You are not logged in.
Dear visitor, welcome to Forum64. If this is your first visit here, please read the Help. It explains in detail how this page works. To use all features of this page, you should consider registering. Please use the registration form, to register here or read more information about the registration process. If you are already registered, please login here.
spooki
Intermediate
  • "spooki" celebrates his birthday today
  • "spooki" is male
Date of registration: Mar 3rd 2006
  • Send private message
member since 72 month member since 72 month member since 72 month member since 72 month
21
Wednesday, May 30th 2007, 9:27pm
@Hucky
man immer her damit :juhu:
spooki :winke:
Hucky
Sage
  • "Hucky" is male
  • »Hucky« is a verified user
Date of registration: Feb 28th 2003
member since 108 month member since 108 month member since 108 month member since 108 month member since 108 month member since 108 month
22
Wednesday, May 30th 2007, 10:02pm
@Spooki
Das läuft auf meinem Arbeitsrechner seit 1988, oder so ...
Damals :P
Auf meinem Zweitrechner ist die Version: "BRENN DIR EINEN !! II" ;)
mfG Hucky
www.emu-ecke.de
2 X Merlin PP64 V1.3 / 1 X Merlin PP64 V1.1 Eprommer
1.Place Game-Competition "Battle Squadron" - 460200 Pts / DoReCo 29.11.08 :juhu:
suche / nehme gerne:
Tafelsilber aus dem 17. Jahrhundert :P
c64-camper
Liemke - das Paradies auf Erden ;-)
  • »c64-camper« is a verified user
Date of registration: Mar 31st 2006
23
Wednesday, May 30th 2007, 10:53pm
Kennt hier vielleicht jemand den "Klon"
>>Du schon wieder?<< :nixwiss:
Den suche ich schon seit mehreren Jahren vergebens..
Classic Gamers -->http://www.classic-gamers.de<--
sotonic
Unregistered
24
Friday, June 1st 2007, 9:58pm
Nope!
Hat nicht geklappt....Dauerlauf wie zuvor.
Das File sah im Monitor so aus wie erwartet = ab 4000 kamen die Daten noch einmal.
Allerdings war das ein rom File von Disk.
Vielleicht sollte ich den PIN 27 des 256er Eproms mal auf Low legen..
oder mal das 128 er auslesen und das File direkt benutzen..
Shit!
Abscess
Unregistered
25
Saturday, June 23rd 2007, 9:30pm
Hi zusammen...
Ich frag mal nett ob jemand " Ewing Dos " kennt .!
Ich hatte es damals auf meinem c64 ...
Wenn man den reset knopf gedrückt hatte , gingen 2 grüne Balken von der mitte aus nach Oben und Unten auf ..
mit grüßen aus Duisburg ..
Dennis
Thunderbird1974
Unregistered
26
Monday, June 25th 2007, 8:49pm
Ewings Dos + Frage
Hallo zusammen,
ja ich kenne Ewing Dos, hab grad ein Image davon gezogen :freude.
Kann mir bitte jemand sagen wie ich Speeddos, Dolphin Dos und das Original
Betriebssystem der Floppy auf Eprom brennen kann.
Reihenfolge und benötigte Adapterplatine bzw. Anschaltung der Adressen wären hilfreich.
Danke für Eure Mühen.
This post has been edited 1 times, last edit by "Thunderbird1974" (Jun 25th 2007, 8:50pm)
Overdoc
Master
  • "Overdoc" is male
Date of registration: Dec 3rd 2002
member since 126 month member since 126 month member since 126 month member since 126 month member since 126 month member since 126 month member since 126 month
27
Monday, June 25th 2007, 10:43pm
Einfach ein größeres Eprom nehmen, die System nacheinander reinbrennen und dann mit den höchstwertigen Adresspins zw. Masse und via 10KOhm Widerstand gegen 5V schalten.
Dolphindos läuft so ohne weiters aber nicht, denn das braucht auch noch eine 8KB Ramerweiterung in der Floppy damit ein kompletter Track zwischengespeichert werden kann !
