellt, habe aber einen Blackscreen und brauche dringend Eure Hilfe!
Vorweg: Ich habe mittlerweile alle C= Chips außer CPU, PLA und VIC rausgeschmissen, alles andere ist voll bestückt. Ich habe den Modulatorersatz noch nicht fest eingelötet sondern über eine Stiftleiste gesteckt. Das lose weiße Kabel ist die GND-Verbindung (und mein GND-Meßpunkt). In einem anderen Board (250407) hat dieser bereits funktioniert und ein Bild geliefert.
Beim Einschalten wird definitiv ein Signal ausgegeben, das Testbild vom Retrotink springt dann auf schwarz. Der Dead-Test springt leider nicht an.
Folgendes habe ich schon gemessen:
Spannungen:
VR1: 12.02VVR2: 4.98V
CPU Pin 40: erst Null, dann 4.62V (Reset)
CPU Pinn 6: 4,84V
VIC Pin 13: 12.02V
VIC Pin 40: 4.98V
RAMs: An Pin 3 jeweils ca. 4.58V (das kommt mir etwas niedrig vor)
PLA Pin 28: 4,84V
Frequenzen:
VIC Pin 22: 2,15 bis 2,55MHz (je nach Stellung von R28) - das ist sicher zu niedrig, an einem funktionierenden 407er messe ich hier 7.882MHz
U29 Pin 9: 985kHz (das müsste passen)
U30 Pin 6: 1,97MHz (müsse auch passen)
U31 Pin 7: wie VIC Pin 22 (siehe oben)
U32 Pin 1: 985kHz (müsste auch passen)
CPU Pin39: ca. 350kHz (das ist viel zu niedrig, am 407er Vergleichsboard habe ich hier auch die 985kHz Systemtakt)
Spanungen scheinen mir gut zu sein aber irgendwo in der Takterzeugung muss ein Fehler sein. Bilder hänge ich an.
Ich bin kein ausgewiesener Experte und komme hier nicht mehr weiter. Bilder hänge ich an, vielleicht sieht jemand von Euch noch etwas. Bin für jede Hilfe dankbar,
viele Grüße, Stefan
Hallo CapFuture1975, Du hast recht, für R22 habe ich die Drahtbrücke nicht gezogen da in der BOM steht:
Ich kann die Brücke mal noch setzen, glauibe aber kaum, dass das etwas ändern wird. Schaffe ich aber heute wohl nicht mehr.
