Dear visitor, welcome to Forum64. If this is your first visit here, please read the Help. It explains in detail how this page works. To use all features of this page, you should consider registering. Please use the registration form, to register here or read more information about the registration process. If you are already registered, please login here.
Zitat
Sind Sie halten mit der Commodore?
Installiert...
Quoted
"install libwxgtk2.8-dev or whatever name it has on your system"
Nööö... hat es aber nicht... JETZT hab ich es nachinstalliert.
Quoted
This will
hopefully also install all other dependencies like libwxbase2.8-dev
Ich habe auch jetzt nur Fehlermeldungen wenn ich versuche NACH dem Verzeichnisswechsel
Quoted
2. compile it (as normal user) using these commands:
cd make/gcc-default
make
3. install it (optional, as root) using this command:
sudo make install
Forum Software: Burning Board® 3.1.7, developed by WoltLab® GmbH
