Dear visitor, welcome to Forum64. If this is your first visit here, please read the Help. It explains in detail how this page works. To use all features of this page, you should consider registering. Please use the registration form, to register here or read more information about the registration process. If you are already registered, please login here.
Wie ist das mit den Spielen ? Kann ich die kostenlos herunterladen als Freeware oder muss man dafür noch zahlen ?
Wo kann ich mir z. B. sicherheitskopien herunterladen ?
Beim C64 sind ja die Spiele kostenlos.
Z̵̰͊ͮ̏͗͐ͣ̒A̬̲̪̣̤͆̍̚L̥̦̈ͬ́G͏͉O̝̞̣̜̬͂̐ ҉̲̦̜̫I̛̟̥̯̳͂̽̃̈́̐S̿̃̑͆̓ͦͯ͏̘̣̝̹̙̣̮ ͔̳͚̞̖̙̥͌͗ͧ̅̓́̊͢Ţ͙̗́ͦ́̅O̩̼̠̣̺͐̊ͪN̦̄ͧ͒Y͓̺͍̖͂ͦͯ͝ͅ ̞̘͇̣͐̓ͤ̇͐T͚͖̑̿ͯ̃͐̋͡Ḧ̡̻͚͔̳̙̤́̀̽̋ͥ̚E̵͉̤̻̘̰͆ ͑̄҉̞̗͓̣͍P̵̝̘̼͍̱͌̍̾͒ͅO̸ͭN̺ͦ̀ͫÝ͖̦ͤ̒̃̽̾̚
This post has been edited 1 times, last edit by "AntaBaka" (Jun 3rd 2011, 7:05pm)
Gravenreuth
) oder sind die alle diesbezgl. absolut gleich ?
Quoted
There are some guidelines to help you though:
- a + with a number (ie. +3) usually means it comes with a trainer that has 3 options.
- if there is a name after the game name then it's usually either the creators of the game or the group that hacked it. There is no way to verify which of the two it really is unless you start the game itself.
- some games have extra information in brackets () or []
- some games or roms are different per region, the region in question is usually shown between brackets like this (USA) for US games. Other countries you can encounter are (J) Japan, (E) or (EU) Europe, (U) no region, (SP)Spain and (G) or (D) German. These are not always correctly printed though and sometimes (U) means (USA).
- Sometimes different versions of games are released or re-released, usually the version numbers are shown.
- Files that are verified to be good usually have a [!] added to the name.
- Other codes can be [a] for alternative, [o] overdump which might or might not work and for bad. There are others but these are the main ones.
Source code |
1 2 3 4 5 6 7 8 9 |
[U] = USA (d.h., das Programm ist dort erschienen; indirekt sagt das also auch etwas über NTSC und PAL) [J] = Japan [E] = Europa [u] = Underdump (die Datei ist also kleiner, als sie sein müsste) [a], [a1], ... = alternativer Dump [b], [b1), ... = bad Dump (sprich: fehlerhaft) |
Zitat
Sind Sie halten mit der Commodore?
Quoted
Was braucht man noch?
TransWarp (Transdisk) am Amiga. Hier steht, wie man transdisk auf den Amiga bekommt: FAQ
Nullmodem Kabel
Ich brauche Hyperterminal auf dem Amiga oder ? Wenn ich keine Diskette für den Amiga habe kann ich nichts machen oder ?
hat einer schon mal versucht das Amiga laufwerk am pc anschliessen ? kann ich dann Amiga Disketten lesen ?
Forum Software: Burning Board® 3.1.7, developed by WoltLab® GmbH
