Dear visitor, welcome to Forum64. If this is your first visit here, please read the Help. It explains in detail how this page works. To use all features of this page, you should consider registering. Please use the registration form, to register here or read more information about the registration process. If you are already registered, please login here.
Quoted
Der 6581 R1 war ein prototyp aus dem Jahr 1982 ich weis nicht ob der sich so sigifikant von dem 6582 unterscheidet vom Sound her.
Z̵̰͊ͮ̏͗͐ͣ̒A̬̲̪̣̤͆̍̚L̥̦̈ͬ́G͏͉O̝̞̣̜̬͂̐ ҉̲̦̜̫I̛̟̥̯̳͂̽̃̈́̐S̿̃̑͆̓ͦͯ͏̘̣̝̹̙̣̮ ͔̳͚̞̖̙̥͌͗ͧ̅̓́̊͢Ţ͙̗́ͦ́̅O̩̼̠̣̺͐̊ͪN̦̄ͧ͒Y͓̺͍̖͂ͦͯ͝ͅ ̞̘͇̣͐̓ͤ̇͐T͚͖̑̿ͯ̃͐̋͡Ḧ̡̻͚͔̳̙̤́̀̽̋ͥ̚E̵͉̤̻̘̰͆ ͑̄҉̞̗͓̣͍P̵̝̘̼͍̱͌̍̾͒ͅO̸ͭN̺ͦ̀ͫÝ͖̦ͤ̒̃̽̾̚
Da jeder C64 leicht anders klingt, ist es auch nur wichtig, dass es Dir gefällt.Ich möchte den Micro 64 ziemlich genau vom Sound anpassen so das er dem realen C64 sehr nahe bzw. perfekt rankommt! Ich denke ich bin mit meinen Einstellungen zufrieden!
Source code |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 |
======================================================================= bero === Version: 1.00.2012.06.24 Build 692 SVN revision: 2273 Date: 24. June 2012 Time: 15:21 UTC -------------------------------------------------------------------------------- - Implemented new PAL emulation with true virtual PAL signal encoding, signal bandwidth filtering and decoding and with emulation of the VIC NMOS glitches (which are applied to the Y/luminance YUV channel) and it includes an cool looking CRT monitor simulation. A current very good midrange or highend graphic card is needed for this new PAL and CRT monitor emulation, so don't even bother to try with an low end or bad midrange graphics card, CPU-integrated GPU, APU or chipset graphics. And it is maybe only for NVIDIA graphics cards, because I've no AMD/ATI graphics card for testing & debugging. - Refactored video settings option menu with an more cleaner structure - Added a workaround for corrupt PSID tune files, whom don't reset the volume register at start in an right way - Fixed SID digi boost - Fixed SID SINC resampling - "SSEized" SID SINC resampling and prepared these code parts for "AVXiziation" ================================================================================ |
Quoted
A small demonstration of the new PAL and CRT monitor emulaton in Micro64.
It is the new PAL emulation with true virtual PAL signal encoding, signal bandwidth filtering and decoding and with emulation of the VIC NMOS glitches (which are applied to the Y/luminance YUV channel) and it includes an cool looking CRT monitor simulation.
It is a multipass GLSL shader effect, so a current modern fast very good midrange or highend graphics card with at least OpenGL 3.0 and shader model 4.0 is needed for this new PAL and CRT monitor emulation, so don't even bother to try it with an low end or bad midrange graphics card, CPU-integrated GPU, APU or chipset graphics.
I had some many frame drops while the capturing process was running, so some natural time-based double frame effects were recorded not correctly here, for example the visible parts where emusuxX0r-crest.prg is loaded and running, where the frame dropping is ruining the, for the human eye, natural optical color mixing double frame effect of it in connection with the VIC NMOS glitch.
And it seems that the Youtube reencoder had reduced the quality of this video also. The original video resolution is 768x564, but Youtube has downsampled it to 654x480, 390x360, 327x240, and so on.
So I'll maybe recapture it in the next day on a more powerful computer in FullHD resolution, where I've no frame drops while capturing at constant 50 FPS framerate with FRAPS and the youtube reencoder doesn't reduce the video quality then at the then present 1080p quality selection.
In einem anderem Beitrag sind wir gerade beim Thema Katakis.
Das gibt es g64-Images die laufen nur bis bis vice-2.3. Neuere wie beim vice-2.3.19 und der aktuelle micro64 gehen die Images nicht.
Katakis-g64+nib.7z
Kannst ja mal schauen was da nicht geht. :-)
index.php?page=Attachment&attachmentID=45105
Wollte gerade die neue PAL Emulation testen und am rumschrauben an den Settings gab's plötzlich und spontan 'nen "white screen", sprich ich kann nix mehr sehen. Problem nun, ich kann die Settings blind nicht zurückstellen.
Daher jetzt meine Frage: wie kann ich die Settings auf default resetten? In der Registry hab' ich auf die schnelle nichts gefunden.
Forum Software: Burning Board® 3.1.7, developed by WoltLab® GmbH
