You are not logged in.
Dear visitor, welcome to Forum64. If this is your first visit here, please read the Help. It explains in detail how this page works. To use all features of this page, you should consider registering. Please use the registration form, to register here or read more information about the registration process. If you are already registered, please login here.
sauhund
ist falsch abgebogen
  • "sauhund" is male
Date of registration: Jul 16th 2005
  • Send private message
member since 90 month member since 90 month member since 90 month member since 90 month member since 90 month
21
Monday, January 16th 2012, 7:19pm
Quoted
Die Platinen ohne Kondensatoren bezeichnet man auch als MMC64-CR (cost reduced)
quatsch, das heisst capacitor reduced. kosten tuts doch das gleiche!
http://www.hitmen-console.org http://magicdisk.untergrund.net
Die Furcht vor der freimütigen Antwort kann auch robuste Charaktere befallen.
AntaBaka
Z̵̰͊ͮ̏͗͐ͣ̒A̬̲̪̣̤͆̍̚L̥̦̈ͬ́G͏͉O̝̞̣̜̬͂̐ ҉̲̦̜̫I̛̟̥̯̳͂̽̃̈́̐S̿̃̑͆̓ͦͯ͏̘̣̝̹̙̣̮ ͔̳͚̞̖̙̥͌͗ͧ̅̓́̊͢Ţ͙̗́ͦ́̅O̩̼̠̣̺͐̊ͪN̦̄ͧ͒Y͓̺͍̖͂ͦͯ͝ͅ ̞̘͇̣͐̓ͤ̇͐T͚͖̑̿ͯ̃͐̋͡Ḧ̡̻͚͔̳̙̤́̀̽̋ͥ̚E̵͉̤̻̘̰͆ ͑̄҉̞̗͓̣͍P̵̝̘̼͍̱͌̍̾͒ͅO̸ͭN̺ͦ̀ͫÝ͖̦ͤ̒̃̽̾̚
  • "AntaBaka" is male
  • »AntaBaka« is a verified user
Date of registration: Oct 29th 2006
member since 72 month member since 72 month member since 72 month member since 72 month
22
Monday, January 16th 2012, 7:22pm
Den Endkunden, ja. :D
mc71
Professional
Date of registration: Nov 30th 2005
23
Monday, January 16th 2012, 10:57pm
Wenn Jens die nachträglich runterdengeln lassen hat (und so sehen die Lötpads mbMn aus) dann ist die Platine mit ohne Kondis sogar teurer in der Herstellung gewesen...
24
Monday, January 16th 2012, 11:08pm
Das erledigen die Beta-Tester und End-Anwender :D
Rayne
In den Krallen der 8 Bit
  • "Rayne" is male
Date of registration: Apr 19th 2008
member since 54 month member since 54 month member since 54 month
25
Monday, January 16th 2012, 11:26pm
Ich hab' ein blaues MMC64 und da sind alle Kondensatoren drauf...
Im Auftrag der Commodore Semiconductor Group unterwegs.
wfking
CBM User
  • "wfking" is male
Date of registration: Jul 18th 2004
26
Tuesday, January 17th 2012, 11:49am
Vielleicht wurden manche MMC64 Platinen ab Werk mit den falschen Kondensatoren bestückt und diese mußten dann nachträglich wieder entfernt werden. So nach dem Motto: Besser gar keine Kondis als falsche Kondis...
JMP$FCE2
Unwissender
  • "JMP$FCE2" is male
Date of registration: Feb 16th 2008
27
Tuesday, January 17th 2012, 12:28pm
Quatsch. An den Stellen wo die Fehlen ist das sogar recht egal welchen Wert die haben.
Ausserden sehen die Lötstellen auf den gnazen Fotos direkt so aus als wenn die Benutzer die selbst duch Unachtsamkeit abgerissen haben.
Hier gibt es nichts zu sehen! Gehen Sie bitte schnell weiter.
  • "Gerrit" is male
  • »Gerrit« is a verified user
Date of registration: Mar 27th 2011
member since 18 member since
28
Tuesday, January 17th 2012, 12:59pm
Wenn es Kondensatoren waren und nicht eine Fehlbestückung z.B. mit kleinen Widerständen oder Null-Ohm-Brücken (die auch wie Widerstände aussehen).
Dirk Vroomen
Professional
  • "Dirk Vroomen" is male
Date of registration: Feb 7th 2010
member since 36 month member since 36 month
29
Tuesday, January 17th 2012, 1:13pm
Könnte es sein, dass sich die SMD-Bauteile mit der Zeit lösen, weil etwas mit der Zusammensetzung des Zinns nicht gepasst hatte? Auf jeden Fall war da definitiv was verbaut und ich kann mir beim besten Willen nicht vorstellen, dass in dieser Häufung eine Fehlbestückung oder ein versehentliches "Abreissen" vorliegt.
Gruß Dirk
gesendet über Robotron Lochbandtechnik mit A 5120
schlonkel
Landgräfin Schnorchel von Möhren
  • "schlonkel" is male
  • »schlonkel« is a verified user
Date of registration: Jul 6th 2004
30
Tuesday, January 17th 2012, 4:22pm
Genau. Die Anwender sind doof. Erinnert mich an den Spruch von einem Softwareentwickler dem das Ganze wirklich Spaß machen würde wenn doch die Nutzer der Software nicht wären. Den Spruch kann man ja portieren und anpassen. Und dann darf man noch Betatester und Fixateur spielen. Erinnert mich irgendwie an... ja... an Großindustriemachenschaften. Doch alle in einen Sack?!
DoReCo #37: 22.06.2013 - INFO - Stammtisch #28: 18.05.2013 - INFO
Markuslohse74
Super Evil Mod
  • "Markuslohse74" is male
  • »Markuslohse74« is a verified user
Date of registration: Jan 10th 2006
31
Wednesday, January 18th 2012, 2:28am
Also bei mir waren definitiv Kondensatoren auf der Platine das Sehe ich wen ich Das Foto auf meine Homepage anschaue. Deswegen gehe ich davon aus das ich selber die Kondensatoren irgenwie runtergerissen habe ,vielleicht beim ein und ausstecken oder der Mitnahme zur DoReCo oder sonst wie. Na ja wen der Beta Test des Chameleon beendet ist werde ich mir das kaufen, aber solange reicht mir mein MMC64 vollkommen :D.
2. Platz beim Home Page Award am 14.06.2009 :D
http://commodore-museum-lohse.npage.de
Schaut mal rein :winke: Möge der c64 mit dir sein!
