You are not logged in.
Dear visitor, welcome to Forum64. If this is your first visit here, please read the Help. It explains in detail how this page works. To use all features of this page, you should consider registering. Please use the registration form, to register here or read more information about the registration process. If you are already registered, please login here.
skoe
macht komische Sachen
  • "skoe" is male
  • »skoe« is a verified user
Date of registration: Nov 12th 2003
  • Send private message
member since 108 month member since 108 month member since 108 month member since 108 month member since 108 month member since 108 month
361
Thursday, February 9th 2012, 8:15pm
Funktioniert das, wenn Du beim Einschalten eine der Tasten gedrückt hältst? Ist der Fehler weg, wenn Du USB anschließt (hat jmp auch schon gefragt, ja).
Wenn das der Fall ist, melde Dich mal per PN bei mir. Dann ist das ein bekanntes Problem.
Vergiss BASIC und lern C! C lernen mit cc65 und C64
Bau Dir ein eigenes Modul! EasyFlash
Ebster
a.k.a. Firecracker of MASK
  • "Ebster" is male
Date of registration: May 30th 2006
member since 72 month member since 72 month member since 72 month member since 72 month
362
Thursday, February 9th 2012, 8:16pm
mach ich gleich, nur kurz: die taster am easyflash gehen, die tastatur reagiert quasi nicht.
skoe
  • "skoe" is male
363
Thursday, February 9th 2012, 8:19pm
Schon verstanden. Ich meinte auch die Tasten an der Tastatur :)
Ebster
  • "Ebster" is male
364
Thursday, February 9th 2012, 8:35pm
hast pn.
Retro-Nerd
Esst mehr Gemüse!
  • "Retro-Nerd" is male
  • »Retro-Nerd« is a verified user
Date of registration: Sep 3rd 2007
member since 54 month member since 54 month member since 54 month
365
Friday, February 10th 2012, 7:14pm
Quoted
33 seconds disk write
Das ist aber verdammt schnell. 8)
skoe
  • "skoe" is male
366
Friday, February 10th 2012, 9:48pm
Hat auch verdammt viel Arbeit gemacht :) Aber auch nur, weil ich nirgens abkupfern wollte, sondern es selbst zusammengefrickelt hab.
Ca. 3 Sekunden könnte man auch noch wegoperieren, aber mit unverhältnismäßigem Aufwand. Momentan dreht sich die Disk nämlich nach jedem Spurwechsel im Mittel 1/2 Umdrehung mehr, ohne dass Daten geschrieben werden.
Dadys_Toy
LDA#$8Bit: STA$C64: RTS
  • "Dadys_Toy" is male
  • »Dadys_Toy« is a verified user
Date of registration: Jul 9th 2008
367
Tuesday, February 14th 2012, 7:03pm
Habe mein EasyFlash3 nun auch (über Umwege ;)) erhalten und bin fleißig am probieren, flashen, Gehäuse basteln.
Vielen Dank an die Entwickler und die Leute die ihr Wissen und Können da hinein gesteckt haben! Neben dem EasyFlash werde ich auch das "3er" sehr gut behandeln und erhalten. Ist wirklich Klasse wie einfach und locker das geht. -ein großes Lob und Dankeschön! :thumbsup:
Beim Flashen der neuen CPLD-Firmware ist mir aufgefallen das Donald meins in der JTAG-Position stehen hat lassen. Demnach kann man es auch so verwenden denn ich teste schon ein paar Tage lang. Sollte man dennoch den Jumper wieder umstecken? Ich möchte nicht jedes mal wenn ich eine neue Firmware aufspiele das Gehäuse auseinander nehmen. Das hält dann sicher nicht lange durch.
mfg :)
Meine Termine:
04.05. - 7. Lange Nacht der Computerspiele - Leipzig
10.05. - 12.05. Amiga User Treffen Ost
21.09. - 22.09. ClassicComputing Berlin
21.02. - 23.02.2014 BCC Party#8 Berlin :D
Manawyrm
VDE ist, wenn ich das sage ;)
  • "Manawyrm" is male
Date of registration: Jul 10th 2010
member since 18 member since
368
Tuesday, February 14th 2012, 8:29pm
Kann es sein, dass wir mit unserer Bestellung heute bei Donald, alle EF3s gekauft haben? Die werden im Shop gar nicht mal mehr gezeigt :D
EDIT: Zum Teufel. Heute morgen waren sie leer :D @Donald: Wo zur Hölle hast du die noch gefunden?
