You are not logged in.
x1541
1. Vorsitzender VzEkC e.V.
Date of registration: Nov 24th 2002
  • Send private message
member since 84 month member since 84 month member since 84 month member since 84 month member since 84 month member since 84 month member since 84 month
21
Friday, July 24th 2009, 2:53pm
Nach dieser langen Bedenkzeit so eine schwache Attacke :lauh3: Ab und zurück in den Wald zum üben :bgdev
Besucht meine Hardwareprojekte:
http://www.x1541.de
Powered by WWW.VIC-20.DE
www.classic-computing.de
Verein zum Erhalt klassischer Computer e.V.
sauhund
ist falsch abgebogen
  • "sauhund" is male
  • "sauhund" has been banned
Date of registration: Jul 16th 2005
member since 60 month member since 60 month member since 60 month member since 60 month member since 60 month
22
Friday, July 24th 2009, 3:00pm
du kämpfst wie eine kuh!
sauhund
  • "sauhund" is male
24
Friday, July 24th 2009, 3:58pm
falsche antwort, versuch's nochmal :)
  • »C64-CAMPER« is a verified user
Date of registration: Mar 31st 2006
member since 48 month member since 48 month member since 48 month member since 48 month
25
Friday, July 24th 2009, 4:09pm
Das war schon richtig, zumindest, wenn du das aus Monkey Island zitiert hast.
http://www.bit-collector.org
Classic Computing 2010: http://www.area64.info
Classic Gamers Paderborn: http://www.classic-gamers.de
ReCoMe Paderborn: http://www.recome-paderborn.de
sauhund
  • "sauhund" is male
26
Friday, July 24th 2009, 4:14pm
ja äh...woher sonst? :) aber, das mit der kuh ist schon die antwort (und ja, nicht ganz richtig zitiert) - darauf muss aber eine vorlage folgen :)
mc71
Professional
Date of registration: Nov 30th 2005
27
Thursday, July 30th 2009, 2:05am
Euer Reich ist größer als mein Garten, aber meine Lanze ist härter als dein Brustbein...
skoe
sternsternstern sternsternstern sternsternstern sternsternstern
  • "skoe" is male
Date of registration: Nov 12th 2003
member since 72 month member since 72 month member since 72 month member since 72 month member since 72 month member since 72 month
28
Tuesday, August 25th 2009, 8:34pm
gikauf: 1 neoram aber 2 gehäuse?
Was ist daran komisch? Er schrieb doch 1 Neoram mit 2 MByte. Jedes MByte bekommt ein Gehäuse, wegen der Wärmeentwicklung.
Vergiss BASIC und lern C! C lernen mit cc65 und C64
Bau Dir ein eigenes Modul! EasyFlash
Unseen
Ia! Ia! sd2iec fhtagn!
Date of registration: Jun 16th 2007
member since 36 month member since 36 month member since 36 month
29
Tuesday, August 25th 2009, 9:00pm
Oh weh, wie soll ich denn vier Gehäuse hinter meinem C64 unterbringen wenn ich die Platine erstmal auf 4MB hochgelötet habe?
skoe
  • "skoe" is male
30
Tuesday, August 25th 2009, 9:08pm
Stacken. Mit Backplane. Die kann man gut aus alten Haferflockenpackungen machen. Du stellst Dich ja auch manchmal an...
31
Tuesday, August 25th 2009, 9:11pm
Es gibt doch um 89€ Aufpreis die wassergekühlte Version von X1541, dann gehen bis zu 1GB RAM in ein Gehäuse ... :roll2:
skoe
  • "skoe" is male
32
Tuesday, August 25th 2009, 9:28pm
Na toll. Da entwickelt sich endlich mal *richtige* Hardware und der doofe Sack schiebt und in den Laberthread. Der ist doch nur zu faul, sich selbst Gedanken über das Multi-Gehäuse zu machen. Grrr.
x1541
33
Tuesday, August 25th 2009, 9:34pm
Skoe: bin ja nun als superprivilegierter Early Adopter und Betatester vom Easyflash geworden, ich nehme also an ich muss da ein noch nie dagewesenes Megadoppelwhoppermegaschnitzelgehäuse (ohne Kruscht) erwarten :blah!
http://www.x1541.de
skoe
  • "skoe" is male
34
Tuesday, August 25th 2009, 9:48pm
Na rate mal, warum Nils neulich Salsa und Servietten geordert hat?!
(Man, jetzt muss ich aber bald aufhören, sonst krieg ich noch Forum-Verbot)
Gikauf
Master
  • "Gikauf" is male
  • »Gikauf« is a verified user
Date of registration: May 16th 2005
35
Tuesday, August 25th 2009, 11:00pm
Willst du auf deine Blöde Frage, auch eine Blöde Antwort, oder einfach nur hören, daß dich das gar nichts angeht?
Teile es mir mit, wenn du dann die Antwort hast.
Für X1541, das 2. Gehäuse, ist für meine 1. Neoram.
Unseen
36
Tuesday, August 25th 2009, 11:21pm
Stacken.
Och nee, das Stapeln der SRAMs und der beiden '138 wird schon unschön genug, vom freifliegenden Hühnerfutter als Inverter ganz zu schweigen...
x1541
37
Tuesday, August 25th 2009, 11:24pm
Anfänger. Die zweiten 2MB werden elegant auf die Unterseite gelötet, Du musst nur 4x32=128 Bohrungen machen und durchverdrahten auf die Unterseite. Dito lötest Du die TTLs von unten spiegelbildlich noch einmal auf :weg:
http://www.x1541.de
mc71
Professional
38
Friday, August 28th 2009, 4:00am
Was sind denn das für vorsintflutliche Konstruktionsmethoden? *haarerauf* So ein DIL biegt man ein wenig zusammen, dann klemmt das von alleine wenn man's auf das bereits eingelötete draufsteckt...
Unseen
39
Friday, August 28th 2009, 1:03pm
Aber passt es dann noch in ein normales Modulgehäuse?
40
Friday, August 28th 2009, 1:05pm
Wenn nicht, dann muss man es halt passend machen. Genügend Druck macht alles flach ... :lol27:
