You are not logged in.
Dear visitor, welcome to Forum64. If this is your first visit here, please read the Help. It explains in detail how this page works. To use all features of this page, you should consider registering. Please use the registration form, to register here or read more information about the registration process. If you are already registered, please login here.
Brotscheibe
Unregistered
201
Monday, July 7th 2008, 10:36pm
Und wie geht es weiter mit dem Ultimate C64 emmulator, gennant Micro64 ?
Brotscheibe
AntaBaka
Z̵̰͊ͮ̏͗͐ͣ̒A̬̲̪̣̤͆̍̚L̥̦̈ͬ́G͏͉O̝̞̣̜̬͂̐ ҉̲̦̜̫I̛̟̥̯̳͂̽̃̈́̐S̿̃̑͆̓ͦͯ͏̘̣̝̹̙̣̮ ͔̳͚̞̖̙̥͌͗ͧ̅̓́̊͢Ţ͙̗́ͦ́̅O̩̼̠̣̺͐̊ͪN̦̄ͧ͒Y͓̺͍̖͂ͦͯ͝ͅ ̞̘͇̣͐̓ͤ̇͐T͚͖̑̿ͯ̃͐̋͡Ḧ̡̻͚͔̳̙̤́̀̽̋ͥ̚E̵͉̤̻̘̰͆ ͑̄҉̞̗͓̣͍P̵̝̘̼͍̱͌̍̾͒ͅO̸ͭN̺ͦ̀ͫÝ͖̦ͤ̒̃̽̾̚
  • "AntaBaka" is male
  • »AntaBaka« is a verified user
Date of registration: Oct 29th 2006
  • Send private message
member since 72 month member since 72 month member since 72 month member since 72 month
202
Monday, July 7th 2008, 11:06pm
In den Worten des unsterblichen Duke Nukem: When it's done.
In der Zwischenzeit: Hyper64
sauhund
ist falsch abgebogen
  • "sauhund" is male
Date of registration: Jul 16th 2005
member since 90 month member since 90 month member since 90 month member since 90 month member since 90 month
203
Tuesday, July 8th 2008, 8:33am
ich konnte in der zwischenzeit mal einen linux-build testen... leider noch mit der alten vic emulation, aber in dem fall ging es auch um das aussehen der pal emulation, und die ist schonmal sehr gut :)
und ich hab jetzt endlich einen guten grund weswegen ich mal 'nen neuen rechner brauche =P
http://www.hitmen-console.org http://magicdisk.untergrund.net
Die Furcht vor der freimütigen Antwort kann auch robuste Charaktere befallen.
enigma
SID Auflöser
  • "enigma" is male
Date of registration: Jun 1st 2003
member since 108 month member since 108 month member since 108 month member since 108 month member since 108 month member since 108 month
204
Tuesday, July 8th 2008, 2:10pm
Ach ja, noch was zur 1541 Soundemulation, die ist so exakt, so dass sogar "1541 music" von alpha-170 klanglich einwandfrei funktioniert.
Gibt es denn eine Testaufnahme, z.B. wie es klingt wenn man ganz normal eine Diskette formatiert?
Ich habe eine echte 1541, die bisher sogut wie nicht in Verwendung war und eine die sehr oft verwendet wurde und mittlerweile klingen die schon ziemlich unterschiedlich.
Mich wuerde interessieren, inwieweit die Emulation da passt.
Hier mal eine Aufnahme der viel verwendeten 1541 (Newtronics Mechanik):
Format Original Routinen: http://mail.lipsia.de/c64/1541format_orig.mp3
Format ARMK6 Routinen: http://mail.lipsia.de/c64/1541format_armk6.mp3
Error: http://mail.lipsia.de/c64/1541error.mp3
Ein sehr merkbares Detail ist beispielsweise, dass die Lautstaerke beim Spurwechsel je nach Position unterschiedlich ist.
Weiterhin moechte ich zur SID Emulation noch auf folgende Seite hinweisen:
http://www.bel.fi/~alankila/c64-sw/
Antti Lankila verarbeitet da Informationen die aus aktuellen Reverse Engineering Bemuehungen herauskommen.
Dazu auch: http://oms.wmhost.com/misc/
Mit Filter: http://oms.wmhost.com/misc/r3_filter.gif
Envelope Generator: http://oms.wmhost.com/misc/r3_envelope.gif
Waveform generator: http://oms.wmhost.com/misc/r3_waveform.gif
marco64
Karteileiche mit kleinem Lebensfunken
  • "marco64" is male
Date of registration: Aug 21st 2005
205
Tuesday, July 8th 2008, 3:14pm
Sorry, the Server failed to retrieve the requested data. ;(
Brotscheibe
Unregistered
206
Tuesday, July 8th 2008, 7:16pm
Jo, so ist es.
Brotscheibe
enigma
SID Auflöser
  • "enigma" is male
207
Wednesday, July 9th 2008, 1:55am
Ihr habt Recht, ich habe das Homedir vergessen. Die korrekten Links sind:
Format Original Routinen: http://mail.lipsia.de/~enigma/c64/1541format_orig.mp3
Format ARMK6 Routinen: http://mail.lipsia.de/~enigma/c64/1541format_armk6.mp3
Error: http://mail.lipsia.de/~enigma/c64/1541error.mp3
Schwarzes_Schaf
Unregistered
208
Tuesday, August 19th 2008, 3:23pm
Mir ist zu Ohren gekommen, dass nun offenbar doch eine 'Distorted' 6581 Emulation mit an Bord sein wird.
Könnte man darüber was genaueres erfahren, oder fällt dies auch unter 'GEHEIM'? ;)
Zusätzlich ein paar aussagekräftige Klang Beispiele zur Güte der Filter wären nicht schlecht.
Gerüchten zu Folge soll es sich ja um so ziemlich das gleiche Prinzip handeln, welches von Antti Lankila zur Zeit als Open Source entwickelt wird.
sauhund
  • "sauhund" is male
209
Tuesday, August 19th 2008, 3:28pm
die berechnung der filterkurve basiert auf alankilas messprogram, ja. das tweaken und überführen in die "neue" form passiert aber automatisch und muss nicht per hand erfolgen.... und da enden auch schon die gemeinsamkeiten :)
seVeneleVen
Unregistered
210
Tuesday, August 19th 2008, 3:30pm
ich kann nur sagen, dass songs, wie z.b. spijkerhoek kein problem mehr darstellen und sich absolut fantastisch anhören. zur technik muss sich bero äußern, wenn er mag.
Schwarzes_Schaf
Unregistered
211
Wednesday, August 20th 2008, 2:12pm
Äh naja. Es ist schwer einzuschätzen wie 'fantastisch' klingt . :) Und ist die Micro64 Distortion nun besser als die von Lankila?
sauhund
  • "sauhund" is male
212
Wednesday, August 20th 2008, 2:44pm
Quoted
nein, die zugrunde liegenden theorien sind die gleichen. die sid emulation ansich ist aber (in der hauptsache wegen aufwendigerem resampling) etwas besser.
seVeneleVen
Unregistered
213
nunja, alles ist immer nur subjektiv betrachtet.
ich habe hier 7 verschiedene sid-chips (6581er) und jeder klingt, wie hinlänglich bekannt, anders. einen davon mag ich ganz besonders gern, einige mag ich gar nicht.
von daher würde ich mal sagen, abwarten und dann die emu selbst beurteilen.
weil gerade die sid-routine z.zt. nochmal in bearbeitung ist, gibts auch erst was zu hören, wenn diese arbeiten abgeschlossen sind.
assiduous
Unregistered
214
Wednesday, August 20th 2008, 3:51pm
Quoted
no added value over Lankilas work ? this is rather disappointing. Micro64 is / was touted as an emulator to be based on the "actual hardware description" not on the perceived behavior(which may be misleading). if you read SID distortion web page you`ll realise that while some of his improvement are based to some extent on the die shots (as is Resid and all the other SID emulators) there are many aspects he changes back and forth to get the sound he likes. how does it differ from what the other emu devs- Horrocks,VICE Team,PHS do ?
AntaBaka
215
Sunday, August 24th 2008, 9:03pm
Hm, but the hardware description does not match the actual chip as far as I know...
Brotscheibe
Unregistered
216
Wednesday, September 3rd 2008, 10:06pm
Was Neues ?
Brotscheibe
C64-CAMPER
Liemke - das Paradies auf Erden ;-)
  • »C64-CAMPER« is a verified user
Date of registration: Mar 31st 2006
217
Wednesday, September 3rd 2008, 10:09pm
It's done when it's done.
Classic Gamers -->http://www.classic-gamers.de<--
Brotscheibe
Unregistered
218
Wednesday, September 3rd 2008, 10:17pm
Alles klar, es ist Fertig, wen es fertig ist :@1@: :dafuer:
Brotscheibe
Naquaada
Unregistered
219
Thursday, September 4th 2008, 12:29am
Habt ihr vor, eine Mac-Version zu machen? Wenigstens für Intel-Macs...
Die 1541-Sounds kommen bestimmt gut als Handy-Klingelton!
BeRo
Unregistered
220
Thursday, September 4th 2008, 3:47pm
Ja, für Intel x86 Macs wird es evtl. eine x86 MacOSX Version geben, sobald ich das Linkingproblem von ObjectPascal Code mit Objective C Code (wegen der sdl_main.m als Entrypoint, da Micro64 ja SDL verwendet) gelöst habe.
Versionen für Win32, Linux-x86/32 und Linux-x86/64 existieren schon und laufen. Aber keine Win64 Version, da ich kein 64-bittiges Windows installiert habe. Eine Win64 Version ist zudem unnötig, da die Win32 Version ja auch problemlos unter Win64 laufen sollte.