Wenn es wie ich annehme für eine alte 1541 sein soll dann nimmst du eine Adapterplatine und ein 32KB Eprom (27256), da passen dann 4 Systeme rein. Für die beiden höchstwertigen Adresspins A14 und A13 hast du dann in Summe 4 high-low Kombinationen und es wird der entsprechende Adressbereich im Eprom aktiviert und somit das dort gebrannte System :)
Pinbelegung suchst du dir am besten im Internet bzw.auch den Schaltplan der Adapterplatine. Müßte auch auf www.emu-ecke.de zu finden sein.
was ich noch so suche:
Commodore VC-1515 Drucker, 1350 Maus, Amiga 1020 Laufwerk
Thunderbird1974
Unregistered
28
Tuesday, June 26th 2007, 6:15pm
Mehrere Betriebssysteme
Vielen Dank Overdoc,
hab mir das gestern mal angesehen und mir mal vorgenommen meine binarys
in ein 27C512 Eprom zu brennen.
So wie ich das dann sehe werden ja
dann die Adressleitungen A13, A14 und A15 zum anwählen der einzelnen Bänke mit Hi bzw. Lo beschaltet.
Die Adapterplatine für ein 512`er Eprom ist auch nicht schwer herzustellen.
Kann man die Ram-Erweiterung nachbauen oder war das damals ein Spezialteil?
Stellt sich aber auch die Frage benötige ich Dolphin Dos oder reicht Speeddos Plus?
Benötigt Turbotrans 3.4 auch noch einen Zusatz? Das wäre auch zum brennen
vorgesehen.
Insgesammt hätte ich vorgehabt folgende Speeder bzw. Kernals zu brennen:
Kernal Original
Ewing Dos
EXOS V3
Hypra Dos
The Beast System
SpeedDos Plus
Dolphin Dos
Turbotrans 3.4
Dazu passend in die Floppy 1541:
Original
SpeedDos Plus
Dolphin Dos
Turbotrans 3.4
Muss man beim Brennen des Floppy Eproms auf was achten oder werden die Daten einfach hintereinander in Eprom gebrannt?
This post has been edited 1 times, last edit by "Thunderbird1974" (Jun 26th 2007, 6:24pm)
Thunderbird1974
Unregistered
29
Tuesday, June 26th 2007, 6:24pm
Wie brennt Ihr eigentlich Eure Eproms?
Vor allem verstehe ich das hintereinander Brenne nicht ganz.
Ich nutzte einen Willem Eprommer und dieser benötigt ein einzelnes File.
Hab mir zwar mit einem Hexeditor alle Dateien zusammengebastelt so das sie ein brennbares File ergeben, ist aber umständlich.
Für bessere Lösungen wäre ich dankbar.
Falls Ersatzteile für C64, C128, VC20, Amiga benötigt werden, ich habe noch einiges im Keller lagern :hammer:
Danke nochmals an alle in diesem genialen Forum!
dirk
Intermediate
  • "dirk" is male
Date of registration: May 29th 2006
30
Tuesday, June 26th 2007, 7:45pm
Man kann auch jedes File einzeln laden und gibt in der Epromsoftware einen
Offset ein.Geht auch bei Willem.
Offset 0000 Original Kernel
Offset 2000 Speeddos
Offset 4000 Exos
Offset 6000 Was weiß ich
Der Wert des Offsets hängt natürlich von der ROM Größe ab.
2000 bei einem 8 KB Eprom
4000 bei einem 16KB Eprom
This post has been edited 2 times, last edit by "dirk" (Jun 26th 2007, 7:49pm)
Thunderbird1974
Unregistered
31
Tuesday, June 26th 2007, 8:01pm
Danke für den Tip.
Habs grad versucht aber der Buffer wird jedes Mal von 0000 an überschrieben,
egal welchen Offset ich festlege.
dirk
Intermediate
  • "dirk" is male
32
Tuesday, June 26th 2007, 8:15pm
Das hat mit dem Buffer nichts zu tun. Der wird immer ab 0000 geladen.
Wichtig ist der Offset ab dem der Brenner das Eprom programmiert.