Besucht mich mal: http://tbspace.de
369
Wednesday, February 15th 2012, 8:59am
Der amerikanische Markt scheint jetzt auch bedient zu werden: klick
skoe
  • "skoe" is male
370
Wednesday, February 15th 2012, 9:01am
Die falsche Jumper-Position wird Dich erst stören, wenn Du mal USB-Software benutzt, also d64-Writer etc.
Wegen des Umjumperns braucht man sich keine Sorgen machen, mehr als ein CPLD-Update alle paar Monate ist nicht zu erwarten. Und wenn alles fertig ist, kommt gar keins mehr. Als Vergleich kann man sich überlegen, dass z.B. für das Retro Replay oder das Alien-Flash gar keine CPLD-Updates (durch den User) vorgesehen sind/waren. Und für reine Software-Updates, die auch auf längere Sicht zu erwarten sind, braucht man nicht umzujumpern.
Dadys_Toy
371
Thursday, February 16th 2012, 5:55am
Okay. "...alle paar Monate..." ist für mich machbar. ;)
mfg :)
Meine Termine:
Retro-Nerd
Esst mehr Gemüse!
372
Monday, February 27th 2012, 11:13pm
Das mit den nicht funktionierenden Tasten (sporadisch beim einschalten) ist mir auch aufgefallen. Wenn ich z.B. "A" für den ersten Slot drücke passiert nichts, egal wie oft ich drücke. In dem Moment, wo ich das USB Kabel anschliesse, wird der Tastendruck "A" erkannt und das Programm/Spiel gestartet. Der Jumper steht derzeit auf Datentransfer. Ist das normal, dass in dieser Jumperstellung das Kabel angeschlossen sein muß um den Fehler der blockierten Tastatur im EasyFlash Menü zu umgehen? Oder ist das ein bekannter Bug?
Unseen
Hätte gerne 'n Virtex 7 ;)
  • "Unseen" is male
  • »Unseen« is a verified user
Date of registration: Jun 16th 2007
373
Monday, February 27th 2012, 11:17pm
Das ist ein bekannter Bug
Quellcode
1
2
3
30 printint(rnd(1)*328)-217
sd2iec Homepage
Retro-Nerd
Esst mehr Gemüse!
374
Monday, February 27th 2012, 11:21pm
Danke für die Info. Ist dann wahrscheinlich schon gefixt. Das neue USB Transfer Update, samt PC EasyTransfer, dürfte skoe ja bald fertig haben.
Donald
Super Moderator
  • "Donald" is male
  • »Donald« is a verified user
Date of registration: May 5th 2007
375
Tuesday, February 28th 2012, 7:10am
Hi Retro-Nerd,
hast PN bekommen.
Gruß Donald
Dadys_Toy
376
Wednesday, February 29th 2012, 9:36pm
Hm, ich hab bei meinem EF3 im Moment dauerhaft die Stellung "Datentransfer" -also die Jumper oben, CPLD-flashbereit. Und bei mir funktioniert die Tastatur am 0466er Board genauso prima wie auf der BCC#6 an verschiedenen C64 und sogar dem C128.
Verwechsele ich jetzt die Jumpereinstellungen? Mein EF3 ist eines der Ersten.
mfg :)
Meine Termine:
Retro-Nerd
Esst mehr Gemüse!
377
Wednesday, February 29th 2012, 9:50pm
Ja, CPLD flashbereit wäre die "PROG" Stellung, Datentransfer die "DATA" Einstellung. Donald hat mich mittlerweile informiert, dass das Problem sporadisch bei einigen der frühen EasyFlash Platinen auftreten kann. Fehlt wohl ein passender Widerstand.
Ebster
  • "Ebster" is male
378
Wednesday, February 29th 2012, 10:09pm
donald hat bei mir ultraschnell und unkompliziert "nachgebessert" - flashe eben die slots - neue cpld ist drauf und die tasten reagieren wunderbar. mit den jumpern habe ich mich ehrlich gesagt noch gar nicht beschäftigt *schäm* ist alles noch im auslieferungszustand.
Retro-Nerd
Esst mehr Gemüse!
379
Wednesday, February 29th 2012, 10:12pm
In der "PROG" Einstellung hatte ich nie Probleme, nur in der "DATA" Einstellung. Also seit Tom-Cat die USB Tools veröffentlicht hat. Bei dir scheint es aber auch in der "PROG" Stellung wohl den gleichen Fehler gegeben zu haben.
Ebster
  • "Ebster" is male
380
Wednesday, February 29th 2012, 10:15pm
scheint so, hatte die neue cpld + menu+init draufgespielt und eben genau danach den fehler..
