You are not logged in.
Schwarzes_Schaf
Unregistered
21
Tuesday, August 12th 2008, 8:18pm
Keine Ahnung ob es jemand interessiert, aber hier findet man *das aktuelle*, gepatchte und stark verbesserte sidplay.
Neueste Version: http://oms.wmhost.com/misc/sidplay2_win32_080810.zip ( 10 August 2008 )
Seite: http://oms.wmhost.com/misc/
FXXS
Freibeuter
  • "FXXS" is male
Date of registration: Oct 28th 2005
  • Send private message
member since 108 month member since 108 month member since 108 month member since 108 month member since 108 month member since 108 month
22
Wednesday, August 13th 2008, 6:34am
und von wem wurde es gepatscht? und was kann es nun besser??
sl FXXS
sauhund
Unregistered
23
Wednesday, August 13th 2008, 6:37am
alankila... vor allem die 6581 emulation hat er deutlich verbessert. details hier: http://bel.fi/~alankila/c64-sw/
HOL2001
DoReCo-Mitbegründer
  • "HOL2001" is male
  • »HOL2001« is a verified user
Date of registration: Dec 23rd 2004
member since 126 month member since 126 month member since 126 month member since 126 month member since 126 month member since 126 month member since 126 month
24
Wednesday, August 13th 2008, 7:41am
Sehr schön ! :)
assiduous
Unregistered
25
Wednesday, August 13th 2008, 3:07pm
yes it would be great to have Sidplay2/w that comes with SIDTool replaced with this new version.
Baracuda
Unregistered
26
Wednesday, August 13th 2008, 3:51pm
:dafuer:
Schwarzes_Schaf
Unregistered
27
Wednesday, August 13th 2008, 7:55pm
Und vor allem sollte es dann bei Gelegenheit auch ein kleines Auswahlmenü für die verschieden SID Filter geben, damit das konfigurieren in der ini entfällt. :)
Baracuda
Unregistered
28
Wednesday, August 13th 2008, 10:42pm
Danke für den Link.
Madman
Unregistered
29
Thursday, August 14th 2008, 2:42pm
Gibts doch schon. Zumindest für WinVice.
Schwarzes_Schaf
Unregistered
30
Thursday, August 14th 2008, 3:13pm
Quoted
Äh naja. Beim neuen Sidplay reicht es nicht mehr, die Filter nur mit 6581 oder 8580 anzuwählen, da mehrere Cutoff Charakteristika für 6581 zur Verfügung stehen.
Madman
Unregistered
31
Thursday, August 14th 2008, 5:59pm
Gibts ne Doku über die Commandlineparameter?
Schwarzes_Schaf
Unregistered
32
Friday, August 15th 2008, 5:20pm
Diese hier?
Source code
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
--help|-h    display this screen
 --help-debug debug help menu
 -b<num>      set start time in [m:]s format (default 0)
 -f<num>      set frequency in Hz (default: 44100)
 -fd          force dual sid environment
 -fs          force samples to a channel (default: uses sid)
 -nf[filter]  no/new SID filter emulation
 -ns[0|1]     (no) MOS 8580 waveforms (default: from tune or cfg)
 -o<l|s>      looping and/or single track
 -o<num>      start track (default: preset)
 -O<num>      optimisation level, max is 1 (default: 0)
 -p<num>      set bit precision for samples. (default: 16)
 -s[l|r]      stereo sid support or [left/right] channel only
 -t<num>      set play length in [m:]s format (0 is endless)
 -<v|q>       verbose or quiet (no time display) output
 -v[p|n][f]   set VIC PAL/NTSC clock speed (default: defined by song)
              Use 'f' to force the clock by preventing speed fixing
 -w[name]     create wav file (default: <datafile>[n].wav)
Madman
Unregistered
33
Sunday, August 17th 2008, 3:22pm
Ja genau, sowas :) Danke
Sanguinus
Unregistered
34
Thursday, September 11th 2008, 12:36pm
Hallo,
ich weiß nicht, ob mein Beitrag hier richtig ist, aber:
Ich verwende SIDTool mit SIDplay2w zum Export ausgewählter .sid-Dateien in .wav
Was mir hierfür noch fehlen würde, wäre eine Batch-Funktion wie sie z.B. VirtualDub bietet.
D.h. ich wähle z.B. verschiedene Songs in die Playlist, welche aber nicht zum abspielen, sondern als .wav-Export Richtung SIDplay2w dient.
Hier müsste dann noch die entsprechende Zeit aus der HVSC Songlengths.txt übermittelt werden (evtl. plus 10 Sekunden), da man die ja bei SIDplay2w immer manuell im .wav-Dialog eintippseln muss.
Im Endeffekt hätte man dann eine Playlist, die selbstständig mittels SIDplay2w sid-Dateien in .wav exportiert.
Bevor ich hier mit Ideen weiter ins Detail gehe, erst einmal die Frage ob so etwas überhaupt als sinnvoll erachtet wird?! :)
FXXS
Freibeuter
  • "FXXS" is male
35
Thursday, September 11th 2008, 12:42pm
fänd ich auch praktisch, auch wenn ich jetzt schon länger nix mehr umgewandelt habe...
mit sidplay1 wäre dann auch das getrennte abspeichern der drei stimmen+digi efekte möglich....
(damit kann man dann ganz brauchbares Pseudo stereo hinbekommen wenn man es weiter bearbeitet...)
sl FXXS
  • "C64-CAMPER" is male
  • »C64-CAMPER« is a verified user
Date of registration: Mar 31st 2006
36
Thursday, September 11th 2008, 1:14pm
Ein Linuxport....
Schwarzes_Schaf
Unregistered
37
Friday, September 12th 2008, 8:50am
Quoted
Sowas müsste mit der neuen commandline Version möglich sein.
Von den anderen Playern (z.B. sidplay2/w, sidplay1, TinySid) ist ohnehin dringendst abzuraten, wenn man originalgetreuen SID Sound möchte.
Madman
Unregistered
38
Friday, September 12th 2008, 11:45am
Manno, Ihr seid aber auch nie zufrieden :weg: :roll2:
Sanguinus
Unregistered
39
Friday, September 12th 2008, 1:12pm
@Schwarzes_Schaf
Ich bin mit der Klangqualität von SIDplay2w unt "Real C64 Enviroment" eigentlich ganz zufrieden.
Zumindest ist die Emulation deutlich besser als mein altes SIDamp-Plugin. :)
Nur leider ist der Export in .wav sehr langsam und Adam Lorentzon wird kein neues Update herausbringen.
Beim Thema "Umwandeln in .wav" kommt es mir neben der "guten Qualität" auf einfaches handling an und entweder gute Geschwindigkeit oder gute Batch-Funktionen. Ich weiß nicht, ob ich mit dem SIDplay2 für Kommandozeile da gut bedient bin?
Wenn SIDTool in einer neueren Version natürlich das SIDplay2 für Kommandozeile nebst gutem handling und evtl. Batch-Funktionen enthalten würde, wäre das vermutlich eine weitere positive Bereicherung. :D
Madman
Unregistered
40
Friday, September 12th 2008, 6:34pm
Da wäre ich nicht so sicher.
Ich will mir das wohl mal ansehen, aber wenn das ein Akt ist, diese INI Datei im Windows Verzeichniss zu editieren, weiß ich nicht, in wie weit das Tool das unterstützen wird.
Ich würde dafür dann TinySID raushauen, das scheint mir eh niemand zu nutzen.
Mal sehen, aktuell habe ich noch zwei Webseiten zu bauen, dann sehen wir weiter.