Dirk
Thunderbird1974
Unregistered
33
Tuesday, June 26th 2007, 8:53pm
Ich muss dann wohl in ein 27C512 jeweils die 8K Betriebssysteme mit der Offsetverschiebung nacheinander brennen?
Werden die leeren Adressbereiche nicht mit FF oder 00 überschrieben und das
Eprom letztendlich als voll deklariert?
dirk
Intermediate
  • "dirk" is male
34
Tuesday, June 26th 2007, 9:28pm
Der Buffer ist normalerweise mit FF, die beim Programmieren übersprungen werden gefüllt.
Du mußt aber darauf achten das die Romdatei wirklich genau 8192 Bytes groß ist.
This post has been edited 1 times, last edit by "dirk" (Jun 26th 2007, 9:33pm)
Thunderbird1974
Unregistered
35
Tuesday, June 26th 2007, 9:33pm
Alles klar, werd das mal die Tage versuchen.
Hat hier vieleicht jemand noch ein paar Fastloader Images die ich oben noch nicht genannt habe?
Bräuchte auch noch das 64´er Dos. Wurde zwar schon mal hier zum runterladen angeboten aber das funktioniert leider nicht bei mir.
Nochmals vielen Dank an all die 64´er User!
Abscess
Unregistered
36
Tuesday, June 26th 2007, 9:44pm
Moin zusammen.
Gib es eine möglichkeit das ich das ewing dos in ccs emulator laden kann ?
grüße aus duisburg
1000ste-user
Unregistered
37
Tuesday, June 26th 2007, 9:46pm
nur die Turbotrans Roms werden nichts nützen, TT ist ein stark Hardware lastiges System (RAM), für Speeddos wird noch ein Parallelkabel benötigt.
Und 64er Dos gibt es verschiedene Versionen die untereinander nicht 100% kompatibel sind - es wird also die genau passende Version für Rechner und Floppy benötigt.
Thunderbird1974
Unregistered
38
Tuesday, June 26th 2007, 10:05pm
Ewing Dos im CCS64
Falls es hier funktioniert hänge ich hier das Ewing Dos Image an.
Natürlich fertig umbenannt in kernal.rom :winke:
Thunderbird1974 has attached the following file:
  • kernal.rar (6.66 kB - 42 times downloaded - latest: May 29th 2013, 2:17pm)
Thunderbird1974
Unregistered
39
Tuesday, June 26th 2007, 10:19pm
RE: Ewing Dos im CCS64
Danke 1000ste-user.
Werd dann das Kernal nicht nutzen können. Wie sieht es mit Jiffy Dos aus?
Wird hier auch Zusatzhardware wie beim Dolphin Dos verwendet?
Sonst würd ich Jiffy und das 64´er in die noch freien Eprom-Bänke schreiben wenn nix zusätzlich gebraucht wird.
Wie verschalte ich eigentlich ein Eprom damit ich zwei Bänke aufrufen kann?
Hab grad bemerkt, dass das 64´er Floppy File 16kb gross ist und somit eben
zwei Bänke belegt.
Ist schon so lange her, dass ich mich damit befasst habe. :juhu:
Parallelkabel ist kein Problem, Eprom brennen stellt teilweise ein Problem dar, da ich aus unerfindlichen Gründen von 3 gleichen (gelöschten) Eproms 2 verbrate :help:
Danke nochmals für die zahlreichen Hilfestellungen.
Plus4Vampyre
Intermediate
  • "Plus4Vampyre" is male
Date of registration: Apr 13th 2007
40
Tuesday, June 26th 2007, 11:52pm
Da scheint doch jemand wirklich Ewing Dos zu kennen und dann noch aus Duisburg. Das kann doch kein zufall sein :schreck!:
Gesucht: Monitore (14xx, 1081, 19xx) auch tausch gegen 1801, PC-I, PC4x-III, PC50,PC60, Plus/4 mit 256KB, Chessmate in OVP, Drean C16 in OVP, VIC20 Module von OEM und Mach. Lang, VC20 Steinbeisser als Modul
