You are not logged in.
Dear visitor, welcome to Forum64. If this is your first visit here, please read the Help. It explains in detail how this page works. To use all features of this page, you should consider registering. Please use the registration form, to register here or read more information about the registration process. If you are already registered, please login here.
medenbacher
Beginner
Date of registration: Oct 15th 2009
  • Send private message
member since 36 month member since 36 month
21
Friday, April 2nd 2010, 1:48pm
C 64 sogar noch In der ARD am 1. April
war sogar der ARD noch was wert..
C 64 als Notcomputer wenn die Server abstürzen...
http://www.tagesschau.de/ausland/internetabschaltung100.html
Lutz G
Master
  • "Lutz G" is male
Date of registration: Jan 15th 2005
member since 90 month member since 90 month member since 90 month member since 90 month member since 90 month
23
Friday, April 2nd 2010, 4:31pm
http://www.alice-dsl.net/lgoerke/aprilapril.html
@Lutz_G:
Gibt es die "Treiberprogramme" irgendwo zum Download?
Würde mich ja mal interessieren, was die so machen.
Diese DATA-Zeilen können ja alles mögliche enthalten.
Zeigen die Programme dann sowas wie "April, April!" oder "Ätsch!" an?
Wäre ja für den Aufwand, das abzutippen, sicher nicht schlecht!
Welche "Treiberprogramme" meintest Du? Kann sein, dass ich die mittlerweile mit auf der Seite hab ;)
Lutz
Lutz G
Master
  • "Lutz G" is male
Plop 242
Unregistered
25
Sunday, April 1st 2012, 12:42pm
In der RUN gab es damals einen Artikel zu WOM-Bausteinen - Write Only Memory. Beschreiben und wegschmeißen. ^^
  • "internium" is male
Date of registration: Aug 30th 2008
member since 54 month member since 54 month member since 54 month
Unseen
Hätte gerne 'n Virtex 7 ;)
  • "Unseen" is male
  • »Unseen« is a verified user
Date of registration: Jun 16th 2007
member since 72 month member since 72 month member since 72 month member since 72 month
27
Sunday, April 1st 2012, 12:46pm
Signetics 25120 (Datenblatt hier, Hintergrund z.B. hier) oder was eigenes?
Quellcode
1
2
3
30 printint(rnd(1)*328)-217
sd2iec Homepage
Plop 242
Unregistered
28
Sunday, April 1st 2012, 12:47pm
Ich besitze leider nur den Erinnerungsfetzen. Das betreffende Heft habe ich noch nicht wiedergefunden. :anonym
Lutz G
Master
  • "Lutz G" is male
29
Sunday, April 1st 2012, 1:14pm
*g*
Wenn Du das Heft noch findest (Ausgabe #?) - bitte den Artikel einscannen!
Lutz
schlonkel
Landgräfin Schnorchel von Möhren
  • "schlonkel" is male
  • »schlonkel« is a verified user
Date of registration: Jul 6th 2004
member since 108 month member since 108 month member since 108 month member since 108 month member since 108 month member since 108 month
30
Sunday, April 1st 2012, 1:29pm
Sicher dass das die RUN war? Hab mal die Aprilausgaben gesichtet. Da gibt es Scherze, einen vom WOM hab ich aber nicht gefunden.
DoReCo #37: 22.06.2013 - INFO - Stammtisch #29: xx.06.2013 - INFO
Lutz G
Master
  • "Lutz G" is male
31
Sunday, April 1st 2012, 1:36pm
BTW: Habe gerade zufällig gesehen, dass mir noch das PRG zum Cardreader Artikel (s.o.) fehlt: "Cashcard". Weiß jemand welche Ausgabe (Jahr? *g*) das war bzw kann man das Teil irgendwo saugen?
Edit: 4/90 dürfte das sein?
Lutz
sac
Alle Kinder mit Grips lesen Yps!
  • "sac" is male
Date of registration: Dec 12th 2010
member since 18 member since
32
Sunday, April 1st 2012, 1:50pm
Man musste es selbst abtippen. Man braucht aber den MSE (Maschinensprache Editor) dafür.
Edit:Hatte das falsche Programm angehängt.
sac has attached the following file:
"Das ist megaaffentittenfrittenturbogeil!"
Zitat meines Grundschulsportlehrers im Jahre 1983.
WTE
Master
  • "WTE" is male
  • »WTE« is a verified user
Date of registration: Feb 11th 2005
33
Sunday, April 1st 2012, 2:08pm
Aprilscherze aus der GO64: http://www.c128.net/articles/idx_april.htm
  • "Delphin64" is male
Date of registration: Jun 10th 2005
34
Sunday, April 1st 2012, 2:26pm
Der mit dem Aufbügeln der Bits ist aber sehr leicht durchschaubar, schließlich weiß ja jeder, dass ein Dampfbügeleisen in der Stellung Seide gar nicht dampft. :P
do9brx
Der tut nicht, der will nur spielen
  • "do9brx" has been banned
35
Sunday, April 1st 2012, 4:29pm
„Wer zum Teufel will denn Schauspieler sprechen hören?“
Harry M. Warner, Chef von Warner Brothers, 1927 zum Thema Tonfilm
Lutz G
Master
  • "Lutz G" is male
36
Sunday, April 1st 2012, 5:03pm
Ok - thx - vielleicht kam das PRG noch auf einer der 64er Disks mit? Ansonsten hatten wir hier doch im Forum einen, der besonders gerne abtippt *g*
Listings abtippen
Lutz
CrazyIcecap
- Teilelieferant der Connected ;)
  • "CrazyIcecap" is male
  • »CrazyIcecap« is a verified user
Date of registration: Jan 31st 2006
37
Sunday, April 1st 2012, 5:42pm
Hmmmm....was ist daran der Aprilscherz? Die Platine sagt mir nix...
Elektrogeräte werden mit Rauch betrieben. Kommt der 'raus, ist das Gerät kaputt.
Der Norden lebt RETRO !
! [connected] 12 - 31.05. bis 02.06.2013 !
Unseen
  • "Unseen" is male
38
Sunday, April 1st 2012, 5:50pm
Apple I
Quellcode
1
2
3
sd2iec Homepage
hobbycoder
Elektrofummler
  • "hobbycoder" is male
Date of registration: Feb 23rd 2009
39
Sunday, April 1st 2012, 5:51pm
Apple I von 1976, nur 200 Exemplare gefertigt, geschätzt 70 noch erhalten, wird heute im mittleren 4-stelligen US$-Bereich gehandelt. ;)
Edit: Unseen war schneller.
How can you know where you've been?
In time, you'll see the sign
and realise your sin.
CrazyIcecap
40
Sunday, April 1st 2012, 5:59pm
Ah, alles klar. Apple I hätte mir auch noch nix gesagt bzgl. Aprilscherz.
